Old 10-28-2021, 07:11 PM   #1
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Front Splitter Adjustment
I had a front splitter installed however when checking the angle of attack it was tilted backwards. Apparently the optimum angle is between .5 and 5 degrees tilted forward. I have the rods maxed out at 2 degrees backwards of level. Am I splitting hairs or not?. It seems a backwards angle would just cause lift at the front.
TommyW is offline   Reply With Quote
Old 10-28-2021, 09:35 PM   #2
whataboutbob
AutoX-10/10ths every run
I always tried to have mine level to the ground when the car was at its resting ride height. Having the front tilted up does seem to be less than ideal when generating down force. One thing I would consider though is under braking when the front of the car is diving a tilted up splitter may actually approach a zero angle relative to the ground. One issue I sometimes encountered was a splitter that was level to the ground would sometimes hit the ground under braking situations depending on the slope of the ground.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
TommyW (10-28-2021)
Old 10-29-2021, 11:02 AM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I have the same issue with a Devsport splitter. It fastens to the bottom of the bumper cover which causes it to angle upward. I'm going to fashion wedges out of treated plywood to get it level and then use material from Speedway Motors to make an air dam. If it doesn't look like crap, I'll post pictures.
The Following User Says Thank You to blsfrs For This Useful Post:
TommyW (10-29-2021)
Old 10-29-2021, 12:38 PM   #4
TommyW
TommyW's Avatar
I think everyone that installs a front splitter needs to check this. I was able to get to 0.0 and many say that is optimum so I'll leave it alone.
The Following User Says Thank You to TommyW For This Useful Post:
blsfrs (10-29-2021)
Old 10-29-2021, 02:21 PM   #5
redlined600
redlined600's Avatar
Drives: Fr-s
The first splitter I made had a negative rake (~.75") by accident. When realized, I made a second one that was more appropriately angled at .5* up in the back. At road America I picked up a couple MPH (and a little better balance but different days so take that for what it's worth) down the front straight so it stands to reason that, with a negative rake, it wasn't as efficient as it could have been.
It is, however, nearly impossible to get out of my driveway with the splitter on.
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
TommyW (10-29-2021)
Old 10-29-2021, 03:22 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can also use rubber door seal to space it down and seal it to the bumper cover.
I had an off and the rear of my splitter came loose and it was angled up a few degrees. Car handled like shit after that. Getting it flat, or tilted down a bit helps a lot.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
blsfrs (10-29-2021), TommyW (10-29-2021)
Old 11-13-2021, 03:33 PM   #7
blsfrs
blsfrs's Avatar
Attachment 206787
My splitter is now level and air dammed. It looks like amateur work because it is.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (11-14-2021), treedodger (11-14-2021)
Old 11-13-2021, 05:57 PM   #8
jflogerzi
jflogerzi's Avatar
Attachment 206787
no such thing as long as it works! And way cheaper too.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
blsfrs (11-14-2021)
whiteline front endlink adjustment oppiee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 04-20-2018 12:23 AM
Apr front splitter front bumper fitment KungFuWaffle Cosmetic Modification (Interior/Exterior/Lighting) 1 03-03-2017 11:41 AM
Just Added APR front splitter and side splitter Pekingduck Cosmetic Modification (Interior/Exterior/Lighting) 42 08-31-2016 10:22 AM
Front camber adjustment. solidONE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 75 10-01-2015 03:32 AM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
