Old 07-26-2012, 06:10 PM   #43
reeves
Originally Posted by FRiSson View Post
The fact is that EPA mileage estimation is imperfect...
Again, if you check the available data anearly pattern seems to be emerging that AT and MT transmission FRZ's get about the same mpg.
^^This
The real world MPG's between AT & MT on this car is closer than the EPA "estimates".
Old 07-26-2012, 09:40 PM   #44
Lytheum
Drives: 2013 BRZ Premium 6MT
brz mt here...best tank so far came out to 31.5mpg. had 3 that came out to close to 30.5. i think my lowest so far was 29.5. usually drive 70-75% highway. i dont drive crazy but dont baby it either.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 07-30-2012, 11:12 AM   #45
kramerica_industries
kramerica_industries's Avatar
Drives: 2013 Ultramarine FR-S
I took a trip from Chicago to Iron Mountain, Michigan and back this weekend. Mostly highway driving (65-75 mph) with some slowdowns for construction and traffic. Posting a pic of my two+ tank trip avg. mpg upon return to Chicago. I was blown away. And I have the MT!Name:  ImageUploadedByTapatalk1343657517.820650.jpg
kramerica_industries is offline   Reply With Quote
The Following User Says Thank You to kramerica_industries For This Useful Post:
SuperDave (08-02-2012)
Old 07-30-2012, 03:25 PM   #46
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Originally Posted by 4thehorde4 View Post
If there is no performance or fuel efficient reason to get manual, whats the point anymore?
The manual does accelerate faster and launch better, so there is definitely a performance difference.
You can get really good fuel economy on the manual, but you have to be willing to drive 75 or less and use very gentle throttle inputs. let it loose a little speed on upslopes and slowly gain it back on downslopes. When you press the gas just gently feed into it. Better still run at 72 MPH or less - it seems MUCH easier to keep the fuel economy good in that range. Also turning on your gear and shift suggestion indicators will help you stay efficient on acceleration, and watching the instantaneous MPG will do the same.
Speed for speed the auto will always win at fuel economy due to the gearing advantage, but I've gotten up to 34 MPG average on highway trips and 44 MPG average on rural roads (40-60) in my manual. For a car that performs like the FRS does that is astoundingly good IMO.
Boosted2.0 is offline   Reply With Quote
Old 07-30-2012, 03:28 PM   #47
Boosted2.0
Boosted2.0's Avatar
Originally Posted by kramerica_industries View Post
I took a trip from Chicago to Iron Mountain, Michigan and back this weekend. Mostly highway driving (65-75 mph) with some slowdowns for construction and traffic. Posting a pic of my two+ tank trip avg. mpg upon return to Chicago. I was blown away. And I have the MT!Attachment 11541
Thats fantastic! I have noticed the same trend. Ever since the motor got broken in I have neeb able to get mid 34s at about 75 and I can get better when I go slower.
The Following User Says Thank You to Boosted2.0 For This Useful Post:
kramerica_industries (07-30-2012)
Old 07-30-2012, 05:00 PM   #48
JTM
Drives: 2013 FRS-6MT Argento
Originally Posted by hav0c View Post
Depending on how much you drive, and where gas prices go, the AT will pay for itself within a couple years. I plan on keeping mine much longer than that.
How much is a new clutch? Depending on the mfg. a new clutch could be as cheap as $50 or as expensive $300. Most kits <clutch, throw out, pilot, and pressure plate> fall in the $100 to $500 range.
How often do those need to be replaced in these cars? Someone who races will have to correct me, but in our offroad rigs we typically see 60-100k miles on a clutch. In a street car like this, you should see 100-200k miles before you need to replace a clutch if you don't race. For refrence a torque converter will typically fail in the same mileage range for the same level of abuse.
I see a lot of folks for whom this will be their first MT and I'm sure that's going to result in a lot of additional wear/tear on the transmission. It will result in more wear on the clutch, and if they jam gears it will result in more wear on the trans. However, your average street racer wannabe will be doing more damage to his auto trans by constantly going WOT and unlocking the torque converter.
Automatic transmissions do fail, and it can be expensive, but in my experience they last a lot longer and have fewer problems than most of the manuals owned by friends. This says more about the people you hang out with than the typical failure rate of a trans. In some cases you can buy a new manual trans for what it costs to rebuild an auto. In most cases a Manual transmission will out last an auto, and is likely to only need basic mantaince and consumeable parts for the life of the car.
This setup in particular seems pretty beefy and capable of handling more power than the car can put out in stock form. Aisan transmissions have been around for a long time, my offroad rig is still sporting the original Aisan Warner automatic that it rolled off the assemble line with in 1988, it needs some love and a new torque converter but it still gets me throught the rock garden at my favorite offroad park.
My last MT was bought used but having to spend 20% of the price of the car to swap the clutch after a couple months due to wear from the previous owner did not make me happy.
I answered your question in green. With the lay out of this car, replacing a clutch should be as simple as any other RWD front engine car.
JTM is offline   Reply With Quote
The Following User Says Thank You to JTM For This Useful Post:
Bonburner (08-02-2012)
Old 08-01-2012, 11:59 PM   #49
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Two all highway trips(still in break-in) today with FRS-AT:
1) Speed range: 5% city, 97% 100-110kph: 396.5km:6.6L/100km (35.7 mpusg)
2) Speed range: 1% city, 99% 90-110kph: 316.5km: 5.7 L/100km (41.3 mpusg)
91 AKI fuel
Just cruising!:happy0180:
calculation method: compared amount of fuel added to top-up since last fill and then compare with odometer distance travelled since last fill. It is important to ensure that you attempt to use a consistent top-up method. First cutoff of the fuel nozzle can be deceiving as it can vary with depth the nozzle is inserted, speed of fill, aeration of the fuel, etc. I usually go to first cutoff, wait to let aeration subside, then fill again with same method a few times to get it as full as possible without overflow spilling. Takes some practice!
Last edited by smbrm; 08-02-2012 at 04:23 AM. Reason: followup question regarding calculation method
smbrm is offline   Reply With Quote
Old 08-02-2012, 01:30 AM   #50
roddy
roddy's Avatar
Drives: '13 Ultramarine
My car is a manual. I have a 35 min drive to work. About 3/4 of the drive is two lane country blacktop with an 80 kph (50 mph) "limit", and 1/4 of it is in town stuff. I don't exactly take it easy and still average 33 mpg.
Old 08-02-2012, 03:20 AM   #51
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I'm getting 28.8 mixed on my MT.
Old 08-02-2012, 03:42 AM   #52
Buggy51
Drives: Put Put
Out of curiosity, how is everyone actually calculating their MPG?
Based on however many miles they driven and calculated by hand by comparing what you just filled in the gas station? Or what?
I'm not too fond of trusting the onboard computer
Buggy51 is offline   Reply With Quote
The Following User Says Thank You to Buggy51 For This Useful Post:
mit_peid (12-09-2012)
Old 08-02-2012, 03:53 AM   #53
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I've gotten ~23 mpg .. granted I drive a bit harder than most but usually keep it under 4k, never past 5k.
computer says 25 though.
Calc by the 1st fill up mileage and then at second fill up find the difference in the odo and how much gas i've filled until full
Old 08-02-2012, 04:26 AM   #54
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
I've been trusting the computer but I believe the last time I checked it was pretty spot on. I remember filling 10.9 gallons and the odometer said something around 300 miles, so that'd be the ~27.5mpg I've been getting. MT and I have definitely not been babying it... ahem.
eriktherod is offline   Reply With Quote
Old 08-02-2012, 06:53 AM   #55
lokvo
Pugilist
lokvo's Avatar
Drives: GT 86 - Hot Lava (AUS Spec)
Because it signifies that ur a man. I kid, I kid.
"BOO FOR THE GOO" - Everyone
http://www.ft86club.com/forums/image.php?type=sigpic&userid=14259&dateline=134355  2296
lokvo is offline   Reply With Quote
Old 08-02-2012, 09:25 AM   #56
KRAZYK
Self Entitled
KRAZYK's Avatar
Drives: 13' Red FR-S, 12' Toyota Tundra
Everyone SHOULD be hand calculating.. reset trip every fill up and then divide your trip miles by how much fuel is needed to fill up. Although I will say, my computer was dead on when I filled up for the first time.. 26.5 mpg. (MT)
KRAZYK is offline   Reply With Quote
Any official 0-60 times between auto and manual? evicfinite Scion FR-S / Toyota 86 GT86 General Forum 123 03-27-2018 04:18 PM
Are you getting Manual or Auto? denverizzles Scion FR-S / Toyota 86 GT86 General Forum 134 08-15-2013 11:55 AM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 12:33 PM
Manual or Auto? StevenDavisPhoto Engine, Exhaust, Transmission 23 03-30-2012 06:58 AM
