Old 09-18-2021, 01:02 AM   #29
It can last for quite a while before it shits the bed, especially if the rest of the engine is clapped out enough to make only a fraction of its rated power. That was the case for my Eclipse. I never let the oil get too nasty from all the blow-by and it just ran and ran. Had the head off a few times and it was always nice and clean. I drove it for almost 300 Kmi.
Old 09-19-2021, 06:59 PM   #30
OwlDance
Drives: Halo 86, '19
Originally Posted by Sniepster View Post
I am also quite perplexed as to how would this happen. It is 5w40 after all, not a thick-ass 10w60 racing oil.
Just because the oil doesn't feel much different than a lighter oil to the fingers doesn't mean it's working the same for something rotating dozens of times per second with sub mm clearances...
OwlDance is offline   Reply With Quote
Old 09-19-2021, 10:56 PM   #31
radroach
Drives: car
Probably your clutch throwout bearing.
Old 09-20-2021, 10:15 AM   #32
Sniepster
Drives: 2013 Toyota 86
No, that was changed relatively recently along the clutch fork and the pivot.
Not the same sound either.
UPDATE: I have changed the oil to a 5w30, i will let the car sit for at least a day and see if the sound is still there (or if it sounds just as bad). Fortunately the old oil does not seem to have metal particles in it. But i'll be conducting a UOA anyway.
Sniepster is offline   Reply With Quote
The Following User Says Thank You to Sniepster For This Useful Post:
Ultramaroon (09-20-2021)
Old 09-21-2021, 02:04 PM   #33
radroach
Drives: car
May be your fuel quality. The couple times I've had a starting rattle was from low fuel and old fuel.
Other thought is maybe let your fuel pump prime for a second before turning the key.
Old 09-23-2021, 05:23 AM   #34
Sniepster
I only put 100 RON gas in it, pretty much the most premium you can find around in Romania. I believe it equals to 95 Pump to you guys across the pond.
UPDATE: The knock is still there but definitely less noticeable and goes away much faster after a cold start. In 3 weeks tops i should have my UOA results from Blackstone, fingers crossed!
Old 09-23-2021, 10:33 AM   #35
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I'd honestly use a 0W-30 for maximum cold protection (least viscosity while cold and still provide 30 weight hot protection).
Old 09-23-2021, 01:45 PM   #36
Old school band-aid is to use something thick like a straight-weight. @humfrz will back me up on the sawdust scheme. Quiets down the engine for a while.
humfrz (09-23-2021)
Old 09-23-2021, 02:44 PM   #37
Oh yes, just before you sell a clunker, fill the crankcase with as heavy of oil that will go down the filler tube.
Yes, a handful of sawdust will help quiet the engine down. Sawdust is really effective at quieting a rear differential down (and transmissions, before they synchronized them).
Ultramaroon (09-23-2021)
Old 09-24-2021, 04:31 AM   #38
Sniepster
Whilst browsing on YT i found this vid:
I think it's remarkable the engine in the video sounds EXACTLY like mine at cold start, same sound and same duration.
Do you guys think the VVT could be at fault for my sound also? I'm thinking since the oil acts as a hydraulic fluid for the VVT system it might've shit the bed by being too viscous, especially considering that our VVT system is quite similar to the one in the video above:
Ultramaroon (09-24-2021)
Old 09-24-2021, 01:21 PM   #39
Different sound, unfortunately. Your's isn't a top-end rattle. It's a deep knock from only one rod.
Haha.... Brother's underwear and toothbrush.
NoHaveMSG (09-24-2021)
Old 09-24-2021, 05:41 PM   #40
FrickingReallySlow
Drives: 2015 FR-S
I watch this guys channel extensively and sometimes his wife’s scarf makes an appearance...haha. His takeapart of the subaru boxer and why it fails is also a good watch. He buys notable seized engines like k20, VR30, FA20 and his bro’s toothbrush points out at all the potential problems
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
Old 09-24-2021, 07:32 PM   #41
That's some good schtick. Thanks for mentioning it! I like how he locks into the subject and stays out of the frame. Looking forward to more of his stuff this weekend.
Old 10-11-2021, 04:57 PM   #42
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It's early rod knock. Takes a couple seconds for the oil to pump up and hit the bearings from a cold start. Relying on thin film lubrication until then, and it's when worn journals will be most obvious.
Sorry. Sucks.
I can attest to this... I had a Camry that had "baby knock" on cold start for many many miles, until one day it decided it was time to let go and tansitioned to full on knock....
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Ultramaroon (10-11-2021)
Cold cold(under 30dg) start sounds super weird vladniko86 Engine, Exhaust, Transmission 9 11-19-2020 10:08 PM
Question about cold start knock, battery radroach Issues | Warranty | Recalls / TSB 24 12-17-2016 09:24 AM
(Spark?) Knock on cold start idle nickw14 Software Tuning 0 04-07-2015 01:41 PM
LOUD KNOCK during cold start Flat_4_Life Issues | Warranty | Recalls / TSB 23 03-18-2015 06:30 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
