#449 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Offset: +35 Color: Silver Tires: RS4 Tire Size: 245/40/17 Drop: ~1.5" (coilovers)
| The Following User Says Thank You to villainous_frx For This Useful Post: | beltax90 (11-08-2021) |
#450 |
Drives: BMW E30, 2014 FR-S
#451 |
Off to the track!
They're absolutely filthy in that photo, two track days in a weekend
#452 |
Drives: what
#453 |
#454 |
Drives: 2014 GT86
Yeah, red gloving brakes nearby during track day, doesn't help with longetivity of plastic part and how securely it stays in place with small tabs that can deform under heat
#455 |
Drives: what
usually non metallic center caps are frowned upon if not outright disallowed at trackdays but that might be dependent on track and who's running the event
#456 | |
Drives: 2013 FR-S Series 10
Yours is in way better shape than mine which is just a DD and never tracked. I think it's UV, also don't have a garage. They look cool and are fairly cheap though.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#457 |
Off to the track!
I ceramic coated mine, here's to hoping they last. They're removed for track though, only installed after track days when the wheels are clean.
#458 |
Drives: Black BRZ
17x9 +35 RPF1 is an absolute timeless look for the 86 platform.
20 years from now a clean 86 with the +35 offset RPF1 is a setup we'll still be drooling over |
#459 |
[||•]=(86)=[•||]
Drives: 2017 Toyota 86
I was searching for fun for new wheels... in 17" it's pathetic how we don't have that many choice/offset in "cheap" quality wheels. I'll keep the RPF1, maybe a color change on my next tire set idk !
| The Following 3 Users Say Thank You to trueno86power For This Useful Post: |
#460 |
Drives: 2024 GR86/ 2015 FRS
17x9 45 offset on 2022
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
| The Following 5 Users Say Thank You to Simmons For This Useful Post: | AllThePeat (01-28-2022), beltax90 (12-25-2021), G-awesome (01-05-2022), Metabrz (01-19-2022), trueno86power (01-06-2022) |
#461 |
Drives: 2019 Toyota 86 TRD SE
Can anyone confirm if these have the pockets in the back of the wheel to be able to run 15mm 5x114 adapters and be able to clear the factory wheel studs?
#462 |
Drives: '22 GR86
17x9 +45 with 10mm spacer in front
Bronze Maxxis RC-1 255/40/17 ~1 inch drop ![]() ![]()
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD |
| The Following 3 Users Say Thank You to staples323 For This Useful Post: |
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 07:31 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 04:50 PM |
| Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel | Infamous Performance | Wheels and Tires | 122 | 02-13-2014 12:34 PM |
| Enkei RPF1 17x7.5 +48 5x100 SBC and wheel/tyre question | Victor Draken | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 12-19-2013 02:28 PM |
| Track wheel Enkei RPF1 in 16" ?? | stockysnail | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 08-07-2013 10:13 AM |
