Old 10-15-2021, 10:52 PM   #29
One of the track day organizers always jokes I am having a yard sale. I carry a lot of stuff because the better tracks in my area are about 3 hours away.
CV axles with new nut and retaining clip.
Spare lugs and studs
Ignition coil
ACC belt
Front hub loaded with studs
Spare set of brake pads
Fluids
Spare Idle pulleys
Exhaust gaskets
Tool kit with common sizes.
I have actually never repaired my car at the track aside from adding a couple zip ties. I have nursed a bad front hub home. Have helped others before though. One guy ran out of front brake pad and I happened to have a partially worn set of stock fronts even though I don't have stock calipers. Earlier this year I spent 2 hours at an SCCA TT event fixing another twin that had stripped front studs, had to unbolt the caliper and hub with the wheel attached and drill out the studs from the back to get the wheel off
I went searching for some kind of track-kit thread. Lo and behold...
Originally Posted by ZDan View Post
I used to take a ton of spares to the track. No more! On the occasions when I had an emergency (fragged clutch, broken driveshaft, etc.), I never had what I needed on hand anyway. I keep it minimal (brake fluid and bottle/hose for bleeding, leftover track and/or OEM brake pads, quart of 5w30 synth). My club is pretty great and there's *always* someone with tools and extra hands to help out if/when things go wrong though...
Haha.... prophetic.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
bcj (10-16-2021), femaledog (10-15-2021), NoHaveMSG (10-15-2021), ZDan (10-16-2021)
Old 10-15-2021, 11:20 PM   #30
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Saving a track day is being prepared before you get there. Keep up all maintenance and replace things that have a history of failing before they fail. Getting stuck at a track with a broken car is no fun. Been there done that. Thank you Irvine Toyota for destroying my motor.
TommyW is offline   Reply With Quote
Old 10-17-2021, 06:00 AM   #31
54fighting
Drives: 2020 toyota 86
AAA membership card!!
54fighting is offline   Reply With Quote
Old 10-17-2021, 06:12 AM   #32
JD001
JD001's Avatar
Drives: Subaru BRZ
A DD..
Old 10-17-2021, 09:26 PM   #33
Icecreamtruk
Drives: Track preped NA FRS
A trailer with fluids, basic tools and another set of rims/tires. Everything else that breaks at that track is a major pain in the ass to repair and I'd rather do it at home or at the garage.
Icecreamtruk is offline   Reply With Quote
Old 10-19-2021, 09:39 PM   #34
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What's in your "save the track day" kit?
You know what they say about "no good deed goes unpunished." Spent all that time working on a friends car and blew up an engine within 2 laps lol
I carry more stuff now that I have a trailer
Ultramaroon (10-23-2021)
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 09:27 PM
Trans balked at 4-5 upshift on track, "Shakey clutch" in paddock ??? Joesurf79 Tracking / Autocross / HPDE / Drifting 1 05-26-2018 04:16 PM
Cantrell Motorsports track event @ "RMP"and some awesome footage with an Air Drone :) glamcem Tracking / Autocross / HPDE / Drifting 23 08-30-2014 07:30 PM
Autocross to Track Day Transition "Dive bombing a tire wall" Rickapl Tracking / Autocross / HPDE / Drifting 13 07-27-2014 10:40 PM
Autocross to Track Day Transition "Dive bombing a tire wall" Rickapl Off-Topic Lounge [WARNING: NO POLITICS] 11 07-15-2014 10:05 PM
