Old 09-29-2021, 06:44 PM   #80879
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Sooo true -
In addition, the store/shop where I used to go as a kid, also had a small machine shop in the back, that would grind valves and mill heads.
Also, they were a source of information. For example, they introduced me to the plastic wire/tape to gauge how to shim piston rod bearings and to a miracle device to compress piston rings, so as to get the pistons back into the cylinders -
Yep, did drums and disks, valves and heads. Now places like O'relies are just wax and grease places.
Sapphireho is offline
humfrz (09-30-2021), soundman98 (09-29-2021)
Old 09-29-2021, 06:47 PM   #80880
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Replaced battery. Doesn't it look cool?
The Following 5 Users Say Thank You to Sapphireho For This Useful Post:
humfrz (09-30-2021), p1l0t (09-29-2021), soundman98 (09-29-2021), spike021 (09-29-2021), wolffbite (09-30-2021)
Old 09-29-2021, 06:50 PM   #80881
Sapphireho
Famous Potatoes
Sapphireho's Avatar
For sale. Original Panasonic battery. All cells good. PM me and I will ignore you.
The Following 8 Users Say Thank You to Sapphireho For This Useful Post:
NoHaveMSG (09-29-2021), p1l0t (09-29-2021), pope (10-01-2021), soundman98 (09-29-2021), spike021 (09-29-2021), Spuds (09-29-2021), Ultramaroon (09-29-2021), x808drifter (09-29-2021)
Old 09-29-2021, 06:52 PM   #80882
p1l0t
p1l0t's Avatar
LiFePO4?
p1l0t is offline
Old 09-29-2021, 06:58 PM   #80883
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
You misspelled "ultramoron".
Definitely not to be confused with Ultramaroon, that guy is cool.
Spuds is offline
The Following 6 Users Say Thank You to Spuds For This Useful Post:
Captain Snooze (09-29-2021), Sapphireho (09-29-2021), soundman98 (09-29-2021), spike021 (09-29-2021), Ultramaroon (09-29-2021), x808drifter (09-29-2021)
Old 09-29-2021, 07:18 PM   #80884
LOLFU
Ultramaroon is offline
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
Sapphireho (09-29-2021), soundman98 (09-29-2021), spike021 (09-29-2021), Spuds (09-29-2021), x808drifter (09-29-2021)
Old 09-29-2021, 07:20 PM   #80885
He's an asshole
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
Old 09-29-2021, 07:42 PM   #80886
Sapphireho
Famous Potatoes
Sapphireho's Avatar
What!? No offer?
Old 09-29-2021, 07:56 PM   #80887
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I have more parts.
Old 09-29-2021, 09:03 PM   #80888
soundman98
ProCrastinationConsultant
soundman98's Avatar
They have Costco in Idaho? -
reminds me of a story.
first car, a '94 chrysler lebaron--tried doing some 'routine' maintenance to it, changing the spark plugs and wires. went with some super-fancy, E3, tri-tip, platinum, 'extreme' plugs. the marketing material said they improved fuel economy, boosted power, and made the motor run smoother!
it was a sideways v6, so the fronts went in easy, but the back 3 plugs took 4-5 hours to get to, as well as learning about car repair and the swear jar.
finally, all done, i go to start it up, and it'll barely maintain an idle. dies nearly every light on the way to see my grandfather(retired chrysler service manager) to show off my new car and the work i did..
pull up in his driveway, and it's chugging like a locomotive at this point.
start telling him all the things i've done to it, and about the super-amazing things that these fancy spark plugs are going to do after they just need a little time to break in a little.
he shrugs, looks the motor over, and says, "we always just put champion's in the cars. never had this sorta problem."
2 weeks later, it was still running like garbage. champions went in. car never ran better after that.
Not bad. We've had some ups and downs with a couple health related things but everything else has been pretty good.
He's currently losing his puppy teeth and fortunately I've found a few and decided to keep them (I don't know if that makes me weird or not ). But that means he's also teething, so that's been interesting.
my parents still have furniture with teeth marks from the dog we had as kids going through that phase...
scrap yard says it's worth about $5. i can give you $2.50. shipped.
soundman98 is offline
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
humfrz (09-30-2021), NoHaveMSG (09-29-2021), spike021 (09-29-2021)
Old 09-29-2021, 10:07 PM   #80889
What!? No offer?
I'll trade you an oil cooler for it. Improved Racing's attempt at improving on a 72-row Setrab 1-series. I replaced it because I thought it leaked.
Old 09-29-2021, 10:27 PM   #80890
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Meh, don't need one. Now if you had a radial arm saw, we could talk.
Old 09-29-2021, 10:49 PM   #80891
Old 09-29-2021, 10:55 PM   #80892
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What!? No offer?
Trade you for a corded set of RT660’s.
NoHaveMSG is offline
