Old 10-16-2021, 01:05 AM   #15
DarkSunrise
DarkSunrise's Avatar
Originally Posted by jflogerzi View Post
I don't see them on the site. I have killed my second coil same one cylinder 1. How have they held up? Thinking of just getting OEM one and wrap some gold tape to help keep some heat out
Sent from my Pixel 5a using Tapatalk
In my testing, the gold foil didn't do anything. It might have actually shortened the life of the coil (only lasted 2,022 miles with the foil).
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
jflogerzi (10-16-2021)
Old 10-16-2021, 01:43 AM   #16
jflogerzi
jflogerzi's Avatar
Cancelling the order
2013 Series 10 FRS #553
Old 10-18-2021, 02:05 PM   #17
thekevinvo
Drives: 2014 Scion FRS
Not sure if I can post the link since I'm affiliated, but if you just search SSFA2X-4 on FTspeed you'll find them.
thekevinvo is offline   Reply With Quote
Old 10-22-2021, 02:30 PM   #18
Four_wheel_drifts
Drives: Whiteout track car; lava donor
Gold tape should always be used regardless of OEM or aftermarket coil.
Looking at the icefabrication.com site, why wouldn't one just buy the 2015+ connectors at $12 each and repin our 2013 ones?
Seems much cleaner and easier than cutting and splicing using their $90 kit.
I'm very wiring competent and can do either. Just wondering if there are hidden gotchas I'm not seeing.
Four_wheel_drifts is offline   Reply With Quote
Old 11-16-2021, 11:07 PM   #19
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
Originally Posted by redlined600 View Post
These were the blue benchmark coils mentioned above?
That is correct the ebay blue benchmark coil failed. Swapped it with one of the two good OEM coils I had and my CEL hasn't come back. Before I was getting it every session.
Shneegle is offline   Reply With Quote
Old 11-22-2021, 02:20 AM   #20
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
OTL now sells an OEM rev1 to rev2 connector adapter. Planning on buying those to go along with a set of used rev2 coil packs for $100 on ebay.
@jflogerzi
EndlessAzure is offline   Reply With Quote
Old 11-22-2021, 12:39 PM   #21
jflogerzi
jflogerzi's Avatar
@jflogerzi
any re-pinning needed?
Old 11-22-2021, 02:26 PM   #22
EndlessAzure
Wheels for Brains
Not that I saw.
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
bcj (11-22-2021), jflogerzi (11-22-2021)
Old 11-26-2021, 04:03 PM   #23
sato
sato's Avatar
Drives: Dodge Patitas
@jflogerzi
https://www.ftspeed.com/part/coil-ad...t#.YaFDDdDMKUk
Can't find it elsewhere, not even directly from OTL.
sato is offline   Reply With Quote
coil packs Replacements OEM or Aftermarket jflogerzi Tracking / Autocross / HPDE / Drifting 76 10-05-2022 08:47 PM
IP Coil Packs bozack Engine, Exhaust, Transmission 6 03-06-2022 01:36 PM
2013 Coil Packs, where did you guys get them from? Keenercarguy Issues | Warranty | Recalls / TSB 24 05-25-2018 08:43 PM
Stock 13/14 coil packs shaynek Want-To-Buy Requests 1 04-26-2018 08:20 AM
Do I have bad coil packs or a failing DI pump? xkalelx Forced Induction 16 03-15-2016 01:56 PM
