Old 11-22-2021, 12:24 PM   #15
Ebush
Drives: 2017 Hot Lava 86
Just wanted to clarify that the starter on my engine has an external solenoid. 6 months ago I asked David which starter I should order, he told me to order a k24 starter. So that’s what I did. That “k24” starter had an internal solenoid. The k24 starter with internal solenoid fit better than the recent starter I ordered that is supposedly k20 and has an external solenoid. After my modifications I never tried the k24 starter but I’m sure it will fit.
I did go ahead and clearance the trans just incase but I don’t think I needed to.
Ebush is offline   Reply With Quote
Old 11-22-2021, 01:50 PM   #16
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I grabbed a K24 starter because that is what I was told that they would be using, but I'm guessing grinding down the bellhousing was less desirable than just buying a K20 starter for them, so it is that much more plug and play.
I do see that your starter is external and looks like the K20 starter in their photo. I think I will be just using the K24 starter and making modifications. I'm not too worried about grinding down the inside of the bellhousing.
Old 11-22-2021, 02:55 PM   #17
visbits
Drives: Garbage.
I just love how they have you remove spot welds and hammer the body but won't have you grind/file down the inside of the trans to clear the starter your probably already own.
visbits is offline   Reply With Quote
Old 11-22-2021, 06:53 PM   #18
Ebush
Anyone else have the awesome issue where you’ll never be able to drain the oil because the drain bolt it basically touching the subframe? I posted a video on my Instagram.
What part of Cincinnati are you in @visbits? I’m in Hamilton, maybe once my cars done we can meet up or something, would be cool to check out the turbo setup
On yours.
Old 11-22-2021, 08:07 PM   #19
Irace86.2.0
On yours.
I feel like of these questions and comments would be better served in the Kpower kit thread.
Did you email them, and did they get back to you? I had planned on driving a few miles down the street to Fujimoto’s distribution warehouse to see if I could pick up a valve for this build. I had one on my FA20, and I won’t be going back. I will probably hammer the subframe and do a valve if it will clear. Weird that they didn’t design that better. Even in their writeup it is clearly blocked by the subframe.
Old 11-22-2021, 08:13 PM   #20
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
That's a pretty major oversight. I may look into a valve as well some hammering or notching as well.
captain awesome is offline   Reply With Quote
Old 11-22-2021, 10:22 PM   #21
Four_wheel_drifts
Drives: Whiteout track car; lava donor
That is terrible and totally unacceptable for a $800 oil pan.
Four_wheel_drifts is offline   Reply With Quote
Old 11-22-2021, 11:09 PM   #22
Ebush
I kinda forgot that this thread was just a general kswap owner thread and that the other is specifically for Kpower. Didn’t email them but David commented on my Instagram post and told me to email him. Not like he can do anything about it at this point. Oil pans on the engine, and the engines in the car. It’s not coming out unless I need to replace the clutch or if the engine blows. I’ll just get one of those oil extractor things To suck the oil out.
I don’t think a valve would work down there as there just isn’t any room between the current bolt and subframe. Best bet would be to install a new drain bolt. And maybe even a dipstick right there on the oil pan since our normal dipstick is pretty useless. Took me 3 minutes to install the dipstick. Just hits the baffling inside the pan.
Old 11-22-2021, 11:52 PM   #23
brzlegend
Drives: brz
Hammer a crucial part of your car?
Why not relocate it, especially if you have a tig?
Buy a bung, drill a hole, install bung, hold it in place with a smaller bolt and two washers,
spot weld it two or three places, remove bolt and run a bead around it or you can fuse it. Bolt and washers are not necessary but helps transfer heat if your a amateur tig welder.
They may have built the pan with a tube crossmember in the proto car.
brzlegend is offline   Reply With Quote
Old 11-23-2021, 12:47 AM   #24
Irace86.2.0
I already did hammer the subframe; we have to in the directions. Now, I'll just do it some more. The subframe already has bends and curves and holes. What is the difference between one more? It would actually be easier for me to cut, sand and MIG weld a recession in the subframe than for me to TIG weld the oil pan, but I don't really think it is necessary; I'll have to see. I'm not sure, but the current spot for the oil pan could be the low spot.
Old 04-12-2022, 02:13 PM   #25
RedReplicant
Drives: None
I kinda half-heartedly put up a post where I will keep track of mine. Waiting on the KPower kit to show up then I'll add more.
https://www.ft86club.com/forums/showthread.php?t=149422
RedReplicant is offline   Reply With Quote
Old 04-16-2022, 12:11 PM   #26
Irace86.2.0
For reference for this thread, these are the final numbers. Depending on what the new GR86 transmission proves to hold, I may do that or a CD009 or BMW transmission, and I will likely do cams, rods n pistons and at some point go back to the dyno to turn up the boost.
Old 11-25-2022, 03:32 PM   #27
D K
Stig's dark passenger
You literally addressed every concern I had about the platform..
Weight
Engine
Engine placement
(going to) double A arm
114.3
Awesome build!
Originally Posted by DIY View Post
I'm already tagged in here but thought I'd post a recent photo.
Built to WTAC rules for Pro-am time attack class
K24A3 engine
AT Power dry sump
BMW ZF320 5-speed
BW EFR9174 twin scroll turbo IWG with electronic actuator low mounted
100% self built in my garage
D K is offline   Reply With Quote
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 04:20 AM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
BBK Owners: How do you swap pads? ZionsWrath Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-24-2016 08:17 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Vic Owners with White or Black GTS, want to swap to Grey GTS? kharn83 AUSTRALIA 3 06-05-2012 06:21 AM
