Old 08-18-2021, 03:19 AM   #29
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Won’t know till someone gets their hands on one.
Definitely. But I don't think they'll match up like a K24/K20 situation. The bore difference is much bigger. Will be interesting to find out though when someone cracks one open or you get blocks out there.
Originally Posted by RippedManiac View Post
Might finally ring to 9k unless oiling becomes an issue
That's what I'm hoping. Although I'm guessing it will need cams/valvetrain to make power up there. on 1st gen, power falls off after 7000 according to many dynos I've seen here. And I heard the stock FA20 valves won't last up there. We'll see!!
Originally Posted by BrahmaBull1990 View Post
Well there goes all my money....figuring out how to swap the new drive train into a gen 1 while keeping or replacing my Edelbrock SC smh
Calling all mad scientists
Unless the FA24's potential is somehow much higher than anticipated, then I don't think it'd be worth swapping out. Either get your current gen built and turbo'd or trade in/get a 2nd gen instead.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
The Following 4 Users Say Thank You to NARFALICIOUS For This Useful Post:
BrahmaBull1990 (08-18-2021), JesseG (10-15-2021), NoHaveMSG (08-18-2021), R2 (11-29-2021)
Old 08-18-2021, 03:58 AM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
FA24 In-Depth Look
Yeah I am aware since the difference between the K20/24 is a stroke change it is simple. I am actually trying to get one of my vendors to 3D scan a set of FA20 heads so I can stick it into solidworks. Just rough measuring it would leave about 8mm of gasket sealing surface, the only complex geometry in the FA head is two quench pads on the exhaust side that are not present on the DIT motor. It is mostly just for fun that I am curious. If one where to buy a FA24 short block, it is not like you couldn’t sell if down the road given the amount of these cars that will likely be hitting the track. At this point I am pretty much married to using the FA20 in the gen 1 car.
Old 08-19-2021, 12:50 AM   #31
Lightened
Every Ounce Counts
Lightened's Avatar
Drives: 86
Lightened is offline   Reply With Quote
The Following 6 Users Say Thank You to Lightened For This Useful Post:
Alltezza (08-19-2021), chaoskaze (10-11-2021), flippy (06-19-2023), Irace86.2.0 (10-16-2021), JesseG (10-14-2021), MJones_RB (08-19-2021)
Old 08-19-2021, 09:55 AM   #32
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Originally Posted by Lightened View Post
Whooo! Look at those rods!
Alltezza is offline   Reply With Quote
Old 10-10-2021, 02:31 AM   #33
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
History of asymmetrical rods
I was checking this topic. Just a little comment about the story of the asymmetrical rods in FA20. This started when Subaru was working on the latest version of their H6 engine. Long story short, they wanted to increase the engine displacement from 3.0 liters to 3.6 liters. Issue was that cylinder bore was close to maximum safe size and any significant increases in crankshaft stroke would result in engine-block deck-height increases that would make the engine too wide to fit. So they came up with a novel way of increasing piston stroke without raising the cylinder deck height. The answer was an asymmetrical connecting-rod design (which looks somewhat like a lamb chop) that permits the piston to travel farther downward into the crankcase and increases the effective stroke. The advantage that the rod bolts can be fastened without separating the block and easing in general the engine assembly was really a side result of this design.
The Following 9 Users Say Thank You to nikitopo For This Useful Post:
chaoskaze (10-11-2021), daiheadjai (10-10-2021), Dirty Harry (10-10-2021), flippy (06-19-2023), Irace86.2.0 (10-16-2021), JesseG (10-15-2021), NoHaveMSG (10-10-2021), RedReplicant (10-17-2021), timurrrr (10-10-2021)
Old 10-10-2021, 12:52 PM   #34
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I wouldn't mind a 3.0L H6 NA engine offered in a BRZ STI
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
Ash_89 (10-11-2021), nikitopo (10-10-2021)
Old 10-11-2021, 12:41 AM   #35
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Issue of building a modern 6-cylinder boxer engine is that it'll be too complex and too heavy. The FA20 was for example 55 kg. heavier than the older EJ20 and the weight of the FA24 hasn't changed.
Old 10-11-2021, 06:49 AM   #36
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
impossiburu, Subaru dreamed of making appliance all day for max proft... =( Sadly they aint Porsche.
The Following User Says Thank You to chaoskaze For This Useful Post:
nikitopo (10-11-2021)
Old 10-11-2021, 08:27 AM   #37
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Yeah, subaru would never do a timing system with an intermediate shaft and chains on both ends of the engine just so they could use the same head casting for the heads.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
ATL BRZ (03-08-2022), JesseG (10-15-2021)
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
Oil Cooling - An In-Depth Look VerusEric Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 115 02-20-2023 10:54 PM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Depth of speed DIG1992 Other Vehicles & General Automotive Discussions 6 05-22-2012 01:13 PM
