#421 | |
However... why did you choose the ACE tune over the EL tune? Our JDL 4-2-1 is a short EL, not a long one like the ACE Edit: Oh ok! I did not see the last posts In my case, I will be purchasing the regular EL. The only difference should be the zero per cylinder compensation though |
#422 |
Drives: brz 2017 hksv2
guys, both headers require more logging and retuning
anyone posting dyno or logs with wayno tunes and ace or JDL have subpar results compared to other well known ecutek tuner so it worth if you spend some time adjusting afr and increase timing to knock limit, don t just put OTS tunes and pretend they work ideally from the beginning |
#423 |
Drives: Subaru BRZ 2016
Nobody is pretending it is ideal. I just did some testing for the sake of it and posted the results, thinking some may find it useful or at the very least somewhat interesting. That's all there is to it.
| The Following User Says Thank You to NicFromTheNorth For This Useful Post: | J95 (11-19-2021) |
#425 |
Ah ok, it does not say that on the website. I will order the EL soon considering the ACE is specific for the long length and then try to adjust AFR and timing as he describes and I guess that the most we can do with OFT tune...
#426 |
In the final tune I settled on, which is based on the Wayne roms, I actually tuned out the torque bump I was getting at 4600 rpm to make it more constant across the rpm range. Some people may find that to be an odd decision!
#427 | |
#428 |
I reduced the angles in the intake and exhaust AVCS tables on the 4600rpm row.
| The Following User Says Thank You to NicFromTheNorth For This Useful Post: | J95 (01-28-2022) |
#429 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
What have people been doing about the contact between the header and underbody shield? Cut to form? It seems to bow out a solid 1/4 to 1/2 inch on Perrin motor mounts.
#430 |
Drives: frs
| The Following User Says Thank You to Teseo For This Useful Post: | strat61caster (08-02-2022) |
#431 |
Drives: 17 Asphalt 86
Put my order through this week.
Given a rough ETA of 4 weeks, they're prepping for the next batch of builds. |
#432 |
Drives: BRZ, Miatas and a Land Cruiser
JDL EL 421
JDL UltraQuiet over/mid pipe. Tanabe Medallion Touring single exit TRD intake/TRD filter. OFT stg2+e85 off the shelf. Ohio/midwest pump e85, unconfirmed % 193.66whp NASA TT5 compliance, so dynojet, SAE, smoothing 5 |
#433 |
Drives: frs
I bet you could squeeze more power.
#434 |
Drives: 2013 frs red
Those are good tq numbers.
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
