Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 08-26-2021, 10:09 AM   #1
s30series
Drives: 2015 BRZ Series.Blue
Track Day Excessive Oil Temp for factory recommended 0w-20 persists
Just watched....ugh....savagegeeses' video...1 min into it noticed 250 on the oil temp....87 degrees outside.
Why oh why can't they just integrate an oil cooler into the radiator?
edit- later on in the video its at 254...
s30series is offline   Reply With Quote
Old 08-26-2021, 10:17 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Majority of owners won't need one.
If anything it would be nice to see a factory oil cooler option offered from the dealer.
The Following User Says Thank You to RToyo86 For This Useful Post:
timurrrr (08-26-2021)
Old 08-26-2021, 10:20 AM   #3
PulsarBeeerz
Drives: JRSC BRZ SOLD
Cost. The new one has a water to oil heat exchanger.
PulsarBeeerz is offline   Reply With Quote
Old 08-26-2021, 10:29 AM   #4
s30series
Noticed that. I installed one of those soon after I purchased my Series.Blue.
Only thing it *may* have helped was to normalize temps quicker after a hard run.
The Following User Says Thank You to s30series For This Useful Post:
Old 08-26-2021, 10:31 AM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I believe that is more of the point. At least that's what I feel I remember people pointing to a few years back when the Forester mod was common. Plus many cars in our budget don't have a 'proper' oil cooler. Hell, even the S2000 has one like the new BRZ/86.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 08-26-2021, 10:32 AM   #6
s30series
*ahem* performance package : upgraded brakes, oil cooler, revised tune?!?
Our 2020 Outback XT has oil cooler, transmission cooler, and heat exchangers for both. Ohh well.
I guess I'm glad the "track mode dash setting" shows the oil temps. Us OG owners back in the day had to buy a P3 guage to watch it on a track
Old 08-26-2021, 10:34 AM   #7
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Sucks, but just gotta plan to either delete the stock cooler and go with an air cooler or cut the lip off the stock oil cooler and put a sandwich plate on that. The latter being the ideal solution for most people that still street drive, I suspect.
FA24 also seems to have a better oiling system than the FA20 so we'll likely be able to just run 5w30 or 5w40 and be "fine" for mild track use with the stock cooler.
Old 08-26-2021, 10:42 AM   #8
weederr33
weederr33's Avatar
HKS teased their oil cooler which appeared to sit on the oem just fine!
Old 08-26-2021, 10:51 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
250F is no big deal. My oil temp stabilizes at 270-275F at the track and never goes into runaway oil overheating. 275F is not a problem for good synthetic oil. I do run 30-wt during track season, I wouldn't run 20wt at those temps...
Oil cooler is not required for "casual" HPDE type track usage (say, 15-20 minute sessions a few times per day). Whatever that Savagegeese guy says...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Blighty (08-29-2021), Tokay444 (08-29-2021)
Old 08-26-2021, 10:51 AM   #10
s30series
Say what?
Old 08-26-2021, 10:55 AM   #11
s30series
Who knows what the max was...just noticed 250 when I paused, then 254 later on in the video. Down here in Gods country when its 98 degrees with 70% humidity, track day oil temps get...uncomfrotable...without an oil cooler.
I did quite a number of HPDE events throughout the year...no way I'm dumping my daily Nanodrive 0w-20 for a thicker oil just for a track day to compensate for high oil temps...that gets....expensive
Also too lazy to change pads when I get off track
Old 08-26-2021, 11:03 AM   #12
weederr33
weederr33's Avatar
Say what?
you can see a glimpse of it here at 1:46
chaoskaze (09-16-2021)
Old 08-26-2021, 11:05 AM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
My data shows oil temperature getting up to around 270F after a couple of laps and maintaining 272F plus/minus a couple of degrees after that. Those temperatures are not a big deal for any kind of decent synthetic oil.
??? Change over to 30wt for track season, change oil every 2-3 events (ish), change back to 0w20 after track season. No big deal...
I would bet that 30wt in the summer months is thinner than 0w20 in the winter for a significant percentage of your daily driving...
I usually change back to street wheels/tires and pads day after I get back, but currently still rolling on Nankang CR-1s with CSG C2 pads a good week and a half after Palmer...
Old 08-26-2021, 11:30 AM   #14
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Running an oil cooler would pay for itself quickly in not having to change oil every 2-3 events...
but anyway, 254F in a single lap of Monticello isn't acceptable IMO. Mishimoto's WRX cooler also looks like it will fit right on, but I'd rather have a better core so it would be awesome if they sold the sandwich plate separately.
The Following 3 Users Say Thank You to DocWalt For This Useful Post:
timurrrr (08-26-2021), TommyW (08-26-2021), Ultramaroon (09-01-2021)
Water Temp problem dejxx Forced Induction 10 07-29-2015 02:26 AM
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
