Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-15-2021, 02:16 PM   #113
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by Lelandjt View Post
All three sound very inefficient. We'll see but if that's the strategy I predict horrible fuel economy and very modest power gain.
Would replacing the pistons be labor-cost prohibitive? Maybe that's what the "Stage 2" kits will do.
What makes you say it would get poor fuel economy? Every ICE car has what I said, FI or not.
Old 12-15-2021, 04:14 PM   #114
falcon_wizard
Drives: BRZ 2013
Originally Posted by saltywetman View Post
People are completely forgetting that this car is a throwback to the ae86. Which was a cheap accessible lightweight na rwd coupe that people can mod to their hearts content. Factory FI will never be considered by Toyota for this car.
Based on the Gen2 having gone increased displacement and NA, I do not see any reason why this car would go FI out of the factory in this generation, if ever. Imho, anyone not satisfied with the car as it is should try it first, then either look for another car or be willing to have it modified to meet their goals… while I personnally went the latter route after owning the car for 4 years, I also am of the opinion this car doest not « need » FI… the chassis has a very high ceiling potential but the car is great as is in my book.
falcon_wizard is offline   Reply With Quote
The Following User Says Thank You to falcon_wizard For This Useful Post:
timurrrr (12-15-2021)
Old 12-15-2021, 04:16 PM   #115
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
STI could go 2.5L with Forged Ti rods, dry-sump and 8250 redline
Rumor started
Stonehorsw is offline   Reply With Quote
Old 12-16-2021, 02:06 AM   #116
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
Using valve timing to reduce compression ratio.
Retarding ignition timing.
Richening the mixture.
Those are the things you said would be done to get aftermarket FI to work on this engine (I thought it had a higher compression ratio than the last gen). Those things all reduce the efficiency of an engine and are done as minimally as possible on stock turbo cars, because they start with lower compression.
If this really has the same CR as the last gen than I expect turbo kits will work even better. The larger displacement spools a turbo quicker and doesn't need as much boost.
Lelandjt is offline   Reply With Quote
Old 12-16-2021, 02:19 AM   #117
EAGLE5
Dismember
EAGLE5's Avatar
High static CR isn't the limiter for most people. Bending pistons is a bigger issue. I've not seen somebody unhappy with performance of a decent turbo on the twins. Just unhappy with blown engines from aggressive tunes.
Old 12-16-2021, 07:24 AM   #118
falcon_wizard
Drives: BRZ 2013
I think the confusion came from a mistake by media in the early press releases where the CR was indicated as 13.5. I suspect they mixed it with the steering ratio which is 13.5:1, but since then the actual CR was confirmed at 12.5:1 like the first gen. In addition, the gen 2 has now straight rods, so should be more FI friendly as well than gen 1. i recall reading that the tranny was also strengthened, so all good things…
The Following 3 Users Say Thank You to falcon_wizard For This Useful Post:
Midnightsky (12-16-2021), Pete (12-16-2021), Tcoat (12-16-2021)
Old 12-16-2021, 10:06 AM   #119
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
So far it sounds like 350whp on a small-medium EFR should not be an issue on stock internals.
Midnightsky is offline   Reply With Quote
Old 12-16-2021, 01:07 PM   #120
falcon_wizard
Drives: BRZ 2013
Yeah, I can’t wait to see what my tuning shop will be able to do out of the box on stock internals when they update their stage 1 turbo kit for the gen 2, which they also offer on a brand new BRZ with full warranty equivalent to OEM when bought with a brand new car… (the LP Turbo from Lachute Performance) so basically one can buy a fully warranteed new FI BRZ… Not aware if other shops offer something like that…
PTUNING Competition Turbo System V2 (version 2) Mrc@ptuning Forced Induction 188 11-14-2018 11:45 AM
North America to get Subaru version but not Toyota version? Ground N Pound BRZ First-Gen (2012+) — General Topics 42 05-29-2014 01:23 AM
Turbo version confirmed? (apologize for this if its a re-post) samsung001 AUSTRALIA 39 06-13-2012 04:29 AM
Do you think we are going to see a trd version or 5axis version of the FRS next week DIG1992 Scion FR-S / Toyota 86 GT86 General Forum 9 01-04-2012 07:59 AM
