Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-23-2021, 10:32 AM   #29
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Here's what interests me. It appears that the engine sound generator is independent of the infotainment system. That's good news.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following 3 Users Say Thank You to FR-S2GT86 For This Useful Post:
sato (09-25-2021), Simmons (09-23-2021), stilesg57 (09-23-2021)
Old 09-23-2021, 10:38 AM   #30
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Yep. You can unplug it, remove it, have the dealer turn it off, maybe repurpose the speaker...
Old 09-23-2021, 10:45 AM   #31
stilesg57
Drives: Shopping Mustang GTs and BRZs/86s
PULL IT FOR WEIGHT SAVINGS
(I’m only half joking)
stilesg57 is offline   Reply With Quote
The Following User Says Thank You to stilesg57 For This Useful Post:
Dzmitry (09-23-2021)
Old 09-23-2021, 10:57 AM   #32
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Hey! There's a lot of unused space behind the dash.
What can we do to make things comically worse?
NoHaveMSG (09-23-2021)
Old 09-23-2021, 11:59 AM   #33
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by FrickingReallySlow View Post
I've been waiting for the same thing. FA24/20 frankenbuild from a rod knocked engine or If only the timing cover being able to also fit the STI FA24 shortblock would be so sweet.. oh wait i'm in california.
Since the header gasket is the same as FA20... so lots of implications there. I'm surprised they didn't open up exhaust ports more
lol you knew exactly what I was trying to figure out. I also tried seeing if the cam carrier is the same but it doesn't show up for the 22'.
Old 09-23-2021, 12:35 PM   #34
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by Hudzoyne View Post
Have a look at EJ20 heads on EJ25 blocks. Very common and a 92mm Vs 100mm bore sizes IIRC. As long as you cut the chambers in the head it should work.
I plan to try building one as soon as I can get a short block sent over
Of course machining the combustion chamber would make it work, as long as your machinist/engine builder knows that they are doing. They would have to balance the chambers again too.. But people are interested in the new block for 'Easy power" NA purposes that won't involve a built block. Like a k20/24.. Your compression drops off a cliff when you open up the combustion chamber which is fine for FI but not some much NA as now you need custom pistons and have circled back to a built block.
PulsarBeeerz is offline   Reply With Quote
Old 09-23-2021, 12:41 PM   #35
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yup.
There are also two quench pads in the combustion chamber of the NA FA that is not there in the FI version that would likely need replicated to some degree. I have been trying to get one of my vendors to 3d scan a set of heads for me but they have been slammed. They already have a simple work project for me that I dropped of 3 months ago they haven't even started
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
PulsarBeeerz (09-23-2021), sato (09-25-2021)
Old 09-23-2021, 01:25 PM   #36
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by trippinbillies40 View Post
Welp.... Either I'm smoking crack or they updated it overnight lol. I swear I saw that it was cross compatible yesterday.
Sorry, all!!!
Gah, that's what I was afraid of.
After all that "FA24 will have higher compression ratio, bad for FI!!!11" thingy, then the inconsistencies in the online configurator, I don't think we should trust the data in a just-updated parts catalogue too much...
The Following User Says Thank You to timurrrr For This Useful Post:
Old 09-24-2021, 05:48 PM   #37
FrickingReallySlow
Drives: 2015 FR-S
OCV parts reused / superseded
2022 FA24 will be using FA20 OCVs it looks like
Very interesting that there's 2 family of OCVs that can be used on FA20s
10921AA241 (superseding 10921AA240) 2015-2021 Brz , forester,wrx
10921AA231 (superseding 10921AA220,10921AA230) 2013-2022
the -231 part is actually the one called out on the TSB but the -241 apparently can also be used. 2015+ vehicles can use either it seems but 2013-2014 can only use -231
FrickingReallySlow is offline   Reply With Quote
Old 09-27-2021, 08:40 AM   #38
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Will the 2015+ diff final drive work with the new cars?
Potential that is a part I'd be interested in.
Blighty is offline   Reply With Quote
The Following User Says Thank You to Blighty For This Useful Post:
stilesg57 (09-27-2021)
Old 09-27-2021, 08:52 AM   #39
dragoontwo
dragoontwo's Avatar
As of right now, it states that the entire diff and r&p are shared with the older models. So yes.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
Blighty (09-27-2021), stilesg57 (09-27-2021)
Old 09-27-2021, 10:28 AM   #40
Blighty
Ahh actually it seems the 2017 manual R&P (the 4.3 one), does not suggest its compatible. The auto from those years still use the 4.1 which is where you might of been confused.
So would it be worth taking a chance on I wonder, or would there be a genuine part incompatibility, not just a 'spec' incompatibility (meaning it would fit but make your car out of spec).
Old 09-27-2021, 10:56 AM   #41
dragoontwo
dragoontwo's Avatar
2017-2020 manual are all 4.3. Its just a different r&p in the same case the 4.1 uses.
Blighty (09-27-2021), Dzmitry (09-27-2021)
Old 09-27-2021, 01:51 PM   #42
pzerok
Drives: GR86
Didn't see anything on fog lights...this makes me sad.
pzerok is offline   Reply With Quote
TRD Catalogue Salemate Canada Classifieds 14 12-26-2015 12:15 AM
Definitive JDM AERO Catalogue (updated frequently) BPAuto Exterior Parts - The Rest 414 12-02-2015 02:53 PM
Hyper Rev magazine - basically a massive parts catalogue. diss7 Scion FR-S / Toyota 86 GT86 General Forum 21 01-18-2014 12:26 PM
KT Auto Works - Grazio & Co Catalogue - Coming Soon m0nty Australia Classifieds 27 09-15-2012 08:14 PM
