Old 09-15-2021, 05:02 AM   #1
Sniepster
Drives: 2013 Toyota 86
Cold start knock
So this summer my car started making a really strange knocking sound at start-up/cold start. It sounds like a knock however it only happens for half a second then goes away and the engine sounds absolutely normal. The sound is present ONLY if the car has been sitting for at least a day, so I am guessing it has something to do with the oil.
The car runs fine otherwise, no smoke coming out the exhaust and no other strange sounds coming from the engine.
Also there's no mods done to the engine other than a K&N air filter.
I ran the car during winter and it didn't make this sound, so i doubt it's due to temperatures.
The car has received regular oil changes at around 3500 miles. It has been running Motul 300V 5w40 for 40.000 miles.
Here's a link to how it sounds from inside the cabin:
Sniepster is offline   Reply With Quote
Old 09-15-2021, 10:48 AM   #2
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Have your checked your oil level?
Dzmitry is offline   Reply With Quote
Old 09-15-2021, 12:59 PM   #3
Sniepster
Yeah, oil level has been full ever since the last service, no oil consumption whatsoever.
Old 09-15-2021, 01:06 PM   #4
Dzmitry
Dzmitry's Avatar
Has it been doing this since your last oil change? Could be a few things... assuming you don't beat the engine to absolute death regularly, it's likely not worn parts or anything.
Could be your valve lifters.
How about your oil filter, is it OEM spec or something else?
Old 09-15-2021, 01:17 PM   #5
Sniepster
Last oil service was in March, about 3000 miles ago. I first started hearing this sound in July, so i'm not sure the two correlate. One notable thing from my last service is the fact that the shop overfilled my pan with oil, not by a lot, but they did overfill it.
And no the car does not get beat on that much, it has only seen a track day so far this year.
Oil filter is an aftermarket Mann oil filter, the skinnier, elongated type.
Old 09-15-2021, 01:31 PM   #6
Dzmitry
Dzmitry's Avatar
Oil overfill could be bad from what I've read in the past, but that depends on how much they overfilled. It can actually reduce the oil flow to certain parts, which could certainly cause the sound you describe. If nothing is new about the oil filter or oil weight used, I would doubt it's the culprit. But you could try a lower weight oil for better flow on your next oil change and see if it stops. In general, it might be worth changing out your oil with your situation to see if anything changes, because there are very few things that can make that sound other than internals, at least for the quick duration that you hear it at.
Old 09-15-2021, 01:34 PM   #7
Dzmitry
Dzmitry's Avatar
Here is a quick writeup about the negative with oil overfill.
https://www.cars.com/articles/what-h...th-oil-433476/
Old 09-15-2021, 01:51 PM   #8
WNDSRFR
Drives: FR-S,GTI
Maybe your oil is too thick?
Toyobaru says to use 0-20.
Old 09-15-2021, 02:14 PM   #9
Sniepster
Or 5w30, which is the recommended grade for heavy usage.
I do agree 5w40 is a step-up, but it has run it for 40.000 miles. I doubt that's the problem
Old 09-15-2021, 02:15 PM   #10
Sniepster
I was planning on going down to 5w30 for the next service. Let's hope the issue goes away by itself.
Old 09-15-2021, 03:08 PM   #11
Dzmitry
Dzmitry's Avatar
Yeah I'd report back when you change the oil to a lower grade. The sound is certainly not pleasant, and nor is it doing any good to your internals, if anything it is speeding up wear, so you don't want to prolong that too much.
Old 09-15-2021, 03:16 PM   #12
humfrz
Good plan - keep us posted -
Old 09-15-2021, 04:42 PM   #13
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's early rod knock. Takes a couple seconds for the oil to pump up and hit the bearings from a cold start. Relying on thin film lubrication until then, and it's when worn journals will be most obvious.
Sorry. Sucks.
Old 09-15-2021, 08:21 PM   #14
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Probably off base, but I had a bad harmonic balancer on my pickup's straight 6 make a similar sound. Wouldn't hurt to check.
Cold cold(under 30dg) start sounds super weird vladniko86 Engine, Exhaust, Transmission 9 11-19-2020 09:08 PM
Question about cold start knock, battery radroach Issues | Warranty | Recalls / TSB 24 12-17-2016 08:24 AM
(Spark?) Knock on cold start idle nickw14 Software Tuning 0 04-07-2015 12:41 PM
LOUD KNOCK during cold start Flat_4_Life Issues | Warranty | Recalls / TSB 23 03-18-2015 05:30 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
