Old 10-27-2021, 01:29 PM   #1
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Exhausts with good flow velocity
Going too big in an exhaust diameter is not always optimal. It will decrease the back pressure which is good, but at same time it will decrease the flow velocity which is bad. A good flow velocity aids the complete expulsion of burnt gases and increases the amount of the air-to-fuel mixture being drawn into the combustion chamber. When exhaust gases exit the engine with a higher flow velocity, they create low pressure behind them. This low pressure continues to suck out exhaust gases at an extremely high rate, creating a valuable cycle.
An example of such exhausts is the family of the STI performance mufflers:
Are you aware of any other exhausts that decrease the back pressure and at same time have a good flow velocity (e.g., by keeping the stock exhaust diameter size)?
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
Dirty Harry (10-28-2021), humfrz (10-27-2021)
Old 10-27-2021, 01:30 PM   #2
Ashikabi
Ashikabi's Avatar
Anything aftermarket that isn't 3 inch should do you just fine. 3 inch of almost certainly too big but I don't have Dyno results to back that up
Sent from my ONEPLUS A5010 using Tapatalk
Old 10-27-2021, 01:48 PM   #3
Originally Posted by nikitopo View Post
Going too big in an exhaust diameter is not always optimal. ..........
NOW ...... you tell me!
humfrz is online now   Reply With Quote
The Following 5 Users Say Thank You to humfrz For This Useful Post:
flippy (10-29-2021), Jdmjunkie (10-27-2021), nikitopo (10-28-2021), norcalpb (10-27-2021), soundman98 (10-28-2021)
Old 10-27-2021, 10:28 PM   #4
PulsarBeeerz
Drives: JRSC BRZ SOLD
You are only paying for noise with an axle back. There aren't any performance benefits so just choose whatever floats your fancy. If it is a cat-back on an otherwise stock car a few JDM manufactures make 60mm cat-backs. But once again there is no performance benefit. Just money spent and noise.
PulsarBeeerz is offline   Reply With Quote
Old 10-27-2021, 11:59 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Old 10-28-2021, 02:23 AM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Here is a dyno graph showing how power is affected if you go with a 3" full exhaust. Peak power in stock exhaust is around 6800-7000 rpm, while peak power in bigger exhaust falls into the 6300-6500 rpm cause of the worse flow velocity even though it is used a less restricted air filter. Overall gains are irrelevant here, because Stages 1.1-1.3 have a more aggressive tune and Stages 1.2-1.3 a sport cat and catless header.
Old 10-28-2021, 02:23 AM   #7
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
This is a false perception from the first years, because the engine was new and there wasn't much R&D. For example, the STI performance muffler was made available in '16. Before they were selling the STI sports muffler without any improvement in back pressure and as you mentioned with a change just in sound.
Old 10-28-2021, 02:34 AM   #8
PulsarBeeerz
No, thinking that changing the last 3ft of exhaust will make an appreciable performance difference is just silly at this point. Just admit you want a different noise out of the car. There is nothing wrong with that. You will never notice the 1-3bhp you think you are gaining.
Old 10-28-2021, 03:17 AM   #9
SydBRZ
SydBRZ's Avatar
Drives: MY14 BRZ, MY06 WRX
NA wise, your header will be the main area where flow velocity will play a role. The remaining exhaust system will only play a small role, assuming you don't choose a massive pipe diameter.
The flow velocity of the exhaust system behind the header, all the way back to the rear muffler, will be more critical in forced induction applications.
SydBRZ is offline   Reply With Quote
Old 10-28-2021, 06:59 AM   #10
Ashikabi
Ashikabi's Avatar
I assume manifold is referring to the header. That's a very interesting Dyno chart since I've always been under the impression that the cat back was not very valuable for power and most is gained through the header. This chart seems to indicate otherwise
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 10-28-2021, 07:58 AM   #11
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The OEM catback is quite restrictive with high back pressure. Most gains of a bigger catback are coming by advancing ignition timing.
Old 10-28-2021, 08:16 AM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
In short, I don't believe those plots. NObody's *really* gaining real-world +20 hp with a catback and "more aggressive tune" vs. stock on any year FT86...
Regarding "good flow velocity", it's a bit of a myth... From what I've seen on 150rwhp 2.4 liter ITS 240Z dynos, bigger exhaust always helped but going from 2.5" to 3" was a small, almost negligible gain, point of diminishing returns.
You could run a 1" catback and get massive gains in "flow velocity" and if you measured at a static pressure port in that 1" section it would show low pressure due to Bernoulli. However you will have lost power due to increased pressure upstream...
jflogerzi (10-30-2021)
Old 10-28-2021, 08:19 AM   #13
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
The HKS Hi Power Spec L claims to improve low end torque and horsepower. I have to say that compared to my last catback, Q300, the car did feel lighter after installation, I was able to develop lower speeds slightly faster and going from 65MPH to 80MPH feels easier. I did have JDL UEL headers while having both exhausts. It just "felt" better with the HKS one.
spcmafia is offline   Reply With Quote
Old 10-28-2021, 09:40 AM   #14
alphasaur
friendly
Drives: 17' 86
I think the spec L just sounds good down low so it feels faster. Spec L gang
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
WTB: OEM Mass Air Flow Sensor/Meter Assembly Air Flow Sensor driftking96 Want-To-Buy Requests 0 02-16-2016 03:57 AM
Velocity orange gts 86 bomexq FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 03-07-2014 04:32 AM
Does anyone know of a good local shop that can even out exhausts? Darryljr11 Mid-Atlantic 13 02-20-2013 10:15 PM
Velocity: Fifth Gear FR-S DBacon1052 Scion FR-S / Toyota 86 GT86 General Forum 2 10-23-2012 10:11 AM
Motorweek 7/24/12, 8pm EST on Velocity No Quarter Scion FR-S / Toyota 86 GT86 General Forum 5 07-25-2012 01:50 PM
