Old 08-24-2021, 02:47 PM   #4229
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Originally Posted by BrahmaBull1990 View Post
Wow! 175k; how many boosted miles?
I boosted it last year. So roughly 12 to 13k miles.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
The Following User Says Thank You to brandonblt2 For This Useful Post:
BrahmaBull1990 (08-24-2021)
Old 08-24-2021, 03:12 PM   #4230
brandonblt2
You tuner can make an educated guess base don logs, but at 175k, it's definitely time to replace it.
Yelp guess I'll be buying an O2 sensor then and checking for any exhautst leaks. Good thing is they're not too bad at about $100 on rockauto.
Old 08-26-2021, 03:41 PM   #4231
JGBtypeR
JGBtypeR's Avatar
Drives: 2015 Scion FR-S
Originally Posted by brandonblt2 View Post
Anyone else tuned with Delicious that has catless headers? Is it normal to have the CEL blink a few times after a reset? I believe the tune is suppressing the P0172 - System too Rich Bank 1. I continuously have this code pop up no matter what after the car warms up. I replaced my fuel pump thinking it was related to that but now I'm leaning towards O2 sensor, possible gasket leak near the headers, or the tune itself.
I added their flexfuel kit this past year and noticed that after I've disconnected+reconnected the battery that I get the CEL blink a few times on that first drive but never again. I went back and looked at my email from when they sent my tune and noticed this part:
VVT Enable Feature – BRZ/FRS/BRZ Platform
We have implemented a triple check engine light blink when the VVT (variable valve timing) is not enabled. This is to inform you that the VVT is not active yet and to not drive hard until this stops.
Granted that doesn't really help with your P0172, but might explain the blinking.
JGBtypeR is offline   Reply With Quote
The Following User Says Thank You to JGBtypeR For This Useful Post:
brandonblt2 (08-27-2021)
Old 08-27-2021, 08:36 AM   #4232
brandonblt2
Ok that makes sense.
I did get around to changing my O2 sensor. Car seems to be running better but I haven't put any real miles on it yet. Hopefully this solved my issues. You can see I really need to change my O2 sensor this is the old after 175k miles vs the new lol.
BrahmaBull1990 (08-27-2021)
Old 08-27-2021, 10:35 AM   #4233
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
That sensor is cooked! Are you running a rich tune?
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 08-27-2021, 03:34 PM   #4234
brandonblt2
Yea I'm catless, plus I believe my o2 sensor might have been telling my engine to dump more fuel also.
Old 08-27-2021, 08:41 PM   #4235
FrickingReallySlow
Drives: 2015 FR-S
Is this the primary O2 before the cat?
FrickingReallySlow is offline   Reply With Quote
Old 08-28-2021, 07:20 AM   #4236
brandonblt2
Yup.
And it turns out the O2 sensor was not the fix but instead I had a single unclamped vacuum line -_- The vaccum line would expand due to heat and leak air once the engine warmed up. Which explains why the problem seemed to pop up intermittenly but what was actually happening is during the night when the engine sat the rubber would shrink due to the cold. So the car ran better at night and in the morning versus it running like crap mid day when temps were high. CEL is now off and car seems to no longer be running rich. Thanks everyone who offered solutions.
The Following 5 Users Say Thank You to brandonblt2 For This Useful Post:
Aztec (08-29-2021), B T (08-30-2021), BrahmaBull1990 (08-29-2021), CallmeDave (09-02-2021), FrickingReallySlow (08-28-2021)
Old 08-28-2021, 12:28 PM   #4237
FrickingReallySlow
Drives: 2015 FR-S
Wow, great troubleshooting. Guess O2 sensors can last a long time even covered in soot
Which vacuum line was it btw? did you remember fiddling with it before
Yup.
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
brandonblt2 (08-28-2021)
Old 08-28-2021, 02:16 PM   #4238
brandonblt2
The line that runs from my catch can to the supercharger. To connect the different sized hoses I have a connector. I had one side clamped but not the other. I hadn't missed with the line before but I did add a oil cooler line near it so the temps near it increased quite a bit.
FrickingReallySlow (09-02-2021)
Old 08-29-2021, 01:51 PM   #4239
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Yup.
Nice work figuring it out!
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following User Says Thank You to Aztec For This Useful Post:
brandonblt2 (08-30-2021)
Old 09-02-2021, 08:12 AM   #4240
CallmeDave
CallmeDave's Avatar
Drives: 13 BRZ, 07 WRX
So I replaced the bypass valve but now Im having other issues, basically rough idle and it threw a P0172 code... also noticed while not in gear if I blip the throttle it seems to hesitate a bit rev to 2k and choke a little bit...
So far when Im driving down the road its seems ok.
I took a log while driving in to work this morning, could one of you guys that knows how to read this take a look?
Thanks
Errr also how do I share a log file.
13 BRZ Premium. 07 WRX.
CallmeDave is offline   Reply With Quote
Old 09-02-2021, 11:50 AM   #4241
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Have you confirmed your bypass valve opens as it should? Sounds like maybe something wasn't fully connected after installing the new valve.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
CallmeDave (09-03-2021)
Old 09-02-2021, 12:05 PM   #4242
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Thanks
https://datazap.me/
Accepts .CSV form
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post:
B T (09-02-2021), CallmeDave (09-03-2021)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
