Old 09-23-2021, 03:07 PM   #1
gpvecchi
gpvecchi's Avatar
How to seal tail lights?
I'm doing a custom mod to my tail lights.
Can you please suggest what product to use to seal them?
I read of 3M Weatherstrip, but I'm in EU and it's not available here.
Thanks!
Old 09-23-2021, 04:02 PM   #2
Purist
Purist's Avatar
Drives: Subaru BRZ
Doesn't have to be 3M. Self Adhesive weatherstrip and/or trim adhesive.
Alternatively cut your gaskets out of closed cell foam and use trim adhesive.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
gpvecchi (09-24-2021)
Old 09-24-2021, 03:15 AM   #3
gpvecchi
gpvecchi's Avatar
I don't think that foam can seal tail lights that had been cut.
Old 09-24-2021, 03:57 AM   #4
Purist
Purist's Avatar
Drives: Subaru BRZ
Can you post a picture of what you've done with your lights?
Less More
Old 09-24-2021, 02:56 PM   #5
gpvecchi
gpvecchi's Avatar
They are still unfinished, I'll post a pic as finished!
Old 09-24-2021, 04:29 PM   #6
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
I think he was more interested in a pic of what you're doing so we can come up with better ways to try and seal it.
It's hard to make suggestions without knowing what's going on.
sharpsicle is offline   Reply With Quote
The Following 2 Users Say Thank You to sharpsicle For This Useful Post:
Busybee (09-27-2021), gpvecchi (09-25-2021)
Old 09-24-2021, 06:49 PM   #7
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
I think a lot of people end up re-heating and use the existing OEM sealant,
Mostly I think because its a total pain in the ass to clean it all out of the groves anyway
Diode Dynamics recommends this stuff, no experience with it personally
https://www.diodedynamics.com/butyl-...p-sealant.html
VIP BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to VIP BRZ For This Useful Post:
Old 09-24-2021, 10:39 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
Thanks!
how did you open them up? cut them open?
generally, i use a clear 2-part epoxy to re-seal assemblies like that.
usually only headlights use butyl rubber as a sealant-- that is reusable and/or can be added to.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
gpvecchi (09-25-2021), Ultramaroon (09-25-2021)
Old 09-25-2021, 03:21 AM   #9
gpvecchi
gpvecchi's Avatar
2 parts epoxy sounds good, butyl tape is usually good for headlights. Thanks!
Old 09-25-2021, 04:22 AM   #10
Purist
Purist's Avatar
Drives: Subaru BRZ
I'm really keen to see what you've done man. Make sure you post some pics when it's finished.
Less More
Old 09-25-2021, 09:18 AM   #11
soundman98
soundman98's Avatar
you just need to stick a screwdriver to it-- if the goops sticky, it's butyl. the reverse light is sealed with butyl, and some aftermarket tail housings that you could be using could also be butyl.
but for one reason or another, most places like to plastic weld tail lights instead.
gpvecchi (09-26-2021)
FS: TOMS USDM DOT Tail lights, 2017+ OEM Tail lights (SoCal) sleepypony Exterior Parts (Aero, Lighting, Etc.) 15 11-10-2021 08:39 PM
TOM'S Racing JDM LED Tail Lights , Spyder LED Tail Lights, and JDM Side Markers!! Evasive Motorsports Exterior Parts - Lighting 94 12-18-2015 01:19 PM
WTT OEM tail lights practically new for Spyder V2 tail lights smoked red KungFuWaffle Exterior Parts (Aero, Lighting, Etc.) 1 06-10-2015 12:26 PM
BEWARE when installing aftermarket tail lights, you must seal the area ! Kayzer Soze Cosmetic Modification (Interior/Exterior/Lighting) 5 08-27-2013 01:52 PM
