Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-01-2021, 01:52 PM   #127
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by timurrrr View Post
So it's a good fit for people concerned about "I live in cold climate and don't want cold oil"?
Precisely, those "factory oil coolers" are really warmers to get the oil temp quickly for emissions and wear purposes.
Old 09-10-2021, 11:08 AM   #128
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Ran into this by accident.
https://www.autoblog.com/2021/09/01/...gdLdOURoyeO7Eo
"The FA24D’s oil pickup system was engineered to the same standards as the FA20D’s. Owners may be aware that the FA20D’s oil pickups can become starved during sustained, high lateral-g maneuvers – what you’d get from pushing the car hard at the track on super-sticky rubber."
I guess it doesn't conclude that exactly, but people might be stuck with that same issue.
Dzmitry is offline   Reply With Quote
Old 09-14-2021, 04:00 PM   #129
OkieSnuffBox
To be fair, most cars aren't designed in mind with what the "purple crack*" will do on track with a quick driver.
* = purple crack meaning Hoosiers. But other RComps are close.
Old 09-14-2021, 04:27 PM   #130
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can oil starve on 200tw street tires and mild suspension mods. It’s really baffling that is needed more then the pickup.
DocWalt (09-20-2021)
Old 09-14-2021, 10:23 PM   #131
slimfit
Drives: ‘22 BRZ
Sounds like Killer B Motorsport might be getting this gen BRZ. They make great options for oil pick ups and baffles.
slimfit is offline   Reply With Quote
Old 09-15-2021, 01:35 AM   #132
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They have yet to make a baffle for an FA motor and their QC is not very good. I bought one of their pickups and it was way too long to use. Another member on here said he talked to IAG about using one of their pickups on his built short block. They didn’t recommend it due to “QC issues.”
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Dzmitry (09-15-2021), slimfit (09-15-2021)
Old 09-16-2021, 06:27 AM   #133
geraldjust
Drives: MR2, Sliver BRZ
It does look like the new engine has a oil to water cooler on the filter. i think the baffling looks similar with small changes.
File Type: pdf BRZ 22MY PubNo_ G4600BE Version_ 002 LUBRICATION.pdf (7.50 MB, 197 views)
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
The Following User Says Thank You to geraldjust For This Useful Post:
Stonehorsw (09-16-2021)
Old 09-16-2021, 08:33 AM   #134
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
These are effectively engine oil temperature stabilisers: Warm up faster, then remain at the desired temp longer.
That is a very desirable property for both the engineer, the epa and you, and now that you've got stable temperatures it's up to you to use the correct viscosity for your use case. And if by chance your needs include 10W60 and an external cooler, there's no way a 30k street car will meet your needs out of the box.
The Following User Says Thank You to RZNT4R For This Useful Post:
Yoshoobaroo (09-16-2021)
Old 09-16-2021, 09:38 AM   #135
s30series
Drives: 2015 BRZ Series.Blue
Is it me, or is that oil pickup tube different than the FA20?
s30series is offline   Reply With Quote
Old 09-16-2021, 11:44 AM   #136
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It looks very different. The FA20 has the oil pickup bolting to a downward facing flange cast into the upper pan assembly that transfers to the front cover. The FA24 looks to have eliminated the cast part of the upper oil pan and is more direct to the front cover.
Dzmitry (09-16-2021)
Old 09-16-2021, 02:55 PM   #137
OkieSnuffBox
In day-to-day use, yes. But notice the title of this thread.
Old 09-16-2021, 05:17 PM   #138
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah, about that title...
If you bought a $100k C7 Z06 and it went into limp-mode due to 320F indicated oil temp a few laps into a track event, yeah, I'd call that a "track day oil temp problem".
When a $28k FT86 has 275F max oil temps during a track day, and doesn't go into any limp-mode but keeps right on trucking without oil temp going any higher, that's not any "track day oil temp problem". It does mean you should think about using higher-viscosity synthetic oil though.
Old 09-16-2021, 06:36 PM   #139
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
From the 2022 BRZ manual, recommended engine oil.
Looks like not much has changed.
The Following User Says Thank You to timurrrr For This Useful Post:
Dzmitry (09-17-2021)
Old 09-16-2021, 06:47 PM   #140
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Don't Bother with US manual, I'm pretty sure the japan Manual will probably tell you to stuff 5w-40 in it if you are going to track it like the old manuals.
The Following 3 Users Say Thank You to chaoskaze For This Useful Post:
DocWalt (09-20-2021), Dzmitry (09-17-2021), ZDan (09-16-2021)
Water Temp problem dejxx Forced Induction 10 07-29-2015 02:26 AM
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
