Old 11-07-2021, 07:33 PM   #29
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
No, there should be no air in the cooling system.
COOLANT expands until the rad cap pressure is reached, at which point excess coolant beyond that pressure escapes to the COOLANT OVERFLOW TANK. As the engine cools down and the coolant contracts, the coolant that escaped during the expansion phase is sucked back into the engine.
The only cooling system with air in it is a DEGAS system that has a pressurised tank at the highest point and an air volume at the top of the system. These systems have no overflow tank as the coolant has room to expand into the air volume.
Bubbles out of the overflow pipe is not normal.
Now unfortunately, I think no matter how many times we say "Do like the manual says" and "bleed it more", I think the level of help that can be given over an internet forum is the proverbial dead horse, and beating it we did.
When a car starts to be reluctant, it's asking for some hands on.
The Following User Says Thank You to RZNT4R For This Useful Post:
jamestemperante (11-08-2021)
Old 11-07-2021, 07:51 PM   #30
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
so many flushes
LOL I am personal friend with a shop that specializes in 86s since they came out in 2012
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
jamestemperante (11-08-2021), Ultramaroon (11-07-2021)
Old 11-07-2021, 08:34 PM   #31
Have you told them they're doing it wrong?
Old 11-07-2021, 08:38 PM   #32
...eventually. I don't know if you were correcting me. If so, then perhaps I wasn't clear.
Old 11-08-2021, 11:24 AM   #33
jamestemperante
Drives: Subaru BRZ
off topic guys. can a bad thermostat can also cause slight bubbles in the radiator?
jamestemperante is offline   Reply With Quote
The Following User Says Thank You to jamestemperante For This Useful Post:
humfrz (11-08-2021)
Old 11-08-2021, 02:04 PM   #34
Only if the housing/seal around the thermostat is "sucking air". The thermostat just open and closes (if it's working right).
Reminds me of a story of when I was doing agricultural field research work. It was a hot day (108 degrees F) down in Yuma Arizona and me, and my co researcher were about to spray some experimental pesticides in a cotton field.
The problem was that I couldn't get my research spray rig to hold a steady pressure coming out of the hypro pump. This old toothless, Mexican farm hand came by and said the problem was that the system was "sucking air". Me and my fellow college educated co worker looked at each other and thought "what the hell does that SOB know about it. Hell, I built the fucking system!
Come to find out, the ol boy was right! A defective fitting on the underside of the unit had a crack in it - allowing the system to "suck air".
Also, that's when I learned that you don't lay a black crescent wrench out in the bright sun on a 108 degree day in Yuma, AZ and reach out and grab ahold of it with your bare hand -
Yes, I know I've told this story before, but I'm getting low on stories that I have made up -
THE END
PS - to the OP, oh just quit worrying about it, Bubba says a few bubbles ain't gonna hurt nutten -
The Following 4 Users Say Thank You to humfrz For This Useful Post:
bcj (11-09-2021), jamestemperante (11-09-2021), soundman98 (11-08-2021), Ultramaroon (11-08-2021)
Old 11-08-2021, 09:04 PM   #35
stacyu18
Drives: 2014 subaru brz
so not sure if this will help but maybe it has nothing to do with coolant maybe his ac drain hole is plugged up and when he runs the ac or defrost it get trap inside of the havc housing therefore when starting up blower motor turns on i work on cars for a living and have found this to be the problem for alot of cars if you have heat and car is not over heating wouldnt worry about the bubbles it will bleed out in time just keep a eye on the coolant tank add when you need to
stacyu18 is offline   Reply With Quote
The Following 4 Users Say Thank You to stacyu18 For This Useful Post:
bcj (11-09-2021), Dzmitry (11-09-2021), jamestemperante (11-09-2021), Ultramaroon (11-08-2021)
Old 11-09-2021, 01:12 PM   #36
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
I had this problem in my BRZ and heard a bubbling sound when running the AC. Dealer took care of it under warranty luckily, but it was exactly as you described, with the AC drain hole clogged up. I would say if this is the case, get it taken care of. I had a nice puddle of water under the passenger carpet built up from this and they vacuumed it out as best as they could.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
jamestemperante (11-11-2021)
No Key Icon on Dash! Cannot start car! vf34 Issues | Warranty | Recalls / TSB 6 11-27-2016 11:51 PM
No Key Icon on the Dash! Car won't start. vf34 Electronics | Audio | NAV | Infotainment 0 11-23-2016 05:41 AM
FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) Sportsguy83 Engine, Exhaust, Bolt-Ons 15 05-27-2014 12:18 PM
FA20CLUB Oil Cooler Kit Liquid/Liquid Andy@FA20Club Engine, Exhaust, Transmission 46 02-03-2014 11:10 AM
Bubbling/knocking (but not liquid) sound aside from chirping mike_ekim1024 Issues | Warranty | Recalls / TSB 22 05-05-2013 03:20 PM
