| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2017 Toyota 86
Tires Options for Rays 57cr
yo, I am new here and new to cars in general so my knowledge is little. I’ve been doing some research to find tires to go with the rays 57cr. Idk what’s good and what’s not. So I am looking for a some daily driving tires, and am in need of a recommendation. Budget is okay, but I don’t want to go over $800. some tires I’ve been told is landsail, fire hawk, BF Goodrich comp 2, and I found some toyo proxey. Are these options nice? What other options can I look at
#2 |
Drives: '23 BRZ
What size wheels?
Go to www.tirerack.com to see how different tires compare. Best tire depends on your wants/needs/usage envelope. Dry grip, wet grip, cold/snow grip, desired life, feel/handling, noise, comfort, etc. Based on yer location and "daily driving", look in the "Ultra High Performance" or "Max Performance" categories. Maybe "Ultra High Performance All Season" if you even *might* drive somewhere cold/snowy. I wouldn't bother with "Landsail"! Stick with known good major brands. |
#3 |
Drives: 17 Asphalt 86
Indy 500s are a good budget summer tire. They don't have the best all around performance like the top tier UHP tires. PS4s, ECS.
Road noise and wear will vary too. I got some dirt cheap yoko advan sport V105. Not sure if I trashed them due to toe out but road noise is loud. Much louder than PS4S I ran previously. Need wheel width for tires. Assuming they're 17x9 a 245/40R17 is go to size and fits nicely. |
#4 |
Purist
Drives: 2013 FRS - Hot Lava
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#5 | |
Wheel size I’m probably gonna get 18x9.5 +22 Sent from my iPhone using Tapatalk |
#6 |
Drives: '23 BRZ
You might want to reconsider that size/offset! Unless you have cutout arches and flares, you're going to poke and rub like crazy... Do they come in +35 offset? That should work with 245/35-18s, if you have some negative camber... Is car lowered and if so how much?
#7 |
Drives: Crapcan
Why? Typical wheel size is 17X9 +38 in the 57CR for this platform. It will get you closeish to flush front and rear, and gives enough strut clearance. It also gives you a lot of reasonable priced tires in 245/40/17.
Firehawk Indy in 245/40/17 is 160 on TR. 245/35/18 is 200 for the same tire.
#8 | |
Idk tbh, that was the size I was gonna go with some Kansei KNPs but I decided to get rays instead , and thought going with the same size would be nice Sent from my iPhone using Tapatalk |
#9 | |
They come in a +38, +22, +12 offset Sent from my iPhone using Tapatalk |
#10 |
AutoX-10/10ths every run
Start here to determine what size/offsets are known to work for wheels: https://www.ft86club.com/forums/showthread.php?t=7535
#11 |
Drives: '23 BRZ
#12 |
#13 | |
Alright bet thanks Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to IamKevin2 For This Useful Post: | whataboutbob (12-10-2021) |
#14 |
Drives: '23 BRZ
| WTB: RAYS 57CR Gold | Clark20 | Want-To-Buy Requests | 0 | 02-14-2020 07:25 PM |
| FS:[IL/WI] RAYS Engineering 57CR 18x9.5 EDP | NEW IN BOX | BanditKeith | Wheels and Tires | 2 | 01-24-2020 07:24 PM |
| Rays Gram Light 57CR - ALL NEW COLORS | FT-86 SpeedFactory | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 04-05-2018 05:41 PM |
| RAYS Gram Light 57CR | DesertLava | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 12-26-2017 11:55 AM |
| New Rays Gram Lights 57CR - ALL NEW COLORS | FT-86 SpeedFactory | Wheels and Tires | 3 | 08-07-2017 09:45 AM |
