Old 09-10-2021, 01:52 PM   #1
Akatzu
Drives: 2014 Scion FRS
Aftermarket Calipers close to OEM?
I want to change the calipers on my frs for looks wanting to powder coat them teal. Every forum I've looked into either has an sti brembo swap or bbk kit. Wondering if there are any aftermarket break kits that replace all 4 calipers, I'm not interested in any company in particular as long as it's good quality same or slightly better than oem. I do a good bit of spirited driving but also want a little bit of flare. Also BBK from the brake thread I read causes clearance issues with some wheel set ups. Any help is appreciated, thank you.
Akatzu is offline   Reply With Quote
Old 09-10-2021, 03:00 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Why not just buy a set of OE equivalent calipers from someplace like rock auto, and have them powder coated.
Old 09-10-2021, 04:04 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I think OP wants monoblocks for looks. I can’t think of any aftermarket monoblock sets that aren’t really hardcore BBKs.
This is an option: https://www.fastwrx.com/products/sub...pgrade-frs-brz
Still need more spoke clearance than stock wheels provide I think. You’ll need a spacer up front.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
NoHaveMSG (09-11-2021)
Old 09-10-2021, 09:06 PM   #4
norcalpb
norcalpb's Avatar
These are another option:
https://www.rr-racing.com/RR-Racing-...gt86fbk005.htm
I’ve heard iffy things about wilwoods on track (metal deforming), but if you’re not tracking these are probably what you are looking for.
Old 09-10-2021, 10:34 PM   #5
Akatzu
@Yoshoobaroo that is exactly what I was aiming for not a BBK as I won't be tracking the car for a couple of years and with my future plans of FI being between 270-310 hp from what others have sad in the forums I don't need 18 but I was thinking of 17x9 maybe between titan TS-r or Volk racing te37 @norcalpb those are also an exact match to what I was looking for slightly leaning towards this one since it comes with everything needed.
Not sure which one I can run without spacer, also not breaking the bank. Giving the girl a refersh now that she is reaching 100k miles.
Old 09-11-2021, 11:02 AM   #6
DarkSunrise
DarkSunrise's Avatar
I'd say it's the opposite with the Wilwoods, they're more of a track oriented setup. I'm using RR's stage 2 kit (Superlite forged 6r caliper) and it can be difficult finding a pad that won't squeal on the street. I think the caliper is so light that there's just not a lot of mass to dampen the squeal. Combined with the lack of dust boots and it's not a friendly street setup IMO, more of a budget track setup.
On the plus side, I've had zero issues with mine on the track and this is probably the cheapest BBK from a consumables standpoint ($80 trackable/progressive Wilwood pads + $80 Centric blanks).
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Teseo (10-10-2021)
Old 09-11-2021, 05:11 PM   #7
Akatzu
@DarkSunrise I see anything you would recommend for a more street/spirite driving. Since I am changing the brakes all together wanted to get some nice monoblock colored calipers thinking the yoshoo linked might be the ones I may need to get. Just not sure about fitment for wheels since he mentioned I may need spacers, I am running stocks wheels atm.
Old 09-11-2021, 07:39 PM   #8
DarkSunrise
At a first glance (and without having tried them), those look like they could be a good choice for what you're looking for. If I'm not mistaken, those are the OEM Subaru calipers from the 06-07 WRX. That means they should be reliable, quiet, and have dust boots so a good street setup. Just be aware those don't actually upsize the rotor so they're not so much a BBK as a caliper upgrade.
Lastly you should look into whether those would change the brake bias.
2022 BRZ Build
2013 FR-S Build
Old 09-11-2021, 11:18 PM   #9
Akatzu
@DarkSunrise that was one thing I was thinking about was the brake bias it was mentioned a couple of times when I researched finding close oem monoblock calipers. A lot of the previous post mentioned track which led to either better pads. How would I find out about the brake bias? The subaru one only has 1 review
Old 09-11-2021, 11:32 PM   #10
Yoshoobaroo
TRACKBREAD
There’s some info floating around on them. As far as I can tell, but not confirmed, they shift the brake bias slightly forward, and you need a ~7+ mm spacer up front on stock wheels.
They actually decrease clamping force on the rear and offer no extra thermal mass so don’t expect any performance increase whatsoever. For performance you’re much better off with pads and fluid.
Old 09-12-2021, 12:09 AM   #11
Akatzu
I'm beginning to think what I want to do is rather difficult without buying some crazy expensive BBK
Old 09-12-2021, 12:26 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
How about painting stock calipers?
Old 09-12-2021, 01:13 AM   #13
DarkSunrise
I think your safest bet might be finding used performance pack brembos.
2022 BRZ Build
2013 FR-S Build
Old 09-12-2021, 07:50 AM   #14
Yoshoobaroo
TRACKBREAD
They’re typically barely cheaper than new parts, and you can’t fit those under stock wheels either.
Knives’s Aftermarket & OEM Parts Hoard: Camber Bolts, Calipers, Shocks & More knives Brakes, Suspension, Chassis 4 01-21-2021 04:30 PM
dual calipers vs big brake calipers Docmattic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 05-30-2017 04:51 PM
(Close)WTB:Aus GT Black interior(Close) Ry.ruzn Want-To-Buy Requests 0 04-20-2016 01:55 AM
How close is too close?: Gap between tire & spring perch kodyo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-20-2015 01:32 PM
Aftermarket Calipers and Stock Rotors Anorexic 86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 12-27-2013 01:08 AM
