| Software Tuning Discuss all software tuning topics. |
Cruise Knock Issue
Hello all,
I am having an issue with knock at cruise but none any reoccurring at WOT. I've sent countless logs to my tuner and we have tried to pull timing at those areas but it seems that the cruise knock (knock corr. + flkc) continues to come back. I've ensured that there is nothing in my engine bay that could be causing this knock reading. I do want to mention that I do not recall this happening during Fall / Winter times last year. I do live in south Florida, so the heat could be the cause of the issue, but then again, the intake comp table should take care of this. Something important things to note is that this problem occurs on 93 + e85, I have never seen flkc or knock corr. be any less than -2, my car is tuned via OFT, and it does not always happen. I have had a hard time recreating this issue while the motor is cold during cruise. If you could please take a look at the following logs and let me know how to troubleshoot this / let me know if this is something to even worry about I would greatly appreciate it! Logs: EDIT: FP + OP is this close to sway bar. Not sure if it would have that much play, however. Last edited by gm5oh; 08-24-2021 at 09:28 PM. |
#2 |
Drives: FT86
very likely that knock may be due to mechanical rattle or vibration of exhaist on chassis or skid plate fooling knock sensor
Pull 5 degrees out of the entire base b timing map if knock doesnt change then its very likely rattle vibration problem its a common issue if the knock goes away with 5 degrees out of the map then likely fueling ignitin timing issue |
#3 |
Drives: UK GT86
TBH if it's at cruise then it's not really an issue, not enough cylinder pressure. It's almost impossible to completely stop any form of knock correction triggering and you can ruin the feel of the car doing so. Let the ECU pull timing if it wants in lower load, that's what it's designed to do.
.: Stealth 86 :.
#4 |
Thank you, I'll reply again soon when / if I find a solution.
#5 | |
Note: Before I got an oil cooler, after doing some light pulls I would get to oil temps of upwards 240+ degrees Fahrenheit. It wouldn't take me any more than 3 minutes driving to get to 185 degrees Fahrenheit. Tagging @Kodename47 so he sees this too. What do you guys recommend? I was thinking of wrapping my OP + FP in header wrap, but I am hesitant that my OP / FP could crack. Please let me know what you think |
#6 | |
Drives: FT86
| Cannot solve transient knock issue high RPM when letting of throttle (boosted) | brosifSmith | Software Tuning | 6 | 07-10-2020 11:07 AM |
| Engine Knock sound issue | nos145 | Issues | Warranty | Recalls / TSB | 65 | 10-20-2019 04:57 PM |
| FML: Tired of the same old coil pack issue? Enjoy your new rod knock... | Yigal.K | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 07-31-2018 04:25 PM |
| Issue: Cruise Control no bump up or down | bcj | Issues | Warranty | Recalls / TSB | 4 | 06-13-2016 05:40 PM |
| CEL and Cruise Issue??? | mortybryant | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 03-23-2015 01:49 PM |
