Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-21-2021, 04:26 PM   #1
Strat_FRS
Drives: 2015 FRS for daily and track use
Gen 2 vs Gen 1 Comparo Video
Hi Guys and Gals, here's a comparison video going over a lot of the aspects of the car - under the car, suspension, interior, engine bay.
Strat_FRS is offline   Reply With Quote
The Following 9 Users Say Thank You to Strat_FRS For This Useful Post:
alphasaur (11-22-2021), bcj (11-24-2021), DarkSunrise (11-22-2021), Falken86 (11-22-2021), Jianlun (11-22-2021), Jucostud (11-25-2021), Pete (11-21-2021), Stonehorsw (11-24-2021), T-Steve (11-29-2021)
Old 11-22-2021, 12:40 AM   #2
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Are the strut position the same? Do old strut bars and the master cylinder brace work between the two?
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE
vignesh is offline   Reply With Quote
Old 11-22-2021, 12:51 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
there was a picture in the " '22 on vorshlag scales" that showed a 12-20 top plate on top of the 22 strut.
strut location is slightly different, but same bolt pattern. almost looks like they rotated the previous mount
Old 11-22-2021, 02:13 PM   #4
Strat_FRS
Coilovers are confirmed to swap from first gen. Looks like quite a few people have installed those coilvers. The MC brace I have not tried yet.
The interesting thing is that the car has a lot of stability and a lot more grip compared to the gen1. Even on the Primacy tires.
Old 11-22-2021, 02:29 PM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Very interesting remark about the longer tube intake manifold. It looks they were trying to optimize more the middle torque curve.
The Following User Says Thank You to nikitopo For This Useful Post:
Ohio Enthusiast (11-22-2021)
Old 11-22-2021, 02:45 PM   #6
Falken86
Falken86's Avatar
Drives: '13 WRB BRZ '22 ISM BRZ Ordered
Fingers crossed we can swap over the header also.
Falken86 is offline   Reply With Quote
The Following User Says Thank You to Falken86 For This Useful Post:
Midnightsky (11-23-2021)
Old 11-24-2021, 08:04 PM   #7
Strat_FRS
We will find out soon.
Just did some camber bolts up front and got an alignment to balance the car out a touch more and video will be up shortly!
The Following 2 Users Say Thank You to Strat_FRS For This Useful Post:
DriveDriftDogfight86 (11-26-2021), Falken86 (11-24-2021)
Old 11-24-2021, 09:09 PM   #8
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
How much camber you get with thr bolts? Same as gen1 1.2-1.3*ish? Assuming no camber plates up top.
MacSpeed is offline   Reply With Quote
Old 11-24-2021, 11:09 PM   #9
Strat_FRS
That's pretty spot on. Evened out the front and rear camber.
The Following User Says Thank You to Strat_FRS For This Useful Post:
MacSpeed (11-25-2021)
Old 11-24-2021, 11:51 PM   #10
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Subaru bolts or aftermarket?
Old 11-25-2021, 11:06 PM   #11
Jucostud
Rookie
Jucostud's Avatar
Drives: '22 BRZ Premium MT6
Thanks for the videos and info Alex!
Jucostud is offline   Reply With Quote
Old 11-26-2021, 02:16 AM   #12
Strat_FRS
Whilteline 14mm
Old 11-29-2021, 04:39 PM   #13
vignesh
Engineer
vignesh's Avatar
Are the swaybars interchangble between the two?
I was curious and was planning to just swap a used Subaru WRX rear sway bar in the brz to get it more tail happy
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE
Old 11-29-2021, 06:30 PM   #14
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I believe Perrin confirmed that "standard size and shape" rear bars should fit.
I'd start with the alignment, perhaps some negative front camber is all that's needed to make the car less prone to understeer.
2022 GR86 Premium MT & AT Comparo StE92ve GR86 General Topics (2nd Gen 2022+ Toyota 86) 121 12-08-2021 11:21 AM
Comparo Megathread! Xerexyz FR-S / BRZ vs.... 14 05-30-2019 04:00 PM
Color Comparo request Timmy_Jones FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 04-09-2013 10:49 PM
Track and road comparo: FR-S/BRZ/GC/MX-5/GTI Sport-Tech FR-S / BRZ vs.... 0 03-01-2013 02:37 AM
odd miata, genesis and frs track comparo fatoni FR-S / BRZ vs.... 2 08-21-2012 11:43 PM
