Old 09-13-2021, 01:41 PM   #4271
localhost
Drives: Edelbrock SC 2015 FR-S 6MT
Better fuel will be your answer.
Agreed - the fuel up here in Canada is honestly pretty bad. That said, that was basically half the reason for installing the meth injection - we should be increasing the octane rating of the fuel fairly significantly to the point it should be almost like race gas (according to my tuner at least).
Maybe it's placebo but I'm noticing that my supercharger is almost uncomfortably warm to the touch now after an extended drive. Before the added boost and meth, I could keep my hand on top of the unit and it'd be warm but not uncomfortable. Now I don't think I could keep my hands on it for longer than a few seconds.
Also, I don't know if this placebo on top of placebo, but the car seems significantly more eager and torquier when it's both cold outside and it hasn't warmed up yet. After I've been driving for a bit, it doesn't feel nearly as torquey as it did when everything was cold - I've noticed this mostly in third gear but second seems like that too.. I'm starting to wonder if that's really a heat soak issue or if I'm just imagining things. Maybe a vented hood might help?
localhost is offline   Reply With Quote
Old 09-13-2021, 01:54 PM   #4272
CSG Mike
CSG Mike's Avatar
Add heat exchangers and heat extraction.
Old 09-13-2021, 02:37 PM   #4273
localhost
Any ideas/suggestions on the best way to do that?
Old 09-13-2021, 02:59 PM   #4274
CSG Mike
CSG Mike's Avatar
You'll want to consult with the shop that did your installs, as they'll be more familiar with your engine bay.
It's difficult to make blind recommendations, as this is not a plug and play solution.
Old 09-13-2021, 04:21 PM   #4275
FrickingReallySlow
Drives: 2015 FR-S
The $0 method: Turn on your heater to the max and sweat a bit you're helping to lower your coolant temp
FrickingReallySlow is offline   Reply With Quote
Old 09-13-2021, 04:42 PM   #4276
CSG Mike
CSG Mike's Avatar
That has nothing to do with charge temps.
Old 09-13-2021, 08:22 PM   #4277
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Increase airflow to your heat exchanger, baffling, increased cooling system capacity (expense of weight) add thermal gaskets between your intake runners and the supercharger.
B T is offline   Reply With Quote
Old 09-14-2021, 02:13 PM   #4278
CSG Mike
CSG Mike's Avatar
How do you do that when it's all 1 assembly?
Old 09-14-2021, 04:14 PM   #4279
B T
I took it apart and reassembled. The runners are held on with hex socket bolts underneath and come off pretty easily.
https://photos.app.goo.gl/omA79aiukqDGgnbA6
Old 09-14-2021, 04:26 PM   #4280
CSG Mike
CSG Mike's Avatar
Do you have before/after temps? I find it unlikely that there would be a significant change, given the temperature of everything involved!
I've heard that adding a second heat exchanger can significantly drop temps though.
Old 09-14-2021, 05:04 PM   #4281
B T
In fact I do! I wouldn't have pulled it to do this mod alone, it was out due to the engine blowing. It seemed to enable it to recover from heat soak a little faster (very little) and lowered my IAT by about 2-3 degrees. Negligible gains, but I figured I'd give it a shot. The goal was to just keep the heat from the head reaching the large flat area at the top of the supercharger. I was really hoping to find some kind of thermal insulating gasket for between the heads and runners originally, but gave up on that. Adding the larger reservoir to the system also dropped my IATs slightly, totaling around 4-6 degrees F in all.
Just an edit, I ended up using Fel-Pro Karropak material gasket maker. Ordered a few things before settling on this. Got it off Summit.
Old 09-15-2021, 12:57 AM   #4282
dpfarr
Drives: BRZ ts
Originally Posted by brandonblt2 View Post
Just make sure you line up the markings on the fuel pump lid. And make sure the gaskets are installed in the fuel injectors. I had a gasket missing on one of my injectors and it throw gasoline all over my engine bay. My whole house smelled like gas for the rest of the day
Thankfully my garage is detached because I fired it up and there was a leak.
dpfarr is offline   Reply With Quote
Old 09-16-2021, 12:56 AM   #4283
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Originally Posted by Aztec View Post
How does everyone's car sound once warmed up and idling?
I am getting an odd sound that seems out of place. My idle is around 900rpm
video for reference: https://photos.app.goo.gl/wCJwbXMPAy9Rhikj6
Thanks!
Should sound similar to stock.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 09-19-2021, 01:48 AM   #4284
dpfarr
Drives: BRZ ts
Motherfucker. What a shit show.
I bought a used kit w v1 delicious ff and had a few hiccups. Missing some coolant tb tubing. “Oh you don’t need those, they’re for cold climate.” Took Edelbrock a couple weeks to get them to me.
Had to modify my alternator.
Was missing the connector to the fuel pump, had to wait a week for a new sock and connector. Just finished putting in the fuel pump and flashed the ECU.
Now it won’t start. Where it previously started w oem fp and no tune.
I can hear the fp run when I turn on before starting. I did a 10+ on and off hoping the fuel pressure would normalize (or get enough to start). Nothing though. Any advice on how to test this fuel pump? Swap the stock one back in?
It’s been a month plus and I wholly fucking regret buying some dudes used shit.
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
