Old 11-02-2013, 04:08 AM   #1
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
Lowering springs regrets ?
so, Ive had my Swift springs for about a year. I miss my 'cush' ride and its getting to the point where I want my original suspension back ? ok , maybe its because im 'over-the'hill but still ---- anyone else go thru withdrawals ?
yea, it looks better but im thinking of packing it up and calling it a phase. TI also question the real advantage ? it seemed that with the stock suspension I had a bit more travel and on mtn runs, it seemed to sway a bit more but its more forgiving on the bumps and I don't think im doing my stock shocks a favor either ?
thoughts - suggestions ? im about to pull them out.
rikdrt1 is offline   Reply With Quote
Old 11-02-2013, 04:30 AM   #2
SliverBrz
Drives: Silver 2013 BRZ limited
get koni yellows.
problem solved
SliverBrz is offline   Reply With Quote
Old 11-02-2013, 07:07 AM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Are you still using the original bump stops?
edited, damn fat fingers.
Old 11-02-2013, 03:27 PM   #4
DAEMANO
Time Traveller
Save and get RS-R Black-i's. Could be right up your alley.
http://www.ft86club.com/forums/showt...ghlight=blacki
Old 11-02-2013, 03:43 PM   #5
suaveflooder
Originally Posted by SliverBrz View Post
get koni yellows.
problem solved
Agree with this. A lot of what you are feeling has to do with the actual shock. Obviously the springs plays a little into it, but my M3 smoothed out A LOT when I swapped to Koni's from the factory shocks. I was running H&R race springs, so they were pretty stiff. I'm assuming (Just an assumption, as I haven't done it) that this car will be the same.
suaveflooder is offline   Reply With Quote
Old 11-02-2013, 03:46 PM   #6
8686
8686's Avatar
Drives: 86
I am waiting for blestin B8 to use with my swift springs
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 11-02-2013, 04:31 PM   #7
MidnightRunner
MidnightRunner's Avatar
Yeah I think that might be it. :sly: All jokes aside, as stated by everyone here, swapping the shocks could have a huge difference for you. I have flat roads with minimal potholes so my swifts on stock shocks work fine for me. Good luck.
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 11-02-2013, 04:50 PM   #8
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
if I end up doing the ylw konis, don't you then have to mess around with the strut stop .. and a lot of other things ? I need to read up on that - I thought I heard something about having to do some mods or change some bolts on the struts etc.etc.
idk, maybe i like the look but i just wonder about the stiffer ride and what its buying me other than a cooler look .
i thought aobut what the difference would be if i went stock height and put some 18's x 8 or 7.5 instead just to fill the gap a little more.. hmm
Old 11-02-2013, 05:09 PM   #9
DougW
Drives: FR-S stock for now
If you can wait the Bilstein Damptronic package will restore your ride and give you great handling. I just got back from a drive from SC to Detroit to SC with a bad back and enjoyed the ride. Austin took the same package to Roebling Roads race track and drove it like a race car with the flip of a switch. About $3200 for the package.
DougW
DougW is offline   Reply With Quote
Old 11-02-2013, 05:34 PM   #10
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
The front koni shocks are inserts so you'll have to sacrifice your own or buy one in the classifieds. There is some adjustment stuff to read up on but it's easy to adjust.
Sent from my Galaxy Nexus
Books is offline   Reply With Quote
Old 11-02-2013, 06:18 PM   #11
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I have Eibach Sportlines and sometimes I feel like it's too low for my taste. I think I should've gone with a Pro-Kit, but I'm not sure.
About half the pics I see with a Pro-Kit look great, while the other half you can barely tell the car is dropped.
Who knows...maybe after seeing my car on a Pro-Kit I'd want the Sportlines back.
ericmpena is offline   Reply With Quote
Old 11-03-2013, 02:13 AM   #12
Raven23
Dang, I have the same problem. Thinking about going sportline but afraid it might be too low for a DD. I don't want to settle for pro kit and see a huge wheel gap tho. Sigh. The pros and cons haha
Raven23 is offline   Reply With Quote
Old 11-03-2013, 04:57 PM   #13
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
The wheel gap with pro springs is an inch or very close to front and back even, it isn't too much IMO.
Old 11-04-2013, 05:42 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have 20,000 miles on my Eibach Pro kit. My stock shocks are still doing ok. I do plan on upgrading the shocks in the future though. I am happy with the ride quality, the height, and the look. I only scraped with three people on a steep driveway one time.
I read every post on springs before making a decision. My opinion is that most mild drop springs will work better than the more aggressive drop springs. Meaning if you lower an inch or less, your ride quality and shock longevity will be better.
My budget at the time would not support even "cheap" coilovers. Though after reading reviews, I decided that buying "cheap" coilovers was not the way to go.
Lowering car with springs... What else do I need? SurfAndSand Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-25-2013 11:39 PM
TRD Lowering Springs? kALMIGHTY Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-29-2013 11:10 AM
RS*R Lowering Springs Soon to be out! tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 03:39 PM
Lowering springs HELP FRS_13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-27-2012 11:03 PM
Lowering springs? Jeff Lange Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-11-2012 12:36 AM
