Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-15-2021, 03:11 PM   #43
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by slipstream8 View Post
I had these wheels on my 2017 as well, with RCE yellows being my only suspension mod. Beautiful wheels, but the fronts always looked a little tractor-like to me. Wondering if your setup avoided that by going lower?
If RCE yellows are your only mod, I have my front tires tucked *way* further in with camber plates at max negative camber in addition to being ~3/4" lower.
Old 11-15-2021, 03:33 PM   #44
slipstream8
slipstream8's Avatar
Drives: On order: 2022 ISM BRZ Ltd
So if I'm going purely for a street setup and am not going for a slammed look, is there a happy medium to get tucked in without compromising ride quality? I don't care too much about tire wear.
[Sorry if I am getting off topic a little, but I will be trying the wheels on the 2022.]
slipstream8 is offline   Reply With Quote
Old 11-15-2021, 03:37 PM   #45
ZDan
ZDan's Avatar
Drives: '23 BRZ
Maximize front camber with camber bolts and Pedder's offset top mounts.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
slipstream8 (11-15-2021), timurrrr (11-15-2021)
Old 11-15-2021, 04:59 PM   #46
OkieSnuffBox
Drives: '23 BRZ Limited
Where does that typically get you to?
On my '15 I had Ground Controls, with solid mounts front and rear, and 255/35/18 Star Spec IIs.
Fantastic on smooth roads, but with our crappy streets in Oklahoma it could downright punishing at times.
Old 11-15-2021, 08:23 PM   #47
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
I'm just wondering, I know so little about tire stuff. If I went out and bought the R18 225/40 PS4s tires they have in my market now for the GRYaris, could I just fit them over my stock 18's and be perfectly fine?
Blighty is offline   Reply With Quote
Old 11-15-2021, 08:49 PM   #48
ForeverCar
Drives: 2022 BRZ and some other cars
Factory uses 215/40/18. 225/40/18 would be about 4mm taller side wall. That should work fine (speedometer would be a little off, higher center of gravity, effectively a slight longer final drive).
ForeverCar is offline   Reply With Quote
The Following User Says Thank You to ForeverCar For This Useful Post:
Blighty (11-16-2021)
Old 11-15-2021, 10:25 PM   #49
groovymoonbear
groovymoonbear's Avatar
Drives: ‘22 CWP BRZ LTD 6MT
I have Pirelli Sottozero 3’s which are 225 / 40 / R18 and I’ve found a calculator online that notes that this against the stock wheels / tires have it only gaining .8 miles per hour at 65 MPH. So below that it’ll be less than a mile an hour different, and at higher speeds up to 100 MPH it can be up to 1.5-2 miles, depends on how crazy you’re going.
groovymoonbear is offline   Reply With Quote
The Following User Says Thank You to groovymoonbear For This Useful Post:
Old 11-16-2021, 08:03 AM   #50
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Originally Posted by OkieSnuffBox View Post
But as mentioned, when you buy high quality light wheels, you can wider, lighter, with wider sticky tires and STILL be lighter than the OEM setup.
Understood. And that's good news. I'll withhold judgment until actually owning the car, but the cars we've owned for, eh, the last 25 years have had adequate grip -- even for enthusiastic street driving, and I don't see us going to the track -- on OEM sizes if sticky enough tires are selected.
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
tiger1964 is offline   Reply With Quote
The Following User Says Thank You to tiger1964 For This Useful Post:
OkieSnuffBox (11-16-2021)
Old 11-16-2021, 09:56 AM   #51
OkieSnuffBox
Yeah, when I bought my 2015 I intended it to be my DD occasional HPDE/AutoX car. Got the suspension/wheels and tires/exhaust/tune done...............then life happened.
Old 11-17-2021, 05:16 AM   #52
Varelco
Drives: '15 GT86 & '22 GR86
I've not seen anyone mention that the rear track is 10mm wider than the previous generation. This obviously tallies up with the surprisingly wheel poke early adopters are seeing.
Varelco is offline   Reply With Quote
Old 11-17-2021, 02:14 PM   #53
Dylans47
Drives: Scion FR-S
I haven't seen this mentioned either. If my thinking is correct then a 45 offset wheel on the GR86 would effectively be the same distance out as a 40 offset the old car.
Dylans47 is offline   Reply With Quote
Old 11-17-2021, 02:21 PM   #54
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I believe people already measured the rear suspension on the 2022's and couldn't find any difference from 1st gens?
Old 11-17-2021, 02:54 PM   #55
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
They just measured the arms IIRC. The change is probably in the hubs, cause it’s not in the wheels.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
DocWalt (11-18-2021)
Old 11-18-2021, 12:56 PM   #56
Brock H.
Drives: 2022 BRZ, Red
Subaru Parts catalogue confirms that it has the same RUCA as previous gen. And Mike measured the RLCA and confirmed its the same length (I'm assuming the new part number for the RLCA is due to a bushing change that was advertised early on) .
Catalog also shows that the rear knuckle and rear subframe are specific to the new gen, but the Wheel Bearing assembly is the same. I'm assuming that the track width difference is coming from either or both of those. What I would like to know is if any of the bolt locations changed, and if so how did it effect camber gain.
Brock H. is offline   Reply With Quote
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
