Old 07-30-2012, 06:50 PM   #43
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I definitely want a set of these when you get a finished product. Do you have a price set yet?
kmbkk is offline
Old 07-30-2012, 10:43 PM   #44
phenryiv1
Drives: 2011 WRX
Originally Posted by cruzinbill View Post
they did arrive, i will be installing them thurs, fri at the latest.
Update?
phenryiv1 is offline
Old 07-30-2012, 10:52 PM   #45
phenryiv1
Drives: 2011 WRX
The price for the main door adapters is $30 shipped in the continental US for the pair. The dash adapters will be an additional $7, or $10 if purchased alone.
I priced them the same as my other Subaru adapters even though they use more material and cost more to ship.
More info: http://www.subaruaudio.net/subaru-sp...nd-scion-fr-s/
Working on the how-to-install page.
Old 07-30-2012, 11:25 PM   #46
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Thanks! I'll want both, but I don't know the cutout sizes off the top of my head. I'll have to wait until I get home in a few weeks. I'll have to let you know the sizes then. I believe the door speakers (6.5") are a 5 3/4" cutout and the dash speakers (4") are 3 3/4"
kmbkk is offline
Old 07-31-2012, 03:13 AM   #47
cruzinbill
Drives: Argento 6spd FR-S
i got a chance to mess with the adapters today, i will be uploading a review and pics sometime this week. upfront i can say the door adapters are ok but dont cover the hole completely... the dash ones im not a fan of at all to be honest. It may just be for me on those tho.
cruzinbill is offline
Old 07-31-2012, 10:48 AM   #48
phenryiv1
Drives: 2011 WRX
The dash ones were pretty much an afterthought, so no harm in them NOT being perfect. If people want them, I'll still make them but until I get an OEM speaker to use as a temlpate (those were designed only from drawings, pictures, and measurements) I was looking at them as nothing but a mountng point for aftermarket tweeters that are too big to fit in the 1" OEM tweeter location.
As for the door adapters, I'd be interested to see what you mean about them not covering the hole. As they were based on a smaller adapter that others have confirmed fit the BRZ/FRS, I am wondering what might need to be changed.
Old 08-01-2012, 03:04 AM   #49
cruzinbill
ok np, like i said ill get pics when i have some time this week, its really just that the adapters are about .5" short on the top of the speaker hole. other than that, the issue for me with the dash one was i tryn to use it with a 3.5" speaker not a tweeter... so it didnt really work out.
Old 08-01-2012, 11:29 AM   #50
KRAZYK
Self Entitled
KRAZYK's Avatar
Drives: 13' Red FR-S, 12' Toyota Tundra
What advantage do these add? Is it just to give you extra mounting depth? or does it also help the accustics?
KRAZYK is offline
Old 08-01-2012, 12:34 PM   #51
phenryiv1
Drives: 2011 WRX
From post #4:
Stock speakers have an odd shape. The speakers are contoured to fit the door, and the mounting holes are 3 holes in a roughly triangular shape where the screws go into a nylon insert (as opposed to the inner door skin). This helps prevent the screws from backing out too easily. This is a good thing, so you should try to re-use the stock mounting points. This means that you need some sort of an adapter, because aftermarket speakers typically use 4 mounting holes that are on a different mounting pattern than the stock circle.
In addition to an adapter for the mounting holes, most aftermarket speakers are more robust than the stockers. This means bigger baskets, bigger magnets, and an overall deeper profile. Sometimes, the basket diameter is much larger than the stock ones. You need an adapter that has a larger cutout diameter.
You will also need something that will allow your window to clear the larger magnet assembly on the back of aftermarket speakers. For this, you need a spacer.
If you look at a stock speaker (or a picture of one), you can see that it usually has a built-in spacer. If you subtract that extra depth and just screw a replacement to the door skin, you lose a lot of mounting depth.
As far as why to use PVC and not MDF (or any wood product), any wood will absorb water over time and will eventually warp, rot, or swell. You can seal the wood to prolong the process, but it will happen at some point.
With PVC, you get a fairly dense product that allows a secure mounting to the door skin while avoiding the shortcomings of wood and without too much excess weight.
Old 08-01-2012, 05:55 PM   #52
KRAZYK
Self Entitled
KRAZYK's Avatar
Ah, Thanks for that.
I am thinking about getting a set from you.. but I havent picked out my speakers yet.. I have a 4 channel amp that I can run the following:
70w @4ohm x4
85w @2ohm x4
or bridged 165w @4ohm x2
component sets I am looking at are Focal, RE audio, or image dynamics.
IF I do not bridge and keep all 4 channels, I have a set of 3.5 inch polk audio coax speakers I would install along with a component set.
Any opinions?
KRAZYK is offline
Old 08-03-2012, 04:13 PM   #53
cruzinbill
finally posted a review of the spacers, sorry it took as long as it did.
Old 08-05-2012, 09:55 AM   #54
phenryiv1
Drives: 2011 WRX
So based on feedback, I will be changing the design a bit. I would prefer to have an OEM speaker on hand to facilitate the changes and I am working on that now. Details to follow.
Old 08-05-2012, 10:32 AM   #55
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Intresting
TouchMyHonda is offline
Old 08-10-2012, 12:49 AM   #56
wheelhaus
wheelhaus's Avatar
I'm also interested.
I have a set of Pioneer Premier TS-C720PRS 6.5" that are rather deep at ~2.7" thanks to the ginormous magnet/basket. I have some angled spacers about 1/2-1" deep from a 2005 WRX that might work, but it sounds like they may need to be re-drilled to fit the BRZ's mounting pattern. If they're a bust, I'd love to help the beta fit testing or purchase a pair if I do in fact need them, I just don't have the car yet.
wheelhaus is offline
Rattle-ly Speaker Door Panels engee Cosmetic Modification (Interior/Exterior/Lighting) 45 11-25-2014 08:45 AM
spacers for 5x114 in australia derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-30-2012 11:03 AM
H&R Wheel Spacers! vividracing Wheels and Tires 3 06-19-2012 06:11 PM
Rattle in door speaker panels Lefty Electronics | Audio | NAV | Infotainment 2 06-18-2012 07:41 PM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 02:31 PM
