Old 10-10-2021, 06:03 PM   #1
86prime
Drives: 18 BRZ tS
Struts that work with Karcepts sway bar
Karcepts just informed me that not all struts will allow the full range of adjustability (beyond hole 2) with their sway bar. This depends on the position of the endlink mounting tab on the strut body.
I have OE Sachs on my 2018 tS, so should not be a problem.
The Bilstein B6 looks like all its mounting locations are same as OE. Can someone please confirm? @Racecomp Engineering
https://www.ft86club.com/forums/showthread.php?t=143629
The RCE T2 coilovers are one example that will not work.
(There's also the question of whether or not you need to go beyond hole 2, but that's another topic.)
86prime is offline   Reply With Quote
Old 10-11-2021, 03:36 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Bilstein B6/8 and Koni should be direct OEM fit when it comes to the Swaybar mount.
My Megan racing were just barely able to hit the third hole, but it made Brian nervous iirc. He provided an incredible amount of support and information over email, over a year later and I still go back to read it.
Currently on Bilstein B16 and need to go remeasure but I have oodles more clearance then the Megan's did so I'm expecting good results as they are designed to be closer to OEM specs, anything that comes with end links and can't use oe is a bad sign.
Great bar though, ease of adjustment is real, only minor noise under awkward daily driving situations, 95% great, I've got over 10k miles on mine.
Edit: I'm surprised the rce doesn't work, the kw base should be oe like as the bilstein for tuv compliance. Can they at least hit the third hole?
ineedyourdiddly
Old 10-11-2021, 04:44 PM   #3
Bilstein B6 mounting points lined up with OEM when I checked.
I swear someone is using RCE T2s with the Karcepts front bar but I definitely could be wrong.
- Andrew
Old 10-11-2021, 06:34 PM   #4
strat61caster
- Andrew
You can use most any coilover in the softer positions, the issue is at the stiffer adjustments you risk binding the endlinks, endlink contacting strut body, or the swaybar arm contacting the LCA. Which in the wrong corner/bump in pavement could be bad news.
I knew that going in and decided I'd rather have a three adjustment bar I could actually adjust at an event then the bar I had which was next to impossible for me to adjust at an event.
ineedyourdiddly
Old 10-11-2021, 08:32 PM   #5
86prime
Drives: 18 BRZ tS
Thanks, guys. I'm told that the RCE T2s may work if used with the RCE lowering front camber plates, since that would move the strut assembly upward.
Old 10-12-2021, 09:31 AM   #6
wparsons
wparsons's Avatar
If that works, then a shorter end link should also work.
flickr
Old 10-13-2021, 08:21 PM   #7
86prime
Drives: 18 BRZ tS
From Karcepts: One would think a simple fix is to just shorten the endlink length until there is no sway bar arm contact at full droop in hole position 4. However, the shorter the endlink, the more limited the link's range of motion becomes. Too short an endlink may observe premature endlink wear; and in extreme cases, possible binding and endlink contact with the strut body when running the bar full stiff and using more than normal steering wheel input. I admit that we may still be a bit conservative on our minimum endlink length at this time.
FS: Goodrich SS Brake lines, TRD spring/Sway bars, Sachs struts Tacticalpanda Brakes, Suspension, Chassis 6 01-25-2019 04:21 PM
Stock Struts, arms sway bar. Perrin rear swaybar Ashikabi Brakes, Suspension, Chassis 13 01-22-2017 07:15 PM
WTB: '15 Springs & Struts , 16mm WRX Rear Sway Bar P@ul Want-To-Buy Requests 0 01-07-2015 12:53 PM
FS: BRZ/FRS shocks, struts & sway bar end links BRZ'13 Canada Classifieds 0 07-02-2014 02:23 PM
Would Springs from Coilovers work on OEM Struts? taimysho0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-14-2013 10:16 AM
