Old 12-07-2021, 10:00 AM   #81985
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Did you also check the rear fenders?
Assuming struts up front? What is suspension type in the back?
I didn’t really check the rear. 90% of the time, as long as front clears rear will clear it. Isn’t it?
ichitaka05 is offline
Old 12-07-2021, 10:06 AM   #81986
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Maybe. Still worth a check?
The other thing is the outside edge could rub on the front or back of the wheel well when steering. Might want to measure that clearance somehow.
Spuds is offline
Old 12-07-2021, 10:39 AM   #81987
ichitaka05
Site Moderator
ichitaka05's Avatar
Front, I’ve already done all the possible things
Caliper clearance
Strut clearance
Back inner wheel-well clearance at maximum turn
Front inner wheel-well clearance at maximum turn
Fender… not worried. Last time I’ve checked, about 7 fingers gap between fender to tire.
Did I miss anything else on the front?
Spuds (12-07-2021)
Old 12-07-2021, 11:04 AM   #81988
Spuds
The Dictater
Spuds's Avatar
Caliper clearance
Strut clearance
Well, I wasn't worried about the inside of the wheel, just the outside edge. I would expect the outside edge of the tire to be somewhere around 7-10 mm closer to the front or rear of the fender/liner when the wheel is fully turned one way or the other. If it's an inch or more of clearance as the closest approach, I agree don't worry about it.
There's no way your wheel and tire selection has too low of a load rating right? That would be weird.
Edit:. Also, you could try the "view wheels that fit" option and see what the difference is?
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
ichitaka05 (12-07-2021)
Old 12-07-2021, 11:17 AM   #81989
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pretty much every time except for the 22' Twins
NoHaveMSG is offline
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
ichitaka05 (12-07-2021), soundman98 (12-08-2021)
Old 12-07-2021, 11:26 AM   #81990
ichitaka05
Site Moderator
ichitaka05's Avatar
So here’s the odd part. Every time I put the wheel into the “view wheels that fit”, the wheel I want doesn’t come up… BUT same exact spec, but different wheel come up. Same 20x8.5+20.
The wheel I’m look at is TSW Tamburello in matte bronze
Old 12-07-2021, 11:55 AM   #81991
Spuds
The Dictater
Spuds's Avatar
Is the fill valve inside the spokes on that? That's kind of cool, but that could be the issue there.
Also, can't find a 22 highlander on the tsw fitment guide, so maybe that's an issue.
Spuds is offline
Old 12-07-2021, 12:24 PM   #81992
Yup! It’s 2-tone wheels. To certain degree I don’t mind it, but my sis-in-law likes it more than me. She gonna buy it off from me.
Well, that's OK, as long as the wheels are "kept in the family".
I was fixing on -ing you if you were just going to get new wheels and stack those fine looking wheels in the corner of your garage -
BTW, where is all your "stuff", that most people keep in their garage?
humfrz is offline
Old 12-07-2021, 01:16 PM   #81993
ichitaka05
Site Moderator
ichitaka05's Avatar
Search ‘21 model. It’s same. Only difference is 1 year newer lol
Yeah, I traded in w winter set (due to morning is freezing cold)
I do have my 18” Enkei Raijin. Tires are shot, but def want to used em when I buy 86/BRZ again or sell em.
But number 1 my fav wheels are these. These cost ridiculous amount, but love the design, color & specs. Only complain is weight isn’t THAT light (<18lbs)
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
humfrz (12-07-2021), NoHaveMSG (12-07-2021)
Old 12-07-2021, 06:10 PM   #81994
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
You ever see yourself doing this?
MS, CSCS, TSAC-F, CPT
weederr33 is offline
The Following User Says Thank You to weederr33 For This Useful Post:
humfrz (12-08-2021)
Old 12-07-2021, 07:14 PM   #81995
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I think it would require a pretty big mirror or some sort of studio to do it properly.
Captain Snooze is offline
Old 12-07-2021, 08:27 PM   #81996
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Old 12-07-2021, 08:57 PM   #81997
Spuds
The Dictater
Spuds's Avatar
Doing what?
Spuds is offline
Old 12-07-2021, 08:59 PM   #81998
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
ScoobsMcGee is offline
The Following 6 Users Say Thank You to ScoobsMcGee For This Useful Post:
NoHaveMSG (12-07-2021), soundman98 (12-08-2021), spike021 (12-08-2021), Spuds (12-07-2021), Ultramaroon (12-07-2021), weederr33 (12-07-2021)
