-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Play in steering rack (https://www.ft86club.com/forums/showthread.php?t=147051)
arbitrarycomplexity 09-30-2021 03:25 PM
I assumed I needed to replace a tie rod, but I get in there and the steering column clearly has about 10-15 degrees of play.
It happens across the entire rack. Always takes a bit of a turn to "hook up" when turning the other way.
https://youtube.com/shorts/RmMxZ58XiuM?feature=share
Is this adjustable or am I looking at replacing the rack?
Ultramaroon 09-30-2021 03:46 PM
Wow, I bet that's squirrely as hell. Replace.
arbitrarycomplexity 09-30-2021 04:00 PM
Oddly it's completely drivable. Almost need to slightly tension it one way
norcalpb 09-30-2021 04:01 PM
Looks like play between the pinion gear and the rack gear.
@Ultramaroon is right as usual, time to replace.
Plus that level of corrosion would have me worried.
But to replace you are looking at like $700 in just parts so maybe just keep driving it until it feels not normal?
arbitrarycomplexity 09-30-2021 04:04 PM
Atlantic Canada:(
norcalpb 09-30-2021 04:06 PM
Originally Posted by arbitrarycomplexity (Post 3470098)
Atlantic Canada:(
Is the car completely off when you are moving the steering rack I.e not in ignition mode?
arbitrarycomplexity 09-30-2021 04:07 PM
Yes
Calum 09-30-2021 04:53 PM
Corrosion? What corrosion?
- another Atlantic Canadian
Ultramaroon 09-30-2021 04:59 PM
Atlantic Canada:(
Yeah. Corrosion's no sweat. I get that.
Rebuilt ones are available. I wouldn't mess around.
https://www.rockauto.com/en/catalog/...nd+pinion,7388
Captain Snooze 10-01-2021 02:07 AM
Attachment 205670
soundman98 10-01-2021 07:57 PM
TORQUE OH TORQUE, WHERE ART THOU
