| BRZ Second-Gen (2022+) General Topics General topics for the second-gen BRZ |
#15 |
2nd 86 member
Drives: 2013 Asphalt AT FR-S
I did the Whiteline camber bolts on my first gen, it does make a difference. The car turns into the corner better.
#17 |
Drives: Subaru BRZ
#18 |
Drives: '15 BRZ RA
#19 |
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Hey guys, how much does camber affect tire wear for daily driving? Also does anyone know the stock factory alignment numbers?
I want to add some camber to the front and maybe a hint of toe in the rear to eliminate understeer, but my wallet is still traumatized from tire purchases for my Miata on a track alignment. |
#20 |
Drives: 2018 BRZ
Most folks agree that around -2 degrees is fine for the street, some even say -2.5 or even -3. Camber bolts top and bottom will give you about -2 degrees, so that should be okay for DD.
#21 | |
TRACKBREAD
The amount were talking about, practically no effect. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | timurrrr (11-30-2021) |
#22 | |
Drives: 2015 FRS for daily and track use
The important thing here is toe. This is what will wear out your inner edges. Set toe to 0 and you can run -2 to -2.5 degrees up front with minimal effect on the inner tier wear especially if you balance this out with spirited/autox/track driving leaning on the outer edges of the tire. For street driving with the ~-1.5 we have in the front it feels very well balanced. A bit of trail braking and corner entry is very good. |
| The Following 3 Users Say Thank You to Strat_FRS For This Useful Post: |
#23 |
Drives: 2017 Toyota 86 (860 SE)
I got about -1.1 with just the upper crash bolt (and RCE Yellows). I've been thinking about what to do to get up to about -2. Would you guys say the Pedders mounts or the Whiteline camber bolt are the better move?
#24 | |
Drives: 2018 BRZ
If you're on stock sized wheels and tires, I'd say camber bolts are cheaper and supposedly give a better camber geometry (with regard to camber interaction with caster when turning). If you're running wider wheels/tires you might rub the spring perch with extra hub camber, so you'd need to use the Pedders. |
| The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post: | Cephas (11-30-2021), Midnightsky (02-28-2022) |
#25 | |
Drives: 17 Asphalt 86
SPC lower, crash bolt upper is good for -2° to -2.3°. That's currently how I am setup. I have had two alignments done at different shops and the camber read 2.1 and 2.3 without changes. |
#26 |
Good call, I hadn't considered top vs bottom geometry. I'm on stock wheels with 225 rubber at the moment, but the widest I can see myself going is an 8in rim with 245 tires. Still, that's a ways off, so I might just get some camber bolts anyway since they're cheap.
#27 | |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
I liked the extra caster too from the Pedders. |
| The Following 2 Users Say Thank You to BlueWhelan For This Useful Post: | Midnightsky (02-28-2022), RToyo86 (12-16-2021) |
#28 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
| The Following User Says Thank You to finch1750 For This Useful Post: | Cephas (12-01-2021) |
| Simplest Bestest Mods to tighten up steering, turn in and body flex | Broz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 52 | 05-13-2021 02:06 PM |
| Simplest possible install for tablet | transition | Electronics | Audio | NAV | Infotainment | 9 | 02-11-2014 05:43 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
