Old 09-15-2021, 01:44 PM   #1
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Exhaust hanger failure?
I dropped my exhaust coming through the Watkins Glen Bus stop. Three aftermarket PU hangers of unknown provenance had gotten hot, stretched, cracked, then failed completely. Thereafter the two remaining (autozone) hangers failed. Mechanics wire got me through the rest of the event, and the drive home.
Trying to decide whether OEM hangers will be enough or if I should take this opportunity to reinforce. Anyone else have issues to report or recommendations?
Thanks.
gcranston is offline   Reply With Quote
Old 09-15-2021, 01:54 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Maybe try an aftermarket one from a big name? The Cusco 12mm ones fit really nice and snug on my Greddy catback. MUCH tighter than the oem ones.
Old 09-15-2021, 02:19 PM   #3
StraightOuttaCanadaEh
Wes
I use the Subaru JDM hangers which I got from Blackhawkjapan
Haven't heard much about the Perrin hangers but they're also available
Instagram: @gt86ws
Old 09-15-2021, 06:27 PM   #4
MX-5RACER
MX-5RACER's Avatar
Drives: 2018 FA24 SWAP BRZ "ANNIE"
Stay away from the urethane hangers, they get hot and fail. I had this happen on my track Miata and it caused my header to crack as the entire weight of the exhaust was hanging on the header. That drive home SUCKED! It was basically an open header and I had to drive from Sebring home to Ft. Lauderdale (2.5 hours). I had to stop and get ear plugs.
DJ
2008 MX-5 PRHT "Violet"
2018 FA24 Swap BRZ "Annie"
MX-5RACER is offline   Reply With Quote
Old 09-15-2021, 06:49 PM   #5
I haven't heard of this. So weird. Is all the tension on one hanger even though the others are all engaged? That could do it.
...or yeah, urethane
Old 09-15-2021, 08:15 PM   #6
Yoshoobaroo
TRACKBREAD
My problem with the Greddy catback on the stock hangers was that the little bumps at the ends of the hanger rods were way too small to not slip through the OEM hangers in turns. I ended up putting some hose clamps on the rod ends until the Cusco mounts came in.
Old 09-15-2021, 08:55 PM   #7
femaledog
Drives: 2017 BRZ Perf. Pkg.
https://www.ft86club.com/forums/showthread.php?t=72867
Never happened to me, but I hope it won't.
femaledog is offline   Reply With Quote
Old 09-16-2021, 06:29 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'm still on factory exhaust hangers at 56k miles and buncha track days.
Weren't your hangers a somewhat misaligned with the exhaust? That could be the root cause...
I think at some point, possibly between 2013 and 2015, relative positions of hangers may have changed a bit so possibly related to 2015 engine swap? Guessing here...
You should post up pics of drive axle boot repair if you have em!
Great that we both made the TT and drive home despite "issues"
Old 09-16-2021, 09:04 AM   #9
gcranston
Yeah I saw that post too. The E-clips aren't a terrible idea, but my problem wasn't the hangers falling off; they actually tore.
Thanks.
Old 09-16-2021, 09:07 AM   #10
gcranston
Yeah, a little more excitement than I'd like. For the confused readers out there, what I didn't mention in the original post was that the exhaust ripped a hole in the CV boot on it's way down/drag back to the pits. Turns out I have spare axels from the rebuild so that shouldn't be an expensive fix.
I do need a section of exhaust pipe welded in to replace the flat-spotted part and I figure that can just be made a little longer to fix the hanger alignment. Collecting quotes...
Old 09-16-2021, 09:08 AM   #11
gcranston
It was the polyurethane ones that failed first.
Old 09-16-2021, 09:08 AM   #12
gcranston
Those look beefy. I'm intrigued...
Old 09-16-2021, 09:35 AM   #13
Wes
they feel just as beefy as the stock ones, but the thing in the middle does a good job of absorbing vibrations and reducing drone being telegraphed to the cabin. Noticeable difference. I replaced all 5
Instagram: @gt86ws
Old 09-16-2021, 10:45 AM   #14
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
I'll be doing a full boot replacement and repack video next week.
2023 GR Cup Car
Opie is offline   Reply With Quote
Exhaust. My biggest failure. grumpysnapper Engine, Exhaust, Transmission 14 03-23-2021 07:40 AM
FS: Torque Solutions Exhaust Hanger Kit skylinekin Engine, Exhaust, Bolt-Ons 1 09-08-2018 12:34 PM
Exhaust hanger Eighty Scion FR-S / Toyota 86 GT86 General Forum 17 11-06-2015 04:19 PM
HELP: Stock Exhaust Hanger measurement LeeMaster Cosmetic Modification (Interior/Exterior/Lighting) 4 01-12-2014 02:25 PM
Know size and thread of the bolt to the exhaust hanger? JiB Engine, Exhaust, Transmission 4 06-20-2013 09:37 AM
