Old 10-25-2021, 04:10 PM   #15
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by norcalpb View Post
To be fair there is a middle ground between staying stock and lowering your car 2 inches.
I can’t remember where it was posted, but in one of the launch interviews for the FR-S there was a bit where Tada explained the car’s geometry does really well when lowered 15-20mm.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
Dirty Harry (10-25-2021), Ultramaroon (10-25-2021)
Old 10-25-2021, 04:25 PM   #16
norcalpb
norcalpb's Avatar
Yes that is totally the sweet spot, whereas lowering the car 50.8mm is getting away from the sweet spot.
The Following User Says Thank You to norcalpb For This Useful Post:
Yoshoobaroo (10-25-2021)
Old 10-25-2021, 04:50 PM   #17
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Thank you for sharing this.
We've all felt this way at some point but aren't willing to publicly speak against the norm.
This is refreshing and makes me think back to basics of modifying my car.
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
The Following 2 Users Say Thank You to KMA KiCKz For This Useful Post:
soundman98 (10-25-2021), Yoshoobaroo (10-25-2021)
Old 10-25-2021, 05:38 PM   #18
ZDan
ZDan's Avatar
Drives: '23 BRZ
So how far off you reckon I am at 12.85" from hub to fender? Seems to be workin OK...
Old 10-25-2021, 05:51 PM   #19
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Live and learn.
Coilovers and wide sticky tires are over prescribed on this platform. They do accomplish making the car handle on rails. A complete departure from the stock handling feel of the car.
I am very satisfied with RCE yellow/B6 combo. Very much a OEM+ feel to it.
I swapped keys recently with a friend who has a track focused setup with 255/40 RS4s and a set of coils. Both of got out smiling for different reasons.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 10-25-2021, 05:58 PM   #20
Yoshoobaroo
TRACKBREAD
Originally Posted by RToyo86 View Post
Live and learn.
RCE yellow/B6 and eibach pro/B6 are probably the best setups for this car that don’t change the fundamental character of the drive, IF you want to lower it.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
RToyo86 (10-26-2021)
Old 10-25-2021, 06:10 PM   #21
Brz-123
RCE yellow/B6 and eibach pro/B6 are probably the best setups for this car that don’t change the fundamental character of the drive.
Only needed if one wants to track or drop height. For a road car the OE suspension set up is more than sufficient. Dont think the OP was doing a track build
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
The Following User Says Thank You to Brz-123 For This Useful Post:
Old 10-25-2021, 06:48 PM   #22
Dirty Harry
Dirty Harry's Avatar
Drives: 2013 BRZ Satin White Pearl
Interesting, the STI pink springs lower the ride height by 15mm, so that correlates with this.
On my car I thought the ride felt about the same, the wife thought the ride was better, lol. The car definitely handled better, flatter through corners.
Dirty Harry is offline   Reply With Quote
The Following User Says Thank You to Dirty Harry For This Useful Post:
Old 10-25-2021, 06:59 PM   #23
Dirty Harry
To the OP, sorry to hear about your experience with modding, I guess try and learn from the experience.
I used to have an underpowered Nissan Micra hatchback and decided it would look cooler with larger rims. Not taking weight or anything else except looks into consideration, I got the wheels fitted (I was a lot younger). Then once I drove out of the auto shop I was shocked at its sluggish performance and instantly regretted it. . I guess some of us have been there.
Also, sometimes with modifying cars, less is more.
Old 10-25-2021, 07:01 PM   #24
FrickingReallySlow
Drives: 2015 FR-S
Originally Posted by Lakitu View Post
- I want to reduce the wheel gap to 2" or 2 fingers - Achieved, but at a substantial loss to highway stability and lowspeed comfort
I think this may have compounded by your choice of coilovers and 245/35/18. thin tires with little room for comp/rebound. The tS is 215/40/18. If you wanted a slammed stance for cruising around suburbia that might have worked as long as your avoided the 4-6 inch speed bumps. You did your coilovers so many times why is it so hard to go back to stock? ( I see these sold on the forum and facebook marketplace for $25-50 for the entire set)
We all have the inner mod itch we want to scratch, its just how well we talk ourselves down from that ledge.
FrickingReallySlow is offline   Reply With Quote
Old 10-25-2021, 10:04 PM   #25
soundman98
ProCrastinationConsultant
soundman98's Avatar
I've been thinking about getting something conventional that I won't be tempted to modify.
been there, done that. even drove the parents truck for a while back in 2007-ish when the housing market fell apart, and i got laid off from my first full-time job. the idea was to get my finances back in order, and drive something reliable, boring, and unmoddable for that time.
the reality is that anything can be modded. that boring unmoddable truck suddenly had a 'new' stereo in it a few months in... old habits die hard. but with age, other interests, and just general 'life' stuff, modding starts to take a little more of a backseat to everything else.
my brz, i've been 'working' on the same reverse light led project since 2015..
suddenly getting a house, a bathroom remodel, getting my own truck, and helping where i can with the nephews while they're still young is a whole lot more important.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
BigHugeFatGuy (10-26-2021), Ultramaroon (10-25-2021)
Old 10-26-2021, 10:28 AM   #26
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
OP, at least you passed on a Rocket Bunny and pop-tune!
PetrolioBenzina is offline   Reply With Quote
The Following 6 Users Say Thank You to PetrolioBenzina For This Useful Post:
alphasaur (10-26-2021), BigHugeFatGuy (10-26-2021), NoHaveMSG (10-26-2021), soundman98 (10-26-2021), Ultramaroon (10-26-2021), Yoshoobaroo (10-26-2021)
Old 10-26-2021, 10:45 AM   #27
Ernest72
I tend to agree but 16 and earlier cars was a bit stiff with damping. So if you don’t want to lower, just adding B6 is a nice improvement over stock. This is what I plan on doing, was gonna do yellows but my daily commute sees speed bumps and some rough highway, so no need to lower for a DD.
OP your situation is fixable. Sell what did not work and buy what has been proven to work. If you buy another car, the taxes and fees alone could have paid for the mods to get the car back to something you enjoy.
Old 10-26-2021, 11:12 AM   #28
Originally Posted by MJones_RB View Post
The truth was (and is) that they are perfectly capable just as they are.
What I have seen on here over the years is that people expect bigger gains from their mods because there are plenty of cars that will get those gains since they started life as an econobox.
Replacing the cast straight exhaust manifold, under hood hot air intake, squishy sedan suspension and 1 1/4 exhaust on your mom's old 2004 Civic DX will transform the car.
Most of what you could do to the Twins was already well thought out from the start. Changing the existing header to a slightly different type or changing the already effective CAI isn't going to get you much.
The Following 7 Users Say Thank You to Tcoat For This Useful Post:
Dadhawk (10-26-2021), MJones_RB (10-26-2021), nikitopo (10-26-2021), Ohio Enthusiast (10-26-2021), RToyo86 (10-26-2021), Ultramaroon (10-26-2021), Yoshoobaroo (10-26-2021)
Regrets on Automatic? Ymerej Scion FR-S / Toyota 86 GT86 General Forum 312 03-24-2020 09:42 PM
Any Modification regrets? No5ki Scion FR-S / Toyota 86 GT86 General Forum 52 03-29-2016 08:03 PM
Any regrets? White0utFrs Scion FR-S / Toyota 86 GT86 General Forum 57 04-14-2014 05:15 PM
Lowering springs regrets ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 11-11-2013 05:04 AM
Regrets pinoyplaya Scion FR-S / Toyota 86 GT86 General Forum 133 04-11-2013 09:14 PM
