#29 |
Master Collaborator
Here's what interests me. It appears that the engine sound generator is independent of the infotainment system. That's good news.
#30 |
Drives: 22 BRZ limited
Yep. You can unplug it, remove it, have the dealer turn it off, maybe repurpose the speaker...
#31 |
Drives: Shopping Mustang GTs and BRZs/86s
PULL IT FOR WEIGHT SAVINGS
(I’m only half joking) |
#32 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Hey! There's a lot of unused space behind the dash.
What can we do to make things comically worse?
"I gotta rock." -- Charley Brown |
#33 | |
Drives: Crapcan
#34 | |
Drives: JRSC BRZ SOLD
Of course machining the combustion chamber would make it work, as long as your machinist/engine builder knows that they are doing. They would have to balance the chambers again too.. But people are interested in the new block for 'Easy power" NA purposes that won't involve a built block. Like a k20/24.. Your compression drops off a cliff when you open up the combustion chamber which is fine for FI but not some much NA as now you need custom pistons and have circled back to a built block. |
#35 | |
Drives: Crapcan
There are also two quench pads in the combustion chamber of the NA FA that is not there in the FI version that would likely need replicated to some degree. I have been trying to get one of my vendors to 3d scan a set of heads for me but they have been slammed. They already have a simple work project for me that I dropped of 3 months ago they haven't even started
#36 | |
Drives: 2022 GR86
After all that "FA24 will have higher compression ratio, bad for FI!!!11" thingy, then the inconsistencies in the online configurator, I don't think we should trust the data in a just-updated parts catalogue too much... |
#37 |
Drives: 2015 FR-S
OCV parts reused / superseded
2022 FA24 will be using FA20 OCVs it looks like
Very interesting that there's 2 family of OCVs that can be used on FA20s 10921AA241 (superseding 10921AA240) 2015-2021 Brz , forester,wrx 10921AA231 (superseding 10921AA220,10921AA230) 2013-2022 the -231 part is actually the one called out on the TSB but the -241 apparently can also be used. 2015+ vehicles can use either it seems but 2013-2014 can only use -231 |
#38 |
Drives: WR Blue Pearl 2022 Subaru BRZ
Will the 2015+ diff final drive work with the new cars?
Potential that is a part I'd be interested in. |
#39 |
#40 | |
So would it be worth taking a chance on I wonder, or would there be a genuine part incompatibility, not just a 'spec' incompatibility (meaning it would fit but make your car out of spec). |
#41 | |
#42 |
Drives: GR86
Didn't see anything on fog lights...this makes me sad.
| TRD Catalogue | Salemate | Canada Classifieds | 14 | 12-26-2015 12:15 AM |
| Definitive JDM AERO Catalogue (updated frequently) | BPAuto | Exterior Parts - The Rest | 414 | 12-02-2015 02:53 PM |
| Hyper Rev magazine - basically a massive parts catalogue. | diss7 | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 01-18-2014 12:26 PM |
| KT Auto Works - Grazio & Co Catalogue - Coming Soon | m0nty | Australia Classifieds | 27 | 09-15-2012 08:14 PM |
