Old 11-23-2016, 05:41 AM   #1
vf34
No Key Icon on the Dash! Car won't start.
Hi All
**Help please** Sorry Guys I've moved this to the Issues forum!!!
I suffered a problem with my manual Blackline/GTS 86 (AUS). I attempted and successfully swapped out the clutch helper spring but now I don't get the Key icon on the dash so I cannot start the engine or place it in acc. Battery is not flat, interior lights, hazards and external lights work ok anything relating to press to start button onwards will not work. The fob key/remote battery are not flat either.
I thought I may have killed the clutch assembly switch, there are 2 of them on the pedal and have just swapped them out with new ones, still cannot get a key icon on the dash so still can't start.
I'm now thinking I may have killed something relating to the canbus system, when I disassembled the clutch pedal I had to release the wiring cable to the clutch assembly switches, however I did not disconnect the battery when I started the clutch spring swap. I've come to this conclusion as I have checked all the fuses, under dash and engine bay, and they are all fine.
So at this stage I'm now curious as to what the problem could be now???
Thoughts.
Thanks.
Nick
vf34 is offline   Reply With Quote
Dash lights and high beam icon are on but.. GT 86 Brah Issues | Warranty | Recalls / TSB 3 06-28-2016 12:18 AM
HELP!!! Where is my AHA icon? iamhugh Electronics | Audio | NAV | Infotainment 0 12-11-2014 09:53 PM
Another Hollywood Icon Has Passed Away White64Goat Off-Topic Lounge [WARNING: NO POLITICS] 7 08-13-2014 09:00 AM
Dash Hole Filler next to push to start Lord Peth Cosmetic Modification (Interior/Exterior/Lighting) 17 05-30-2014 09:21 PM
Icon A5 ThugNasty Other Vehicles & General Automotive Discussions 1 03-09-2013 08:11 AM
