Old 09-14-2021, 11:11 PM   #1
BrZ_Good
Drives: '13 BRZ Ice Silver Metallic
Spark plug tube fail
130k mile 2013 brz. Spark plug gasket on cylinder 4 is leaking on plug and coil pack, shorting the connection causing spark plug tip to explode.
Update: pulled engine this week. I guess material on plug tube gasket just wasn’t thick enough to seal. Cleaned up and reinstalled. Used much less rtv than the factory. Looks like it was even on the cam lobe in last pic
BrZ_Good is offline   Reply With Quote
Old 09-15-2021, 12:26 AM   #2
Now THAT is ugly -
Bubba suggests you put a new spark plug in there.
Then check the other plugs to see if they are tight.
Old 09-15-2021, 02:26 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ummm. Hopefully all the pieces escaped and there is no engine damage. You MAY be able to replace the valve cover gasket and spark plug tube gasket without pulling the engine but it will be a PITA.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
alphasaur (09-15-2021), Dzmitry (09-15-2021), Opie (09-15-2021), Ultramaroon (09-15-2021)
Old 09-15-2021, 05:54 AM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Maybe jacking up that side of the engine by pulling the bolt on the mount would help.
The Following User Says Thank You to RToyo86 For This Useful Post:
NoHaveMSG (09-15-2021)
Old 09-15-2021, 08:43 AM   #5
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
My gasket failed when I lost a rocker arm. When I pulled the plug to initially diagnose the "misfire" the tube was full of oil. Didn't understand why until I pulled the valve cover. BTW: My rebuilt engine is in the car and I get my cleaned injectors back on Friday. I might actually have a running car over the weekend.
The Following User Says Thank You to blsfrs For This Useful Post:
Old 09-15-2021, 11:22 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I would undo both motor mounts, lift the engine up by the oil pan till the motor mounts clear the cross member, and push it over to one side(make sure you don't knock the engine off the jack). Alternately you could also remove the motor mounts off the block so you could mess with the height to get the most space, but I am pretty sure lifting up will get you the most. That is how I did my brothers Forester. The issue with the FA is they use a bit of sealant on the valve cover gasket. So you would have to scrape that off, clean up, and reapply in that little space trying not to get any of the old stuff into the head. It's a PITA. 6 beer job, 4 while working, 2 for after while you are putting your tools away. If you have the equipment, it takes about the same amount of time to just pull the motor, fix, reinstall.
blsfrs (09-15-2021)
Old 09-15-2021, 11:45 AM   #7
BrZ_Good
Preciate the input fellas. I’ll make sure I’ll have the beer money before starting this one. Probably gonna unbolt motor, tilt and rock it. Do these valve covers have a gasket? Or am I gonna have to bob ross some sealant? I’ll change the set of tube gaskets. Needs new plugs anyway, changed once at 75k.
Only other knuckle buster was tob at 86k.
Threatened to break up with her, but, I can’t…
The Following User Says Thank You to BrZ_Good For This Useful Post:
blsfrs (09-15-2021)
Old 09-15-2021, 11:47 AM   #8
BrZ_Good
Oof. Congrats tho dawg
blsfrs (09-19-2021)
Old 09-15-2021, 11:51 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There is a gasket for the perimeter, and for the spark plug tube, but it uses sealant too in a couple spots.
SPARK PLUG GUiDE! Kojiap1 Engine, Exhaust, Transmission 15 04-13-2022 01:30 PM
DIY: Spark Plug Change thekevinvo DIY (Do-It-Yourself) Guides 22 12-15-2020 04:41 PM
Spark Plug Options? BRZach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 08-18-2017 12:14 AM
Spark plug failure BRZ68 Issues | Warranty | Recalls / TSB 9 06-12-2017 07:44 AM
Spark plug question Wilsonk227 BRZ First-Gen (2012+) — General Topics 19 07-03-2013 12:57 AM
