#15 | |
Master Collaborator
Answer #1) check out Williston Audio Labs YouTube channel here: https://m.youtube.com/c/bigdwiz/videos Big D's main topic is amplifier dynos and he usually shows you the purchase price of the amp that he's testing. He's done A LOT of them, so be prepared to spend some time watching. Right off the top of my head though, I can't think of an amp for $100 that will compliment the Audio Control amp that you've already got. You would probably need between 300 to 500 watts RMS of subwoofer power to match your other speakers. Answer #2) There are so many speaker manufacturers out there, I'm sure you should be able to find a coaxial that will work in the rear. However, I would suggest not purchasing a coaxial but rather a midrange-only driver. Let your front Sony separates create your front stage and let the rears be your rear fill. The front speakers are the most important. Here's a suggestion, amplify the stock rear speakers for the time being, get them time aligned and equalized through the Audio Control DSP amp, THEN if you don't like how it sounds, or if they can't keep up with your Sony's, find a replacement. I will end this answer with a question: When you go to a concert, do you stand and listen with your back to the band? |
| The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post: | blueskiesgreenlights (12-08-2021), soundman98 (11-04-2021) |
#16 | |
Drives: 2020 86
This will likely be what I end up doing. So far, I've fabricated a mount for the D-12.000, confirmed that the Basser box fits and can be secured as alphasaur instructed. |
#17 | |
Drives: 2020 86
I purchased an installer kit that has a 4 awg power line. I was planning on powering the sub amp by serially linking it to the amp at the trunk. Is a 4 awg wire sufficient for this? If not, what size power wire would be appropriate? I wasn't aware of power splitters. I'll look for one with a fuse. |
#18 | |
Drives: 2020 86
This is a great idea. I'll plan to to secure the sub amp under the passenger's seat and route the right and left speakers down the center console. Last edited by blueskiesgreenlights; 11-04-2021 at 07:20 PM. |
#19 | |
Drives: 2020 86
I had never heard of Big D. I will, indeed, spend some time watching his reviews. I noticed he posted one recently on the CT Sounds CT-400.1D. At $119 it looks promising. I had considered a mid range component for the rear speakers. Perhaps I'll give the stock systems a listen in this role as you suggest Thanks! Last edited by blueskiesgreenlights; 11-04-2021 at 08:48 PM. |
#20 | |
Master Collaborator
You're very welcome. But I want to give you one more piece of advice: When looking for power wire for your amplifier, use only oxygen-free copper. Stay FAR AWAY from any of that cheap, crappy, copper clad aluminum (CCA) wire. Here's a video about that: Realize that not only does aluminum carry less current than copper, it also heats up faster and begins to corrode within just a few months of installation (and sometimes weeks depending on the environment it's exposed to). So if your build requires 4 gauge copper, but you install 4 gauge copper clad aluminum instead, that aluminum wire will get hot and you can lose voltage through the wire itself and end up doing some serious damage to not only your amps, but potentially your car. We don't want to see one of our twins get destroyed in a fire due to an attempt by its owner to cheap out on amplifier power wire. Pay for the good stuff now, you'll thank me later. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | soundman98 (11-04-2021) |
#21 | |
ProCrastinationConsultant
^very good call on watching out on CCA. it's crap.
i mostly use knukonceptz wiring, specifically, the 'Kolossus Fleks', as it's one of the few that walks that fine line between being good quality, and cheaper due to a lack of overzealous marketing wank. Quote:
use this handy-dandy chart as a guideline. but if in doubt, run bigger.
| The Following User Says Thank You to soundman98 For This Useful Post: | blueskiesgreenlights (11-14-2021) |
#22 |
Drives: 2020 86
Speaker Input
I'm having a problem with speaker input. The source of the problem is that the speaker wiring system of the 2020 Toyota 86 is not compliant with the E.I.A (Electronics Industry Association) as presented on the back of the Scosche packaging.
Questions: Is it possible to use a Scosche TA02B harness and connect it to the original factory plug that was providing speaker input to the original factory amp? If so, how do I configure the TA02B harness? I attempted to do this and the result was that the Green and Violet wires are on a separate 4 pin TA02B plug. Consequently, I decided to follow FR-S2GT86 advice and use the wires attached to the head unit to provide speaker input for the AudioControl d-6.1200. The problem I ran into here was that there was no Green wire which according to E.I.A. is used for the left rear speaker. An inspection of the left rear speaker shows a Violet and a Blue wire attached to the left rear speaker. This concerns me because the Blue wire is for the remote amp turn on. I successfully completed FR-S2GT86's "Magnuson-Moss" Version. My recollection is that this allowed for the factory amp to power the door speakers. So that is the current state of the head unit. The Good News is that a 0/1 awg power cable has been acquired. The AudioControl amp, a sub amp, the Sony speaker crossovers, external fuses, and a power block have been mounted to secure shelf in the trunk. A Rockford Fosgate sub has been installed in a Basser Box in the right trunk cavity. The Sony XS 162ES speaker system has been successfully installed. I'm confident that the speaker output is configured correctly. The only holdups now are the above speaker input issue and the delivery of 0/1 ring terminals. I'm considering a D.I.Y. post of this project for non-professionals interested in upgrading the 86 multi media system. Of course, this will depend on a successful completion of this endeavor. Any help on this speaker input issue would be greatly appreciated. |
#23 |
to my knowledge, no vehicle-side wiring from any mfg is EIA compliant.
that's part of the reason to use the adapter harness with a standardized color code and labels(when installing an aftermarket stereo, the aftermarket stereo colors will line up), though the best reason is to maintain the oem plugs to allow easy conversions/adaptations later, and use the adapter as a sacrificial wire loom--it's cheap and easy to aquire should something need to be changed later. yes, as per previous outlines, the toyota speaker adapter harness will connect into the amp harness. but the significant difference is that the 'front speaker' terminals serve as the 'input from radio', and the 'rear speaker' terminals serve as the 'output to door speakers' forewarning, there's no way to maintain front/rear fader capability using this method.
| The Following User Says Thank You to soundman98 For This Useful Post: | blueskiesgreenlights (11-21-2021) |
#24 |
Drives: 2020 86
Final Phase - Speaker Input
So I plan to use the Magnuson-Moss version ("MM") as a source for speaker input wires (and amp turn on) to the AudioControl ("AC") d-6.1200. The MM will serve as the "sacrificial wire loom" and I'll make the connection at the head unit ("HU") with Positap connectors.
I plan to use these RCA "lollypop" connectors at the AC. My objective in using these connectors is to retain the HU phase control. Before starting the AC for the first time, I'll use the AC usb cord to update the AC firmware. I did invest in 0/1 Kolossus Fleks awg wire to the power block in the trunk at which point 4 awg wire is used to power the AC and sub amp. I did "cheap out" with the sub amp going with the Blaupunkt 1500W 1-Channel, Monoblock Amp for $55. Does the plan to use the MM as a source for speaker input seem reasonable? Thanks in advance. |
#25 |
the d-6.1200 has rca low-level inputs only, so those rca converters won't work. you need to connect the speaker level wires to the 'line level' plugs just to the right of the 'line level' inputs.
| The Following User Says Thank You to soundman98 For This Useful Post: | blueskiesgreenlights (11-29-2021) |
#26 |
Drives: 2020 86
Installation Complete but Sound Issue
Per Soundman98's suggestion, I ditched the RCA converters and tapped into the HU wires for connection to the AudioControl D-6.1200's ("AC") speaker level inputs.
The problem is that I am not getting any sound from the Right and Left front speakers (Sony tweeters in the dash and Sony woofers in the doors). I used the Magnuson-Moss ("MM") white and gray wires (and line for negatives) as tap in points to connect to the AC speaker level inputs. Both the AC and subwoofer amp power on. The only sound is low volume from the left and right rear speakers. These speakers were id'd using the Ohm setting on a digital multi-meter. Can the MM serve as speaker level out of HU or is the sound issue elsewhere? |
#27 |
Drives: 2020 86
To answer my own question, yes, the MM can be used to access speaker level output for the left and right front speakers. For the 2020 86s AC LGD dongles, discussed below, are necessary.
As I stated earlier, the rear speakers are a little more difficult to access as they require one to use a digital multi meter to identify wires from the rear speakers to the head unit. These wires appear as different colors from rear speakers to HU (perhaps they merge with other wires). AudioControl ("AC") tech support was very helpful in resolving the sound problem. They advised that I reposition the front speaker input from that outlined in the AC instruction booklet. This and by remotely operating the AC windows software (which was connected to the d-6.1200 via usb cable) the device was configured in such a way as to allow sound from all speakers. Importantly, AC advised that many late model cars have stereo systems which somehow prevent a full level sound signal to be sent to non-factory speakers. AC is sending a set of LGD dongles designed to correct this problem. If there is an interest, I'd be glad to post a DIY guide. Once the LGD dongles have arrived and the sound is impressive as I expect it to be I'd be willing to do so. Now, if I can just get the reverse camera to display on the primary screen instead of the rear view mirror. I haven't yet found this listed on the DIY wish list though I suspect it is there. I'd like to express my gratitude to Soundman98. Thank you for your patient guidance. Also, FR-S2GT86 and Laura at AC - your contributions to this effort have been invaluable. |
| The Following 2 Users Say Thank You to blueskiesgreenlights For This Useful Post: | FR-S2GT86 (12-05-2021), soundman98 (12-08-2021) |
#28 |
It's sure on my wish list. I expect in the spring I'll get around to the stereo work (currently on jackstands for more suspension mods). Is there a wish list post I missed?
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
| Tags |
| sound deadening, stereo upgrade, stock amp |
| 2020 86 Stereo Info | Bobharp | Electronics | Audio | NAV | Infotainment | 228 | 09-20-2024 12:33 AM |
| 2020 vs. 2022 BRZ specs | MJones_RB | BRZ Second-Gen (2022+) — General Topics | 42 | 04-27-2021 09:25 AM |
| Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo | dssence | Electronics | Audio | NAV | Infotainment | 0 | 01-27-2015 06:43 PM |
| Stereo Upgrade | avig | New England | 0 | 04-05-2013 12:21 AM |
| 8 Speaker stereo specs? | Rstalter77 | BRZ First-Gen (2012+) — General Topics | 56 | 04-24-2012 04:43 AM |
