Old 11-06-2021, 10:47 AM   #43
Brz-123
Shouldn't the FA20 headers fit then?
Sent from my ONEPLUS A5010 using Tapatalk
Yes they should. Its also stated in one of the posts above. Change to intake side slightly , not to exhaust. I think even Mike at CSG is saying that in his new brz thread
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 11-06-2021, 11:33 AM   #44
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
OP is using the FA20 cylinder heads anyways, so FA20 headers will almost guaranteed work. Will they be optimized? Probably not.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following User Says Thank You to Goingnowherefast For This Useful Post:
sato (11-09-2021)
Old 11-06-2021, 11:56 AM   #45
Brz-123
It is an experiment for sure but not a random one as the OP has put the gaskets on top of each other and verified oiling lines etc. How optimised or not with a minor change, the results of this will tell. We are all keenly watching as this is the first!
The Following User Says Thank You to Brz-123 For This Useful Post:
Goingnowherefast (11-06-2021)
Old 11-07-2021, 10:17 AM   #46
soundman98
ProCrastinationConsultant
soundman98's Avatar
sato (11-09-2021)
Old 11-07-2021, 12:48 PM   #47
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
The question here is will it use the same CPS (crank position sensor). That's another critical sensor you'll need to determine engine position. If it is different, it may be possible to swap the gen 1 sensor in.
Per the documentation, it's in the same location.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 11-07-2021, 02:03 PM   #48
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Redline is 6000k. Normally turbocharged. Designed for torque. Lower compression. It's interesting, but is it really going to have more power if not turboed?
Old 11-07-2021, 02:15 PM   #49
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This is the 22’ BRZ short block he bought. Not the turbo Acent/Crosstrek engine.
The Following 7 Users Say Thank You to NoHaveMSG For This Useful Post:
BrahmaBull1990 (11-08-2021), EAGLE5 (11-07-2021), Goingnowherefast (11-07-2021), kevaughan (01-07-2022), Opie (11-08-2021), PulsarBeeerz (11-07-2021), soundman98 (11-07-2021)
Old 11-07-2021, 03:21 PM   #50
Lantanafrs2
Drives: 2013 frs red
The fa20 heads seemed to flow more than needed so maybe they'll be dead nuts for the larger displacement?
Lantanafrs2 is offline   Reply With Quote
Old 11-07-2021, 04:32 PM   #51
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Excited to see how this build goes!
Is the plan to machine the heads to match the larger bore, or...?
Tatsu333 is offline   Reply With Quote
Old 11-07-2021, 04:41 PM   #52
Goingnowherefast
I'll let OP comment but that's usually not needed. No one does it on the really popular K20/K24 hybrid. It's a good example, because it's 2.0L heads with a overbored 2.4L crankcase.
The Following 2 Users Say Thank You to Goingnowherefast For This Useful Post:
BrahmaBull1990 (11-08-2021), soundman98 (11-07-2021)
Old 11-07-2021, 05:44 PM   #53
Tatsu333
This is not *quite* the same as K20 / K24, since the difference in bore between those two motors is only 1 mm (most of the displacement difference there is with a jump from 86mm stroke to 99mm), while the difference between the FA20 and FA24 bore is 8 mm (from 86mm to 94mm) while the stroke stays the same.
That would mean a substantial amount of extra material sitting around the top of the bore, which at the very least would be sub-optimal for combustion, if not downright problematic.
This is closer in concept to an EJ20 / EJ25 combo - I haven't really looked into what they do with those, but I'd be surprised if the heads are untouched with a 7.5mm increase in bore.
EDIT: I looked into the EJ20 / EJ25 combo, and to do it properly, it seems they either machine the heads to enlarge the combustion chambers or use custom pistons to bring the compression ratio back down. Otherwise C/R is too high. That said, some folks DO run it without either...
EDIT 2: Running some quick rough numbers, the combustion chamber volume for an FA24 is 19.47% larger than the FA20's, so with the FA20's combustion chamber volume unmodified that would make the hybrid's C/R about 13.74:1. That is a BIG jump that would be hard to tune for.
The stepped shape at the top of the bore would also make for some funky swirl of the mixture as it compresses, and could create some major heat risers that would trigger detonation. With all that considered, I don't think it would be a great idea to run it without machining the heads to match...
The Following User Says Thank You to Tatsu333 For This Useful Post:
alphasaur (11-07-2021)
Old 11-07-2021, 06:34 PM   #54
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Machining the head seems necessary. The pistons could cause interference with the lip of the head, and if the lip of the heads are sharp then they could be a location for preignition, or at best, they could cause weird tumbling of air coming into the cylinder. Personally, I feel like getting the heads machined was already a given.
Old 11-07-2021, 07:07 PM   #55
Tatsu333
That's kind of what I was thinking, but it seems some folks have done the EJ20 heads on EJ25 block combo without it.
Old 11-07-2021, 08:49 PM   #56
Irace86.2.0
That's kind of whatI was thinking, but it seems some folks have done the EJ20 heads on EJ25 block combo without it.
The EJ is a low compression motor. What do the pistons look like? They are recessed.
The FA20/24D has domed pistons to create the high compression. Here are some pictures of my blown engine. The piston height is visible from the side, and the piston in the background shows a piston close to TDC with a dome shape and impedance reliefs in the crown for valves. I’m sure if someone wants to throw some low compression pistons in there then there is no risk of any issues. If Toyobaru changed the valve angle or valve opening height to make it open higher or enlarged the valves then that could cause interference, depending on the tolerances. Regardless, the edge of the cylinder-head combustion-chamber probably will interfere with the crown of the piston without machining.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Tatsu333 (11-08-2021)
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 12:33 AM
