#127 |
Drives: 2022 MT Neptune GR86 Prem.
| The Following 3 Users Say Thank You to CincyJohn For This Useful Post: |
#128 | |
Drives: '12 C63 P31, '23 GRC
![]() Also I would agree that the base brakes are more than up to the task of track duty (with proper pads and fluid). However, the bigger brake (option) makes sense for long term consumable costs and thermal management for someone that tracks often. Certainly the lack of a larger brake option from the factory is a dumb reason to disqualify the car in general.
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#129 |
ProCrastinationConsultant
sometimes, you just don't know till you try!
#130 | ||
Drives: '23 BRZ
#131 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#132 |
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Relative to 2022 OEMs vs "Brembos" / Monoblocks...
Track guys on the stock calipers -- have you not experienced feathering of the pads or caliper spread over time on a non-fixed / floating pin designed caliper? I know the C5 has that problem over time on faster / hotter "brake" tracks. Also, if you are pulling brake pads all the time so your daily pads that are safe, for me, monoblocks are a huge time saver there. If you are also pulling the disc to keep them burnished / matched, not as much. For monoblock calipers (even the Brembos from STi/BRZ I have been using for years), they have been pretty good for those cases and MUCH easier to work on for pad replacement and consistency in braking (less knockback, easy on-site replacement). Might just be me. But, I do prefer / enjoy monoblocks... even more so if we talk about AP Racing solutions, or solutions that allow much deeper pads!
#133 | ||
Drives: 2022 GR86
First properly turn guide pins from under the bumper, then it's easy to put the safety pins from the side of the car by feel. |
#135 | ||
Drives: '23 BRZ
Pins should install from the outside/front face of the caliper! |
#136 | |
Drives: 2022 GR86
So that every 10 year old can pull them out while passing by your car? |
| The Following User Says Thank You to timurrrr For This Useful Post: | gen3v8 (09-08-2021) |
#137 |
Drives: Crapcan
On the fronts, yes. Rears, not an issue.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | dowroa (09-08-2021) |
#138 | |
Drives: '23 BRZ
That's still gonna be a no-go, friction is a thing with mine. A couple/few taps with ye olde 3mm punch is super easy and then I can pull them out.
I mean, if you're worried about that, you should also worry that 10 year-olds will carry a wrench around and remove 3 lug nuts from your wheels for funzies. What are 10 year-olds like where you live?! |
#139 | |
Drives: 2022 GR86
Have you tried turning/wiggling the pins while pulling? Works like a charm to me.
#140 |
Drives: '23 BRZ
| Black Brembos or Red Brembos? | Mike_ZN6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 04-30-2021 11:44 PM |
| Other Enthusiasts Suck | ZionsWrath | Off-Topic Lounge [WARNING: NO POLITICS] | 23 | 06-01-2018 07:15 PM |
| American Drivers Suck | ogrowup | Other Vehicles & General Automotive Discussions | 144 | 07-11-2016 10:30 AM |
| All my LED's installed, they suck. | Yruyur | Cosmetic Modification (Interior/Exterior/Lighting) | 26 | 04-14-2013 07:23 PM |
| well this may suck. | Mikes86 | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 12-29-2012 02:35 PM |
