Old 11-03-2021, 10:42 AM   #29
radroach
Drives: car
@lapsio When I'm trying to get into 1st quickly, say I roll to a stoplight at 1-5 mph, I press the gear lever towards 1st gear two times. The first time you try, it won't go in but you might feel it slow down the counter shaft. Press it into gear the second time and it should go in.
Another mention is that improving my driveline mounts (whiteline inserts) down the entire line, and then adjusting my clutch engagement point fixed most of my shifting issues.
Old 11-03-2021, 06:44 PM   #30
Leaning on the gearshift for any length of time causes undue wear on the contact surfaces of the shift fork as the syncro collar spins inside it. How much? Meh... might find out after 100 Kmi. It's probably just fine but from a best-practice standpoint, it's better to double-clutch into first on a roll. Done properly, no force required. Will actually feel like an upshift.
Last edited by Ultramaroon; 11-07-2021 at 04:29 PM. Reason: nomenclature: shift was clutch
Old 11-04-2021, 02:36 AM   #31
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Leaning on the gearshift for any length of time causes undue wear on the contact surfaces of the clutch fork as the syncro collar spins inside it. How much? Meh... might find out after 100 Kmi. It's probably just fine but from a best-practice standpoint, it's better to double-clutch into first on a roll. Done properly, no force required. Will actually feel like an upshift.
150k miles and still goin strong in my car. As with any, Subaru it's just a luck of the draw
villainous_frx is offline   Reply With Quote
Old 11-04-2021, 01:29 PM   #32
Nature vs nurture. Some are built/designed more stoutly than others but anything can be rekt.
Best practices are best.
Old 11-04-2021, 04:27 PM   #33
And it had 120K without ever seeing a double clutch shift.
Old 11-04-2021, 05:57 PM   #34
What's your point?
Old 11-04-2021, 06:02 PM   #35
What's your point?
That they can stand up fine without double clutching.
Old 11-04-2021, 06:07 PM   #36
Yup. Never said that they couldn't.
Old 11-04-2021, 06:47 PM   #37
villainous_frx
Off to the track!
Car eats throwout bearings though, I swear I heard some squeaking as I loaded it onto the tow truck :/.
Transmission and diff drain plugs both come out with minimal if any metal on it, and the fluid still looks good enough for street use.
Old 11-04-2021, 08:13 PM   #38
PenGun
Drives: Red 2019 Subaru BRZ
I double clutch every downshift. I don't think about it, its how you do that.
You can do all kinds of things that won't kill the car, but should you???
PenGun is offline   Reply With Quote
Old 11-04-2021, 08:17 PM   #39
_sigh_ Southern Canadians
Old 11-04-2021, 08:30 PM   #40
It doesn't need a double clutch. It isn't a 1950 Willys Jeep.
Old 11-04-2021, 08:32 PM   #41
See I knew it was coming from somebody!
Remember there are people that think a certain movie is a driving documentary.
Old 11-04-2021, 08:39 PM   #42
villainous_frx
Off to the track!
Is it not?
Cold Air Intake on Edelbrock Supercharger for extra whine TokyoDrift Forced Induction 9 07-09-2023 04:14 PM
2018 cold shifting konahic BRZ First-Gen (2012+) — General Topics 29 02-28-2020 05:09 PM
Transmission shifting when cold? jpilone Engine, Exhaust, Transmission 112 02-22-2018 03:48 AM
Down shifting into 2nd gear when cold Flame9020 Issues | Warranty | Recalls / TSB 27 12-22-2016 04:24 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 02:22 PM
