Old 11-05-2021, 04:44 PM   #29
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by redlined600 View Post
I guess I'll be the first to ask, how much for the short-block?
https://parts.subaru.com/a/Subaru_20...11-001-02.html
The Following 4 Users Say Thank You to Irace86.2.0 For This Useful Post:
redlined600 (11-05-2021), RedReplicant (11-13-2021), soundman98 (11-07-2021), Teseo (12-16-2022)
Old 11-05-2021, 05:29 PM   #30
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
That's actually really reasonable
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following User Says Thank You to Goingnowherefast For This Useful Post:
Lantanafrs2 (11-07-2021)
Old 11-05-2021, 05:40 PM   #31
alphasaur
friendly
Drives: 17' 86
A bargain compared to alternatives.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
Old 11-05-2021, 06:12 PM   #32
ermax
ermax's Avatar
So it’s basically the same price as the FA20 short block. I got FA20 short block through a friend at a dealer for around 1800. I suspect the FA24 could be had for similar discounts if you know the right person.
The Following 3 Users Say Thank You to ermax For This Useful Post:
Opie (11-05-2021), soundman98 (11-07-2021), Teseo (12-16-2022)
Old 11-05-2021, 06:53 PM   #33
FrickingReallySlow
Drives: 2015 FR-S
Curious about @Opie plan for the heads to get compression back to 12.5 The FA20 heads will actually introduce a quench/squish area when paired with bigger bore of FA24 (which I guess can be desirable for velocity and mixturing). Probably also need a head CC kit to get compressed volume even across all 4 heads if material is taken out.
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
Opie (11-05-2021)
Old 11-05-2021, 07:25 PM   #34
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Surprisingly so. Probably looking at three grand once you account for the ancillaries. Then what else do you need?
-Header, if you're still stock?
-Tune? Which might become available off-the-shelf in the not-too-distant future
If that works out, it might yield 250 OEM-like hp for the price of a decent supercharger. N/A, with a "new" engine, higher reliability and less weight.
Speaking of which, interested in seeing the weight penalty between FA24 & FA20 short blocks. Probably less than an FI kit anyway.
alex87f is offline   Reply With Quote
Old 11-05-2021, 07:45 PM   #35
ermax
ermax's Avatar
I doubt it’s much more. I guess the steel sleeves are larger but could that really add up that much?
Old 11-05-2021, 08:26 PM   #36
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by BrahmaBull1990 View Post
This was my biggest concern. I have an Edelbrock and it is going to be tough if it doesn’t match up. I suppose I could sell my FA20 Edelbrock to finance the FA24 short block and machining, then add another PD SC down the road.
Decisions, decisions….
@Opie Are you considering the upgraded transmission, too?
Not until/unless the current one breaks
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
BrahmaBull1990 (11-06-2021)
Old 11-05-2021, 08:55 PM   #37
Ashikabi
Ashikabi's Avatar
I'm gonna assume the weight penalty is approximately one large dump after taco night.
Sent from my ONEPLUS A5010 using Tapatalk
The Following 3 Users Say Thank You to Ashikabi For This Useful Post:
alex87f (11-06-2021), NoHaveMSG (11-06-2021), soundman98 (11-07-2021)
Old 11-06-2021, 04:40 AM   #38
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Is it not the FA24 short-block longer? Hope you don't have clearance issues.
Old 11-06-2021, 10:01 AM   #39
Goingnowherefast
No. It should be the exact same size externally.
The Following 2 Users Say Thank You to Goingnowherefast For This Useful Post:
nikitopo (11-06-2021), Opie (11-06-2021)
Old 11-06-2021, 10:15 AM   #40
Brz-123
It has the same casting and same stroke , no change. Only bored wider.
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
The Following 4 Users Say Thank You to Brz-123 For This Useful Post:
Goingnowherefast (11-06-2021), nikitopo (11-06-2021), Opie (11-06-2021), Teseo (12-16-2022)
Old 11-06-2021, 10:18 AM   #41
Goingnowherefast
The question here is will it use the same CPS (crank position sensor). That's another critical sensor you'll need to determine engine position. If it is different, it may be possible to swap the gen 1 sensor in.
Old 11-06-2021, 10:35 AM   #42
Ashikabi
Ashikabi's Avatar
Shouldn't the FA20 headers fit then?
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 12:33 AM
