Old 11-19-2021, 03:39 AM   #421
J95
J95's Avatar
Originally Posted by NicFromTheNorth View Post
This thread seems appropriate for posting dyno numbers I got at Light Touch Tuning. They provided .csv files of the data so I made this graph, rather than posting a screen capture of their software also showing runs we did with another tune.
car: BRZ 2016
mods: JDL 4-2-1, everything else is stock
tune: Wayne Rom v167 for ACE, 91 octane fuel
Very interesting info, because I was thinking about purchasing a Wayne tune too. You don´t have a run with the stock tune or OTS tune though?
However... why did you choose the ACE tune over the EL tune? Our JDL 4-2-1 is a short EL, not a long one like the ACE
Edit: Oh ok! I did not see the last posts
In my case, I will be purchasing the regular EL. The only difference should be the zero per cylinder compensation though
J95 is offline   Reply With Quote
Old 11-19-2021, 03:46 AM   #422
tomm.brz
Drives: brz 2017 hksv2
guys, both headers require more logging and retuning
anyone posting dyno or logs with wayno tunes and ace or JDL have subpar results compared to other well known ecutek tuner
so it worth if you spend some time adjusting afr and increase timing to knock limit, don t just put OTS tunes and pretend they work ideally from the beginning
The Following 3 Users Say Thank You to tomm.brz For This Useful Post:
J95 (11-19-2021), NoHaveMSG (11-24-2021), RToyo86 (08-31-2022)
Old 11-19-2021, 08:02 AM   #423
NicFromTheNorth
Drives: Subaru BRZ 2016
Nobody is pretending it is ideal. I just did some testing for the sake of it and posted the results, thinking some may find it useful or at the very least somewhat interesting. That's all there is to it.
NicFromTheNorth is offline   Reply With Quote
The Following User Says Thank You to NicFromTheNorth For This Useful Post:
J95 (11-19-2021)
Old 11-19-2021, 08:06 AM   #424
NicFromTheNorth
The EL has more advance on the intake AVCS below 5600 rpm.
J95 (11-19-2021)
Old 11-19-2021, 08:21 AM   #425
J95
J95's Avatar
Ah ok, it does not say that on the website. I will order the EL soon considering the ACE is specific for the long length and then try to adjust AFR and timing as he describes and I guess that the most we can do with OFT tune...
Old 11-24-2021, 11:20 AM   #426
NicFromTheNorth
In the final tune I settled on, which is based on the Wayne roms, I actually tuned out the torque bump I was getting at 4600 rpm to make it more constant across the rpm range. Some people may find that to be an odd decision!
Old 11-24-2021, 01:08 PM   #427
J95
J95's Avatar
What do you mean about tuning out, I mean what did you change?
Old 11-24-2021, 03:53 PM   #428
NicFromTheNorth
I reduced the angles in the intake and exhaust AVCS tables on the 4600rpm row.
J95 (01-28-2022)
Old 08-01-2022, 09:49 PM   #429
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
What have people been doing about the contact between the header and underbody shield? Cut to form? It seems to bow out a solid 1/4 to 1/2 inch on Perrin motor mounts.
B T is offline   Reply With Quote
Old 08-01-2022, 10:14 PM   #430
Teseo
Drives: frs
Try to "massage" the panel with a hammer
The Following User Says Thank You to Teseo For This Useful Post:
strat61caster (08-02-2022)
Old 08-31-2022, 11:51 AM   #431
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Put my order through this week.
Given a rough ETA of 4 weeks, they're prepping for the next batch of builds.
Old 08-31-2022, 12:41 PM   #432
doward
Drives: BRZ, Miatas and a Land Cruiser
JDL EL 421
JDL UltraQuiet over/mid pipe.
Tanabe Medallion Touring single exit
TRD intake/TRD filter.
OFT stg2+e85 off the shelf.
Ohio/midwest pump e85, unconfirmed %
193.66whp
NASA TT5 compliance, so dynojet, SAE, smoothing 5
doward is offline   Reply With Quote
The Following 2 Users Say Thank You to doward For This Useful Post:
DocWalt (11-17-2022), Teseo (09-01-2022)
Old 09-01-2022, 09:05 PM   #433
Teseo
Drives: frs
I bet you could squeeze more power.
Old 09-02-2022, 05:53 PM   #434
Lantanafrs2
Drives: 2013 frs red
Those are good tq numbers.
Lantanafrs2 is offline   Reply With Quote
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
