Old 09-30-2021, 03:25 PM   #1
arbitrarycomplexity
Drives: '17 Toyota 86 AT
Unhappy Play in steering rack
I assumed I needed to replace a tie rod, but I get in there and the steering column clearly has about 10-15 degrees of play.
It happens across the entire rack. Always takes a bit of a turn to "hook up" when turning the other way.
https://youtube.com/shorts/RmMxZ58XiuM?feature=share
Is this adjustable or am I looking at replacing the rack?
arbitrarycomplexity is offline   Reply With Quote
Old 09-30-2021, 03:46 PM   #2
Wow, I bet that's squirrely as hell. Replace.
Old 09-30-2021, 04:00 PM   #3
arbitrarycomplexity
Oddly it's completely drivable. Almost need to slightly tension it one way
Old 09-30-2021, 04:01 PM   #4
norcalpb
norcalpb's Avatar
Looks like play between the pinion gear and the rack gear.
@Ultramaroon is right as usual, time to replace.
Plus that level of corrosion would have me worried.
But to replace you are looking at like $700 in just parts so maybe just keep driving it until it feels not normal?
Old 09-30-2021, 04:04 PM   #5
arbitrarycomplexity
Atlantic Canada
Old 09-30-2021, 04:06 PM   #6
norcalpb
norcalpb's Avatar
Originally Posted by arbitrarycomplexity View Post
Atlantic Canada
Is the car completely off when you are moving the steering rack I.e not in ignition mode?
Old 09-30-2021, 04:07 PM   #7
arbitrarycomplexity
Yes
Old 09-30-2021, 04:53 PM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
Corrosion? What corrosion?
- another Atlantic Canadian
Old 09-30-2021, 04:59 PM   #9
Atlantic Canada
Yeah. Corrosion's no sweat. I get that.
Rebuilt ones are available. I wouldn't mess around.
https://www.rockauto.com/en/catalog/...nd+pinion,7388
Old 10-01-2021, 02:07 AM   #10
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Old 10-01-2021, 07:57 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
TORQUE OH TORQUE, WHERE ART THOU
FS: Perrin Steering Rack Lockdown Kit and STI Steering Rack Long Bolts Kit neilvosko Brakes, Suspension, Chassis 3 04-10-2018 05:48 PM
FS: OEM Steering Rack MicheleAbbate Brakes, Suspension, Chassis 0 04-18-2016 02:51 PM
Steering Rack Play FR Sports CANADA 1 06-04-2014 09:00 PM
Steering rack diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-07-2014 12:12 AM
