Old 10-29-2021, 09:45 AM   #15
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Kurochan View Post
Would you say the 86 is less capable than the S on equal mods? I dont want to downgrade even if it means its a lot easier to drive.
Yea I miss having a coupe, the S feels claustrophobic with the top up
Mod vs. mod, I think the S2000 is going to come out on top in terms of outright performance. I mean, same weight with +30 more hp and much better weight distribution, it has some pretty significant advantages...
But with a few relatively minor mods, my BRZ KILLS what my stock S2000 would do at the track. I mean KILLS it, by a couple/few to several *seconds*. And again the driving position and steering feel in the BRZ is WAY better. And fixed roof And you can fit a fair amount of stuff in it.
I don't think you'll be disappointed if you make the move, I'm not.
alphasaur (10-29-2021)
Old 10-29-2021, 09:52 AM   #16
Kurochan
Drives: RX8
Thats good to know thanks. What kind of mods if you dont mind me asking?
Sent from my SM-N986B using Tapatalk
Kurochan is offline   Reply With Quote
Old 10-29-2021, 10:01 AM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
Camber plates (Raceseng) up front, stock camber isn't nearly enough...
Lowering springs (Swift Spec-R)
Struts/shocks (Bilstein B8), kind of necessary if you both lower the car and run camber plates, stock front struts don't have enough bump travel!
Eibach front/rear swaybars (*way* stiffer than stock)
4-2-1 header (ACE 350) and tune (Zach at CSG)
Obviously there's other ways to get there, I might go to coilovers next year but good lowering springs + Bilsteins makes for a great street/track compromise IMO.
I resorted to header/tune and sways this year because spring/damping rates are kinda soft for serious track usage and I compete in time trials and it was close this year!
Header and tune greatly improved drive from mid-rpm, more so than expected, but top end power not much more vs. stock '17+. Definitely not required.
Old 10-29-2021, 10:12 AM   #18
DarkSunrise
DarkSunrise's Avatar
I've tracked my friend's AP2 at Buttonwillow while instructing him and also driven it many times in the canyons. In terms of speed, an FR-S on e85 tune (2017 OEM header, mishimoto inlet tube, slight weight reduction) is about even 10-90 mph vs. stock AP2. Basically +/- 0.25 carlength. If you don't have e85, a good header and tune should give you about the same gains. Or buy a GR86 which is already 1-2 carlengths faster vs. AP2. The S2000 doesn't have great aero above 70 mph especially top down, which is something I noticed vs. AP1 (80-125 mph at the track).
Handling-wise vs. AP2, it will come down to setup/tires/driver. For whatever reason, my friend's AP2 feels more sensitive to trail-braking in the canyons, but on the track the overall balance is very similar to my FR-S (RCE T2 coilovers, track alignment, pedal dance). AP1 might be different with the bumpsteer. Balance aside, my car is faster than his AP2 in corners, but that's mainly due to tires and setup. Steering feel is better on the FR-S.
Also ergonomics are better in the FR-S. The FR-S seats have more bolstering and are more grippy (cloth vs. leather). The steering wheel extends/tilts. When I drove his AP2 at the track, my knee kept bumping into my bottom hand on the steering wheel in the middle of turns.
Can't really go wrong either way. I'm planning to trade my car in for a GR86. Briefly thought about buying an AP2, but I really enjoy the 86 chassis and a new GR86 seems a much better value vs. used S2000.
2022 BRZ Build
2013 FR-S Build
Old 10-29-2021, 10:13 AM   #19
Kurochan
Drives: RX8
So no power mods, just camber essentially. Thats awesome, were you running 215s?
Why didnt you go with a 4-1 header for top end power?
Old 10-29-2021, 10:20 AM   #20
ZDan
ZDan's Avatar
Drives: '23 BRZ
Oh yeah, forgot, running 17x9 (Titan 7 and Wedsport TC105n) with 245/40-17s and/or 235/45-17s. Might run 225s next year depending on points allocations...
I figured filling in midrange was more important. Only reason I got a header was a friend and competitor got one (friggin arms race). He got a good 4-1 and I got the ACE. He dynoed +5hp more peak but mine made way more midrange. I drove his car at Palmer and the lack of grunt going up the hill from 4-5 was very noticeable. Our max speeds at the end of the straight were the same. I was about 1/2-sec faster in time trials
Old 10-29-2021, 11:28 AM   #21
Ernest72
I think we can say that these two cars as well as the Miata are close enough, that personal taste, likes, feelings etc have more to do with the choice than debating which one is better at this or that. Drive all three, examine your life/needs/wants and go with your gut. You can always sell and buy the other one, or own all three at some point in your life if you are lucky. They are not that expensive on the used market.
The Following User Says Thank You to Ernest72 For This Useful Post:
Old 10-29-2021, 11:33 AM   #22
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
99.9% of people over here will focus fixing the torque dip in middle rev range. There aren't that many to appreciate getting more power the higher they go in rpm. I guess times are changing and with so many turbos almost everywhere people nowadays have different expectations.
Old 10-29-2021, 11:51 AM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
The torque dip never bothered me. Based on recommendations of people who have track experience with both, I went with the more midrangey header option over maximum peak for better performance at the track with a stock engine spinning to 7400-7600. As mentioned, my bud's same-year 86 with similar mods but 4-1 EL header had objectively less drive out of corners and no speed advantage on the straights despite 5 more peak whp.
Another big factor was that a used Ace-350 turned up in the classifieds...
Old 10-29-2021, 12:29 PM   #24
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The torque dip is only a problem if you’re in the wrong gear.
The end
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
EAGLE5 (11-07-2021)
Old 10-29-2021, 09:28 PM   #25
PorscheUnlimited16
Drives: 2016 Porsche Gt4
The s2000 Ap1 & Ap2 is the better sports car out of the box. The motor and transmissions til this day is still considered special. You either like roadsters or you don’t. Get a hardtop otherwise. The 86 is a good entry level sports car and does what it was intended for well but still not special like an s2000 is. One continues to go up in value, the other is a dime a dozen.
PorscheUnlimited16 is offline   Reply With Quote
The Following User Says Thank You to PorscheUnlimited16 For This Useful Post:
nikitopo (10-29-2021)
Old 10-29-2021, 11:56 PM   #26
MrDinkleman
Drives: 2016 Oceanic, "base" model
Originally Posted by beltax90 View Post
Miata Is Always The Solution!
Unless you want a coupe and don't live in Japan.
Oh, and it's Miata Is Always The Answer... Except if you want a coupe...
MrDinkleman is offline   Reply With Quote
The Following User Says Thank You to MrDinkleman For This Useful Post:
Adam_L (11-01-2021)
Old 10-30-2021, 04:48 AM   #27
Kurochan
Drives: RX8
How does an 86 with a header and tune on 98 octane (Europe gas so its probably similar to your 91 octane) compare to an s2000? Mine has a test pipe and is approximately 30kg lighter than a stock S.
Im curious how a header+tune 86 on square 255 compares to a 255 square S2000. Im guessing the S is getting a major beatdown
The reason I'm looking to trade in is not because the S is a bad car, quite the opposite actually. I just really prefer how coupes look and I never really look back at the car when I park it (4 seats dont hurt either, it sucks when you cant take more than 1 friend with you), getting even better handling is the icing on the cake. The trade wont cost me any money
Old 10-30-2021, 04:55 AM   #28
Purist
Purist's Avatar
Drives: Subaru BRZ
The reason I'm looking to trade in is not because the S is a bad car, quite the opposite actually. I just really prefer how coupes look (4 seats dont hurt either, it sucks when you cant take more than 1 friend with you), getting even better handling is the icing on the cake. The trade wont cost me any money
I think you might be overthinking this, dude... You're going to have a lot of difficulty trying to explore every combination and permutation of 86 and S2000.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Frs vs s2000 veuxx FR-S / BRZ vs.... 1384 10-10-2016 09:28 PM
S2000 FS/FT Darnold Cars for Sale/Trade 0 08-29-2014 03:51 PM
BRZ vs 86 vs S2000 Brzetto FR-S / BRZ vs.... 0 05-09-2013 12:54 AM
FR-S vs S2000 vang FR-S / BRZ vs.... 436 09-19-2012 04:52 PM
E36 M3 vs FR-S vs S2000 (for me) RearDrive FR-S / BRZ vs.... 48 07-02-2012 10:46 PM
