Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-28-2021, 11:38 AM   #15
Grateful Dave
2nd 86 member
Grateful Dave's Avatar
Drives: 2013 Asphalt AT FR-S
I did the Whiteline camber bolts on my first gen, it does make a difference. The car turns into the corner better.
Grateful Dave is offline   Reply With Quote
Old 11-28-2021, 11:59 AM   #16
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I had the Subaru bolts on my 13, front end bite was notably better, and the bolts were literally 5 bucks each
Old 11-28-2021, 12:19 PM   #17
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Just ordered mine. $5 a piece. if I can get ~ -1 degree i'll be happy.
SpectreRT is offline   Reply With Quote
Old 11-28-2021, 12:26 PM   #18
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Old 11-29-2021, 10:22 PM   #19
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Hey guys, how much does camber affect tire wear for daily driving? Also does anyone know the stock factory alignment numbers?
I want to add some camber to the front and maybe a hint of toe in the rear to eliminate understeer, but my wallet is still traumatized from tire purchases for my Miata on a track alignment.
Interceptor777 is offline   Reply With Quote
Old 11-29-2021, 10:41 PM   #20
Ohio Enthusiast
Drives: 2018 BRZ
Most folks agree that around -2 degrees is fine for the street, some even say -2.5 or even -3. Camber bolts top and bottom will give you about -2 degrees, so that should be okay for DD.
Old 11-29-2021, 10:41 PM   #21
Yoshoobaroo
TRACKBREAD
The amount we’re talking about, practically no effect.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
timurrrr (11-30-2021)
Old 11-30-2021, 02:42 AM   #22
Strat_FRS
Drives: 2015 FRS for daily and track use
The important thing here is toe. This is what will wear out your inner edges. Set toe to 0 and you can run -2 to -2.5 degrees up front with minimal effect on the inner tier wear especially if you balance this out with spirited/autox/track driving leaning on the outer edges of the tire.
For street driving with the ~-1.5 we have in the front it feels very well balanced. A bit of trail braking and corner entry is very good.
Strat_FRS is offline   Reply With Quote
The Following 3 Users Say Thank You to Strat_FRS For This Useful Post:
Midnightsky (02-28-2022), timurrrr (11-30-2021), Yoshoobaroo (11-30-2021)
Old 11-30-2021, 08:09 AM   #23
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
I got about -1.1 with just the upper crash bolt (and RCE Yellows). I've been thinking about what to do to get up to about -2. Would you guys say the Pedders mounts or the Whiteline camber bolt are the better move?
Cephas is offline   Reply With Quote
Old 11-30-2021, 10:13 AM   #24
Ohio Enthusiast
Drives: 2018 BRZ
I'm on stock sized tires and using camber bolts top and bottom, got me -2.1 degrees.
If you're on stock sized wheels and tires, I'd say camber bolts are cheaper and supposedly give a better camber geometry (with regard to camber interaction with caster when turning).
If you're running wider wheels/tires you might rub the spring perch with extra hub camber, so you'd need to use the Pedders.
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Cephas (11-30-2021), Midnightsky (02-28-2022)
Old 11-30-2021, 10:42 AM   #25
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Pedders are a good solution.
SPC lower, crash bolt upper is good for -2° to -2.3°. That's currently how I am setup.
I have had two alignments done at different shops and the camber read 2.1 and 2.3 without changes.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Cephas (11-30-2021), timurrrr (11-30-2021)
Old 11-30-2021, 06:55 PM   #26
Cephas
Cephas's Avatar
Good call, I hadn't considered top vs bottom geometry. I'm on stock wheels with 225 rubber at the moment, but the widest I can see myself going is an 8in rim with 245 tires. Still, that's a ways off, so I might just get some camber bolts anyway since they're cheap.
Old 12-01-2021, 12:22 AM   #27
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
For what it's worth, I was running the SPC cam bolts in the lower hole and Pedders top hats. I got -2.2 up front before I started rubbing tire (235/45/17). With spacers I could've seen over -2.5.
I liked the extra caster too from the Pedders.
BlueWhelan is offline   Reply With Quote
The Following 2 Users Say Thank You to BlueWhelan For This Useful Post:
Midnightsky (02-28-2022), RToyo86 (12-16-2021)
Old 12-01-2021, 05:31 PM   #28
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
You wont have an issue with even your future possible setup on the prior gen twins with both camber and crash bolts
Cephas (12-01-2021)
Simplest Bestest Mods to tighten up steering, turn in and body flex Broz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 05-13-2021 02:06 PM
Simplest possible install for tablet transition Electronics | Audio | NAV | Infotainment 9 02-11-2014 05:43 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
