#29 |
Drives: 2022 WRB Limited 6 Speed
Damn.. I was hoping to be able to run some 18x9.5 +38 with this new gen but guess not
Figure 255's won't fit with it so hoping i can fit a 245/35 then I don't mind rolling the fenders if it means i can squeeze 255 though, maybe i'll add a tiny bit of camber to make it fit |
#30 |
Drives: 2022 BRZ and some other cars
I have a set of 17x9 ET42 that I plan on running on my incoming BRZ with 245/40/17. I’ll share more once I put them on.
| The Following 2 Users Say Thank You to ForeverCar For This Useful Post: | Pete (11-11-2021), Yoshoobaroo (11-11-2021) |
#31 |
Drives: 2015 frs
I have some weak boi specs on order. Went with 18x8.5 +44 plan on running a 235/40 for a oem+ setup
#32 |
Drives: '94 Ford Aspire
I have a set of RPFs 17x9 +45 with Conti ExtremeContactForce 245/40/17 I will try on once I have my car and report back.
#33 |
Drives: 2023 BRZ
Been following this topic with amusement; I've been OK with OEM sizes on cars for a while, (sticky + light) > fat for me. YMMV, of course.
You have not suffered until you've taken delivery of a new car fitted with 155/80-13 tires; yesterday, I replaced a tire on a hand truck almost that wide!
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
| The Following User Says Thank You to tiger1964 For This Useful Post: | bcj (11-12-2021) |
#34 | |
Drives: 22 BRZ limited
#35 |
Drives: '15 BRZ RA
#36 | |
Drives: 2023 BRZ
Thanks for sharing that. This suggests good opportunities, with the right wheels & tires, to reduce unstrung weight if running more modest -- perhaps even OEM -- wheel/tire sizes.
#37 | |
Drives: '23 BRZ
NOTE: This is a 2017 car, not a '22! Last edited by ZDan; 11-12-2021 at 10:31 AM. |
#38 |
Drives: '22 WRB
So, there's a little bump out in the fender liner just inside of the fender lip that is what the tire has been hitting. I'll try to take pics later today, but I think the "less rubbing" has been a self clearancing thing lol. +35's with 245's might actually work. I'm tempted to try it with another set of Enkeis and some 245/40/17 PS4S's for tooling around in the winter here and back up heavy rain autocross tires.
#39 | |
Drives: 2022 GR86
Have you looked at why that bump is there, what's underneath it? Is the bump you're talking about located around any of these things? Source: https://www.instagram.com/p/CU40Tv4pdnK/ |
#40 | |
Drives: '23 BRZ Limited
But as mentioned, when you buy high quality light wheels, you can wider, lighter, with wider sticky tires and STILL be lighter than the OEM setup. I'll likely end up TWS wheels. |
#41 |
Drives: 2022 BRZ Sport-Tech
Thinking to put 57DR 17x9 +38 with 245/40/17 AD08R from my first gen to the second gen.
Ordered HKS Hypermax IV SP and will pair with RLCA. Car is arriving in Feb/March and will test it out once it's arrived. |
#42 | |
Drives: On order: 2022 ISM BRZ Ltd
I plan to try them out on my 2022, but it isn't due until February. |
| Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 10:05 PM |
| Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 06:09 PM |
| Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 07:08 PM |
| Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 04:09 PM |
| Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 03:34 PM |
