Old 08-24-2021, 12:34 AM   #15
Turdinator
Señor Member
Turdinator's Avatar
This is all just speculation until the Gen 2s are out for the public to pull apart. For all we know the seats come with automated dildos built in, probably not but we cant be 100% sure until the car is released to the public
1974 TA22 Celica
2013 86 GT
Old 08-24-2021, 02:49 PM   #16
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Originally Posted by cjd View Post
Did the auto transmission change? If not... Bolt-up seems likely.
I'm mostly ignorant on the gen2 stuff, but this one has me intrigued as a just-in-case I need to know some day.
Same here. I would love to throw in an IAG stage 2 block and a gen 2 transmission...power and reliability.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
jcw99 (09-09-2021)
Old 08-24-2021, 08:50 PM   #17
Oooo! Seat swap!
jcw99 (09-09-2021), Turdinator (08-25-2021)
Old 09-07-2021, 11:54 PM   #18
Poogchomp
Poogchomp's Avatar
Drives: Chevrolet Ram 250
Originally Posted by Goingnowherefast View Post
I'd actually be pretty shocked if the transmission bellhousing didn't have the same bolt pattern. Mechanically, I'd bet it'll bolt in and the output is probably the same. The electronics may be different though.
The AISIN gear boxes use removal bell housings so even if they were for some reason different (would be very unsubaru like if they were) it wouldn't matter too much. As for electronics, if they were different then most likely a soldering iron and heat shrink would be able to fix that easily.
Poogchomp is offline   Reply With Quote
The Following User Says Thank You to Poogchomp For This Useful Post:
jcw99 (09-09-2021)
Old 03-17-2022, 12:24 PM   #19
bhmax
Drives: 13 BRZ, 17 Focus RS
Any more definite info on this? There’s one on eBay…
bhmax is offline   Reply With Quote
Old 03-17-2022, 01:25 PM   #20
Evil Rocky
Drives: FRS
I am wondering too if this is something that can be done. Been saving for a CD009 and hope this works for better reliability
Evil Rocky is offline   Reply With Quote
The Following User Says Thank You to Evil Rocky For This Useful Post:
bhmax (03-17-2022)
Old 03-17-2022, 02:55 PM   #21
RedReplicant
Drives: None
I guess I am not seeing the point in swapping to a new one given the price difference unless they fixed the issues with 4th gear, which we won't see until someone actually opens one up. I am leaning towards a no, they haven't.
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
bhmax (03-17-2022), Tcoat (03-17-2022)
Old 03-17-2022, 03:14 PM   #22
At this point there are not enough miles on them to even decide if they are "more reliable" anyway. They could turn out to be crap.
bhmax (03-17-2022), BrahmaBull1990 (03-17-2022), Evil Rocky (03-17-2022), RedReplicant (03-17-2022)
Old 03-24-2022, 02:53 PM   #23
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
I really want to swap to the new gen transmission. I drove my 2014 FRS back to back with the new 2022 BRZ and the difference was night and day.
My tranny exhibits the typical slight crunchiness & troubles getting into 1st gear at a stop & 2nd is not smooth (this is with Red line trans oil).
The new 2022 was so buttery smooth and easy to use. And this was while it was freezing cold no warmup.
kevaughan is offline   Reply With Quote
The Following User Says Thank You to kevaughan For This Useful Post:
SuperTom (03-25-2022)
Old 03-25-2022, 02:39 AM   #24
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Damn... I had a buddy who recently had to drop his 2nd gen 86 tranny to rethread a stripped hole he caused while installing shifter springs.. should have asked him to take a picture of the bell housing. too late now
Bach415 is offline   Reply With Quote
Old 03-25-2022, 05:12 PM   #25
RedReplicant
Drives: None
The bell housing part number is the same for 2013-2022
30099AA051
The Following 5 Users Say Thank You to RedReplicant For This Useful Post:
Bach415 (03-31-2022), DocWalt (03-30-2022), Evil Rocky (03-25-2022), flippy (04-09-2022), jrhudson (03-25-2022)
Old 03-25-2022, 11:57 PM   #26
Evil Rocky
Drives: FRS
I can’t wait to get more info on the transmissions if can be swapped
Old 03-27-2022, 02:54 PM   #27
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I will likely pick one up once they saturate the market and prices drop. There is a local one on eBay for $1800. I can get 13-16s all day long for $300-500, and 17-21s for $400-600. No way I would pay $1800 when I could buy 3-5 older transmissions for the same price. It takes 3 hours to drop the tranny taking my time.
I’ll wait to see if the improvements actually materialize into holding more power and feeling better, and I’ll wait to see if there won’t be any TSBs. Even then, a CD009 would be better at those prices until things fall.
Old 03-27-2022, 06:28 PM   #28
Irace86.2.0
The CD009 will hold far more torque and probably be more reliable, especially at the extremes. The only advantages to this is the slight weight penalty with the CD009 and the drop in ability. Gear ratios are similar enough.
A used CD009 can be had for reasonable prices. Ive seen new CD009s for under $2k.
The previous transmission seemed to be rated around 185tq with a real world capacity of 325-350wtq. The CD009 has a rated capacity in the 300’s from the factory, but has gone past 1200wtq in the real world. It is in a different league. Per the article below, shot peening can improve fatigue resistance and torque capacity, and I could see a 20% improvement could be good for 400wtq, and maybe more if they improved and beefed up 4th gear too, but this won’t be earth shattering numbers or greatly improve reliability at the limits. The goal isn’t to improve FI torque capacity. It was probably to improve longevity from rapid heat and torque cycles on the track. Just my guess. People were destroying transmissions on the track with NA or CARB level FI power levels. This was probably from fatigue cracks. Shot peening should add more oil protection and reduce fatigue cracks.
https://www.amtechinternational.com/...enefits-gears/
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Evil Rocky (03-29-2022)
transmission swap senpai_gt86 Engine, Exhaust, Transmission 2 05-14-2020 08:26 PM
Transmission swap Wilfred86 Engine, Exhaust, Transmission 6 10-04-2016 04:22 PM
Transmission swap ChrisD Engine, Exhaust, Transmission 6 04-04-2016 09:27 PM
transmission swap? VJZNAV Southern California 1 03-26-2014 11:57 PM
New hybrid drivetrain for Gen2 86? Mim Scion FR-S / Toyota 86 GT86 General Forum 28 09-17-2013 09:59 AM
