#15 |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
From a normal HPDE standpoint I agree. From a competition standpoint I disagree. The more negative camber you have the worse straight line performance you have. Double wishbone cars have a huge advantage in this area since they don't have to run ridiculous amounts of camber like we do. Again, there's a reason why bespoke performance cars aren't MacPherson strut.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
#16 | |
Drives: '23 BRZ
Most competition classes will classify cars based on their inherent performance, so any difference between wishbone and strut is often built-into the classification. Ultimately, yeah, wishbones or multiink are "better", but for 90% of us who track these cars, not really... Ultimitely, I still think the crap weight distribution holds these cars back much more than front struts instead of wishbones. |
#17 |
Drives: Toyota 86
I agree with Zdan, Mx5 and S2k are better cars primarily for their weight balance (if you’re skilled enough to exploit it of course, more nose weight means less performance maybe but it’s way easier to handle for a non pro driver), I’ve only driven the s2k which is heavier so I guess the lighter ND2 Miata is even better…the DW probably helps but it’s not the whole story, a well built strut car with a good setup and a decent balance plus not a crazy weight like our twins performs better than a crappy DW car with too much weight and a bad steering feedback like an Audi A5 for example.
Car which has given me the best steering feeling so far was a strut equipped 991 Porsche, tons of caster and not a standard strut yes but still a strut. |
#18 | |
I was instructing a friend in his ap2 yesterday and drove his car for one session at around 9/10ths pace. The wear on the tire shoulder was pretty extensive after just one session, and that was with the factory camber adjustment maxed out to -1.9*.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Ohio Enthusiast (10-09-2021) |
#19 |
Drives: BMW E30, 2014 FR-S
Then we have guys that are custom fabricating cantilever suspension setups.
![]() https://www.instagram.com/p/CTa5hZcHvj9/ |
| The Following User Says Thank You to kevaughan For This Useful Post: | Wally86 (10-13-2021) |
#20 |
I would argue that the type of suspension a car has, either stock or modified, does not matter as much as how well the car is tuned/optimized.
| The Following User Says Thank You to SCFD For This Useful Post: | Ohio Enthusiast (10-11-2021) |
#21 |
Drives: 2018 BRZ
I won't reply to all posts, but this is a really good point - both on the MX-5 and on the Lotus Elise (just examples I've read about) the consensus about track camber alignment is "as much as you can get". On top of that the aftermarket offers improved A-arms that allow greater camber range for the DW.
#22 |
Drives: 2018 BRZ
Try a Lotus Elise - manual steering, DW and very low caster angle that gives one of the best (if not the best) steering feel of any car at any price. I would agree with "many ways to skin a cat" and "suspension tuning trump suspension type".
#23 | |
Drives: Crapcan
#24 | |
But is that really because of the geometry and weight distribution? If you want your car to have sharper turn-in just add some toe-out in the front. |
#25 |
Dismember
Drives: 2013 Red Scion FR-S
A lot can be done to change and move grip around. Spring rates. Tires. Unsprung weight. Total weight. Height. Damping. Alignment. Roll bars. Weight distribution. Aero.
My understanding is that double wishbones have some advantages in the alignment department. That's a pretty important department, but it's not like other suspensions are shit, and it's just one department among many. If I wanted sharper turn in, I could stiffen up the rear springs or damping or roll bars, add toe out in front, add camber in front, trail brake, and probably some other things. Of course all of this would affect the car on exit too, and in all kinds of fun and interesting ways. Or am I wrong?
#26 | |
Drives: Crapcan
#27 |
Dismember
I wouldn't argue that the S2K is not superior. It probably is in most ways on the track.
If you had mid corner understeer, maybe Bilstein would tell you to... Increase rebound rate on front. Increase compression rate on rear.
#28 | |
Drives: '23 BRZ
For mid-corner understeer: Increase rear roll stiffness (more rear spring rate or rear bar). Or decrease front roll stiffness (less front spring rate less front bar). Or increase rear ride height (raise rear roll center). |
| The Following User Says Thank You to ZDan For This Useful Post: | strat61caster (10-14-2021) |
| If anyone is going down the dirt/rally/rough road type suspension route... | grumpysnapper | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 02-01-2021 05:57 PM |
| Do Rear Suspension Springs Orientation Matter? | krayzie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 07-02-2019 12:01 PM |
| Tein Type Flex - suspension setting question | koevasi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-03-2013 04:20 AM |
| Lug Nuts, do they matter? | jonnyozero3 | Tracking / Autocross / HPDE / Drifting | 34 | 04-28-2013 08:48 PM |
| ARE YOU GONNA BUY IT NO MATTER WHAT | serchmarc | Scion FR-S / Toyota 86 GT86 General Forum | 97 | 03-19-2011 06:27 PM |
