Old 08-10-2021, 03:47 PM   #19265
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Originally Posted by CrowsFeast View Post
I think you're misunderstanding what I was describing. The pin moved freely but was 'bottoming out' on the old grease inside the guide hole. once that grease was removed (pulled out when it stuck top the tip of the pin) the pin was able to go all the way in to the guide hole as well as moving freely.
The pin itself is metal at the end but has a ribbed plastic sleeve for about 1" near the tip. Found a picture of a similar one (no hex portion on ours, just 2 flats)
Piston boots and guide pin boots were good; metal clips for guiding the pads were replaced and greased.
I've done a number of brake jobs on a number of vehicles. That's part of what makes it so frustrating when a simple job like replacing brake rotors and pads becomes a long drawn out pain.
I think I now prefer the setup I had on my german cars; pins are screwed into the caliper bracket and the caliper glided on the pins as opposed to this setup where the pins are bolted to the calipers and the pins glide on the mounting bracket. No way for air/grease/etc to get stuck inside the glide hole.
So you like Conti FSIII (Golf) setup, seems like. Their ZN is also good. I like Colette types for other reasons (mainly related performance).
Now I got what you meant, and I never saw a similar failure, with the grease loosing their properties to a point that becomes a impediment for the guide pin to bottom (i would expect the grease to move and create space).
Whenever I have to rotate the tires, I will take a look on those brakes (I think those are Tokico’s, but need to verify). See if they have anything unusual.
Two flats on guide pin is not ideal…
Stonehorsw is offline   Reply With Quote
Old 08-14-2021, 05:34 PM   #19266
Grady
Grady's Avatar
Installed a Garmin Catalyst. Sometimes I think the Garmin discount I get is a curse. Makes me buy to many Garmin things.
The Following 7 Users Say Thank You to Grady For This Useful Post:
BrahmaBull1990 (08-14-2021), Dzmitry (08-16-2021), Jdmjunkie (08-18-2021), MrSkubi (08-19-2021), NoHaveMSG (08-15-2021), villainous_frx (08-27-2021), wolffbite (08-16-2021)
Old 08-18-2021, 05:14 PM   #19267
dpfarr
Drives: BRZ ts
From traveling for funerals, vacation, field work, buying a house and living in general I’ve neglected installing the Edelbrock unit I bought in May(?). Taking a couple days off to do it leisurely. Installed a new led unit in my garage to work w.
dpfarr is offline   Reply With Quote
The Following 5 Users Say Thank You to dpfarr For This Useful Post:
MJones_RB (08-20-2021), norcalpb (08-27-2021), soundman98 (08-18-2021), Stonehorsw (08-18-2021), Wally86 (08-19-2021)
Old 08-26-2021, 03:46 PM   #19268
Danathin
Danathin's Avatar
Drives: 2018 BRZ Limited
Tinted the front windshield today:
Louvers last weekend:
Danathin is offline   Reply With Quote
The Following User Says Thank You to Danathin For This Useful Post:
2020BRZtS (08-27-2021)
Old 08-27-2021, 09:53 AM   #19269
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Is that legal where you live? I guess you don't plan on driving after dark.
CrowsFeast is offline   Reply With Quote
Old 08-27-2021, 10:23 AM   #19270
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Holy crap... you can't possibly begin to convince me that you can see ANYTHING at night time. Especially in CO roads. On top of that, this HAS to be illegal or I'll be mind blown. I guess on the positive side, the BRZ LED's are bright as hell, and may do a decent job of helping you see something...
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
Old 08-27-2021, 11:36 AM   #19271
Danathin
Danathin's Avatar
I'm sure it is not. Drove it at night yesterday and had 0 visibility issues and hit a pretty dark road. Bought a used FRS years ago that had the same tint preinstalled when we got it so we knew it wasn't an issue. Had that car from 2016-2019.
Ok I won't convince you, but we can. It's a little dark in the mountains but this car doesn't see nighttime out there very often anyways. We have a 4runner for that. This is a weekend cruiser. Owned for 2 1/2 years and less than 12k miles. Definitely illegal but cops seem lenient on that. Also, basically every single person in the US with tint on their front windows is illegal. Most tint laws are written that if you have ANYTHING (including stock) on the rear windows you can't have anything on the front. No one goes and removes their rear tint to tint just the front.
Comparative pic:
Dzmitry (08-27-2021)
Old 08-27-2021, 11:42 AM   #19272
Dzmitry
Dzmitry's Avatar
Interesting. I have a hard time seeing through the "visor" tint in my front windshield at 20% at night. But I rarely need to be looking that high up anyway, so it never bothers me. I would think with such a dark tint as you have, it would be a serious issue, but if it works for you then it works... As you say, you're not driving it much at night anyway so I guess that takes the worry away. Good luck!
Old 08-27-2021, 11:45 AM   #19273
Danathin
Danathin's Avatar
Wait are you thinking this is darker than 20%? The sun and black interior may have made it look worse. This is "only" 35% so it's not even as dark as our side windows which are 15% all around. Completely agree 20% would be brutal at night - 35% pushes it but we've never ran into an issue for us.
Old 08-27-2021, 12:38 PM   #19274
Grady
Grady's Avatar
I can see it now. A post on the BRZ curse!
The Following User Says Thank You to Grady For This Useful Post:
Old 08-27-2021, 01:06 PM   #19275
If you are 35% you are definitely within the law in Colorado except the front windshield if it is a full tint (I can't see the picture). There you can only tint the top strip, not the whole glass.
One correction about your earlier comment on front windshield though. It can be factory tint, just not third party/aftermarket as I understand it.
Old 08-27-2021, 01:06 PM   #19276
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
I love my 5% but on the windshield would be a death sentence. In my area you could get away with it on the street but it would never pass inspection.
2020BRZtS is offline   Reply With Quote
Old 08-27-2021, 01:10 PM   #19277
Danathin
Danathin's Avatar
35% is on the whole windshield - so not legal.
My comment wasn't on the windshield, but rather on front windows (driver and passenger). Typically you can not tint your front windows if your rear (sedan back seat, rear quarters or back windshield) are tinted, including factory. This means anyone adding 35% to "stay legal" typically isn't within the law. At least in IL and in CO that's the case, as well as other places I've read (there's that tint law website that lists everything out).
Dadhawk (08-27-2021)
Old 08-27-2021, 01:11 PM   #19278
Danathin
Danathin's Avatar
Oh god 5% on the windshield and you'd have to put your head out the window. 5% and 35% are VERY different.
