Drives: '15 BRZ RA
Exhausts with good flow velocity
Going too big in an exhaust diameter is not always optimal. It will decrease the back pressure which is good, but at same time it will decrease the flow velocity which is bad. A good flow velocity aids the complete expulsion of burnt gases and increases the amount of the air-to-fuel mixture being drawn into the combustion chamber. When exhaust gases exit the engine with a higher flow velocity, they create low pressure behind them. This low pressure continues to suck out exhaust gases at an extremely high rate, creating a valuable cycle.
An example of such exhausts is the family of the STI performance mufflers: ![]() Are you aware of any other exhausts that decrease the back pressure and at same time have a good flow velocity (e.g., by keeping the stock exhaust diameter size)? |
| The Following 2 Users Say Thank You to nikitopo For This Useful Post: | Dirty Harry (10-28-2021), humfrz (10-27-2021) |
#2 |
Anything aftermarket that isn't 3 inch should do you just fine. 3 inch of almost certainly too big but I don't have Dyno results to back that up
Sent from my ONEPLUS A5010 using Tapatalk |
#3 | |
| The Following 5 Users Say Thank You to humfrz For This Useful Post: | flippy (10-29-2021), Jdmjunkie (10-27-2021), nikitopo (10-28-2021), norcalpb (10-27-2021), soundman98 (10-28-2021) |
#4 |
Drives: JRSC BRZ SOLD
You are only paying for noise with an axle back. There aren't any performance benefits so just choose whatever floats your fancy. If it is a cat-back on an otherwise stock car a few JDM manufactures make 60mm cat-backs. But once again there is no performance benefit. Just money spent and noise.
#5 |
Wheels for Brains
| The Following User Says Thank You to EndlessAzure For This Useful Post: | nikitopo (10-28-2021) |
#6 |
Drives: '15 BRZ RA
Here is a dyno graph showing how power is affected if you go with a 3" full exhaust. Peak power in stock exhaust is around 6800-7000 rpm, while peak power in bigger exhaust falls into the 6300-6500 rpm cause of the worse flow velocity even though it is used a less restricted air filter. Overall gains are irrelevant here, because Stages 1.1-1.3 have a more aggressive tune and Stages 1.2-1.3 a sport cat and catless header.
#7 | |
Drives: '15 BRZ RA
#8 | |
#9 |
Drives: MY14 BRZ, MY06 WRX
NA wise, your header will be the main area where flow velocity will play a role. The remaining exhaust system will only play a small role, assuming you don't choose a massive pipe diameter.
The flow velocity of the exhaust system behind the header, all the way back to the rear muffler, will be more critical in forced induction applications. |
#10 | |
| The Following User Says Thank You to Ashikabi For This Useful Post: | nikitopo (10-28-2021) |
#11 |
Drives: '15 BRZ RA
The OEM catback is quite restrictive with high back pressure. Most gains of a bigger catback are coming by advancing ignition timing.
#12 |
Drives: '23 BRZ
In short, I don't believe those plots. NObody's *really* gaining real-world +20 hp with a catback and "more aggressive tune" vs. stock on any year FT86...
Regarding "good flow velocity", it's a bit of a myth... From what I've seen on 150rwhp 2.4 liter ITS 240Z dynos, bigger exhaust always helped but going from 2.5" to 3" was a small, almost negligible gain, point of diminishing returns. You could run a 1" catback and get massive gains in "flow velocity" and if you measured at a static pressure port in that 1" section it would show low pressure due to Bernoulli. However you will have lost power due to increased pressure upstream... |
| The Following User Says Thank You to ZDan For This Useful Post: | jflogerzi (10-30-2021) |
#13 |
Drives: 2018 Subaru BRZ
The HKS Hi Power Spec L claims to improve low end torque and horsepower. I have to say that compared to my last catback, Q300, the car did feel lighter after installation, I was able to develop lower speeds slightly faster and going from 65MPH to 80MPH feels easier. I did have JDL UEL headers while having both exhausts. It just "felt" better with the HKS one.
#14 | |
friendly
Drives: 17' 86
Seek comfort in discomfort.
| WTB: OEM Mass Air Flow Sensor/Meter Assembly Air Flow Sensor | driftking96 | Want-To-Buy Requests | 0 | 02-16-2016 04:57 AM |
| Velocity orange gts 86 | bomexq | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 10 | 03-07-2014 05:32 AM |
| Does anyone know of a good local shop that can even out exhausts? | Darryljr11 | Mid-Atlantic | 13 | 02-20-2013 11:15 PM |
| Velocity: Fifth Gear FR-S | DBacon1052 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 10-23-2012 11:11 AM |
| Motorweek 7/24/12, 8pm EST on Velocity | No Quarter | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 07-25-2012 02:50 PM |
